Old 12-28-2012, 03:43 PM   #1
Domromer OP
Desert Rat
Domromer's Avatar
Oddometer: 1,084
Why do BMWs' cost so much to run??
Ok not a troll or anything. I've had a vstrom for a few years, and every other little dual sport there is. I've wanted an 1150gs forever. Every time I talk to anyone on the vstrom forum they talk about how the BMWs cost so much to maintain and how things are always breaking. So I decided to ask people who actually own the any kind of post 2000 GS...do they brak a lot, do they cost a lot to fix, do they have a lot of known mechanical issues? I just sold a bike so I'm seriously considering getting a GS that's a few years old. Ideally I'd like to spend around 12k.
If all you ever do is all you’ve ever done, then all you’ll ever get is all you ever got.
http://advrider.com/forums/showthread.php?t=851060 ... A desert rat explores the south.
Domromer is offline   Reply With Quote
Old 12-28-2012, 03:47 PM   #2
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
Are you gonna do your own maintenance?
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 12-28-2012, 03:51 PM   #3
Domromer OP
Desert Rat
Domromer's Avatar
Oddometer: 1,084
Yes and no.
On the Vstrom I've done the oil, coolant, air filter, chain adjust, removed and replaced both wheels, installed steel brake lines, removed and installed new forks, and various other things I'm probably forgetting.
I would not feel comfortable doing my own valve check and adjustment. Since I'm a bit beyond the basics but not much.
Old 12-28-2012, 04:03 PM   #4
advNZer?
advNZer?'s Avatar
Oddometer: 2,829
i dont really think BMW cost any more to run than any other bike if you take it to the shop.The best thing to do is find a shop that can service BMWs but arent a official bmw dealer.Any issue with 1150gs is very well known now.
If something breaks i think major parts are expensive.
I think the interenet over states reliability issues.Years ago in 2002 i bought a 1990 BMW e34 535.If you beleived the internet hype they are not reliable cars.I had it for many years and had 1 no start incident and had to replace some suspension/steering parts(well known)
aka BMWST?
advNZer? is offline   Reply With Quote
Old 12-28-2012, 04:11 PM   #5
spagthorpe
spagthorpe's Avatar
Oddometer: 14,662
The valve checks and adjustments on the 1150s are dead simple. Really. If I had to take the bike to the dealer every 6K for them to do it, I probably wouldn't own these bikes. The simplicity, of at least the routine stuff is a big reason I ride these pigs.
Now, if the ABS goes south on you, or you have a final drive issue, or any of the not so common things come up, then it can get pricey. Having ridden a few of the competition though, the other reason I ride this bike is that somehow it just feels better to me than the others. Sometimes you have to pay a little extra for what you want.
spagthorpe is offline   Reply With Quote
Old 12-28-2012, 04:18 PM   #6
Jim Moore
Jim Moore's Avatar
Oddometer: 13,212
Yes and no.
Brother, if you can do that stuff you can do a valve adjustment on an oilhead. It's dead simple.
Here's the deal on your original question. BMWs quality assurance program is crap. You either get a good one or a bad one. If you get a good one, it will run for hundreds of thousands of miles with very little maintenance. Literally. If you get a bad one it will cost you multi-thousands of dollars in repairs every 30K miles. Literally.
With that in mind, I'd trust a high-mile bike more than I would trust a low-mile bike. A bike with 75k miles can be had pretty cheap, and will probably run another 100K. A bike with 10K miles will be more expensive and can have several multi-thousand dollar time bombs ticking.
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is online now   Reply With Quote
Old 12-28-2012, 04:27 PM   #7
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Valve adjustments and checking is quite simple on a GS, much more than on a Vstrom. The heads are right there and easy to access. Lots of threads on how to do it.
TB sysncs are not hard, but do require a sync tool which is $150 or so and then it is pretty easy, again, lots of threads on how to.
Parts and shop time can definately be more than a Suzi, but not usually more often by any stretch.
The problem with asking the V-strom site is all they they ever hear and see is the negative side of people complaining.
There are literally thousands of posts in Ride Reports of people who travel RTW on Beemers with only standard service issues. Other have had some trouble.
There is the ever present final drive issue...a problem for some, not so much for others. Expensive if you have the problem and if you have it fixed at a dealership. But the balance is, once you have it done it will likely be a very long time before you need another one....many chains and sprockets on a Stromer between FDs on a BMW. I have no issue with chains, I like them, but to replace a set, I usually change them as a set of chain and both sprockets, and I always use a good X-ring so It requires less lube and last very well. Keeping it clean is more important than lube on an X-ring. But on my KTM a good X-ring and steel front sprocket and a Tri-metal rear sprocket is $200 or so. I get max a few thousand miles out of it...hard enduro use, maybe more in mixed use. That is alot of money over 100,000 miles. Even if you get 10k miles out of a set, that is 10 sets in 100k miles x $200 a set you are at $2000 and alot of time replacing them. A FD is not much different in the long run.
Alot of people pay alot of money for their BMWs and thus prefer to spend alot of money on the highest grade of oils and services right on schedule and they are willing to spend alot of money to upkeep theirs.
