Old 12-28-2012, 02:58 PM   #50686
Mossy-Back
Brown Falcon
Mossy-Back's Avatar
Oddometer: 1,657
Got my bike partially torn down and oil drained today.
First thing tomorrow morning my buddy is bringing his XRL over to my place (on a trailer) and we're going to adjust valves on both bikes, and then put in my new clutch, put on my fork skins, and tweak my suspension a bit.
Any advice for removing the right side engine cover? Does the brake lever need to come off?
'05 CRF450X
Once a Marine, always a Marine!
Mossy-Back is online now   Reply With Quote
Old 12-28-2012, 03:01 PM   #50687
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,577
Originally Posted by Schultz! View Post
Hehe I know the feeling just got up from the basement and seen all this talk of "lipstick on pigs" and fun with a Dremel.
Was working on/with all of the above!
Santa brought me a XRs case saver! My only problem with it is it looked like it was machined with endmills from 1940
So a dremel with a 320 flap wheel, some 600/1000 wet sandpaper plus the polishing wheel I have this beauty
Me likey... A LOT!
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 12-28-2012, 03:07 PM   #50688
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,577
If i was in your shoes I would pick up the Dremel 3000, I have 2 4000s that I have had both repaired twice for burning out the speed controls for a total of 4 failures. The 3000 might get a bit hot running at low rpm or a large flap wheel but keeps asking me to punish it more with out a single issue.
I also have a 3000. I run a flex-shaft attachment on mine. I think it makes fine detail work easier.
http://www.dremel.com/en-us/Attachme...spx?pid=225