That does not mean a person HAS to do so.
Any good oil will work, extending service intervals is common practice once the valve settle in. Once TBs are set right they rarely go out.....
Some will have different opinions, but rear the Ride Reports not the repair sections....many more miles ridden than spent in service for 90+% of GS owners.
I had a few frustrating issues when I got my RT, but once sorted it has been great. Nothin but oil nowdays. I would have no issue hoping on and riding RTW today....my body might, but not my bike.
PS: Resale is good, if you buy and don't like it, resell it and buy another Stromer or go BIG service cost and buy a KaTooM....I love mine, but man, THAT is some service.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 12-28-2012, 04:42 PM   #8
terryckdbf
Oddometer: 1,001
If you have not ridden a GS do so. Then you will know why we ride them. Maintenance is the same for any machine. Valves are one hour every six thousand, another hour for oil, filter, transmission and final drive. We do not have a BMW at this cost for ego, nothing handles like a GS.
Terry
terryckdbf is offline   Reply With Quote
Old 12-28-2012, 04:53 PM   #9
Ken Fritz
Oddometer: 1,017
Thumb 11560GS is not expensive to ride
I bought my 2001 GS new in 2002. It's been a reliable bike. Only twice - 1: low battery, 2: flat tire - did it ever prevent me from going anywhere. The first few years I rode only about 5,000 miles/year. It has over 48,000 miles now - two XC trips put more than 20,000 miles on the bike. I have adjusted the valves, changed the oil & filter, and replaced an alternator belt (preventive measure) in campgrounds. That's no big deal. The tools are basic and simple. The access to the engine is almost unlimited.
Besides tires and brake pads, oil, filters, and clutch/brake fluid changes (all normal & easy maintenance), I have replaced the shocks with Wilbers, replaced the brake lines with braided lines and I recently removed the charcoal cannister (in the way of some new side Hepco & Becker side case racks). There are plenty of farkles, but they are personal preference items. None were really necessary and none have failed.
It runs, rides and looks great. It's been inexpensive to operate - I do all my own maintenance work and I know it's been done right, so I ride without worries.
Ken Fritz screwed with this post 12-28-2012 at 05:03 PM Reason: spelling
Ken Fritz is offline   Reply With Quote
Old 12-28-2012, 04:59 PM   #10
Domromer OP
Desert Rat
Domromer's Avatar
Oddometer: 1,084
Terry
I did ride one in 03. Felt great but all I could compare it to was my xt or klr. I'll need to ride one again here soon to compare apples to apples. I guess I'll need to schedule a test ride. Hopefully the 1200gsa doesn't feel that different than the 1150gs.
Old 12-28-2012, 05:19 PM   #11
jfslater98
Oddometer: 304
You're over-qualified for doing a valve check on an 1150.
KellyMac's observations on chain/sprocket costs were an interesting counterpoint to the final drive "ghosts". I loved my 1150, and have since upgraded to a 1200. You'll find the 1200 to be much lighter and quicker than the 1150 you tried. I was a former KLR owner and there is definitely no comparison.
jfslater98 is offline   Reply With Quote
Old 12-28-2012, 05:20 PM   #12
JustKip
JustKip's Avatar
Oddometer: 4,470
Terry
Maintenance is the same for any machine? A GS in the OP's price range will take 4 valve adjustments to his V-Strom's 1. A Harley won't take any, ever.
Also, I suggest that there's a fair bit of "ego" in the statement " We do not have a BMW at this cost for ego, nothing handles like a GS." as there are many bikes that handle better in one way or another. Dirt bikes, smaller dual sports, and KTMs are far superior in the dirt. Supermoto's excell on tight twisties, and sport bikes handle better on most mountain roads. Then there's the slab and touring bikes...
The GS does all of these pretty darned well, but it's not the best at any of them.
BTW; I have almost 30k trouble free miles on mine - nothing but routine maintenance.
And Yes, valve adjust is pretty simple. Unlike the V-Strom, you don't need to dissasemble half the bike, and there's no coolant to change.
JustKip is offline   Reply With Quote
Old 12-28-2012, 05:27 PM   #13
dieselpete
dieselpete's Avatar
Oddometer: 135
I agree, the issues with the Beemers are no more common than on other bikes. However major components can be expensive. I also purchased a GS due to the simplicity, saving on labor rates of shops, and limiting down time due to field failures.
dieselpete is offline   Reply With Quote
Old 12-28-2012, 06:11 PM   #14
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,787
Click on my second link below for the maintenance run down on my '07 R1200GSA. As stated above, with what you've already done to your Strom you're more than qualified to do valve checks/adjustments on a BMW opposed twin.
Good luck in your search.
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 12-28-2012, 06:17 PM   #15
Domromer OP
Desert Rat
Domromer's Avatar
Oddometer: 1,084
Does the 1150 have shim and bucket? Obviously the access is 10x easier than on a Vstrom. I never imagined I'd have to remove all the crap to just change the plugs.. Seat. Fairing. Tank.. Move radiator.... Ugh.
Times are GMT -7.   It's 04:21 AM.
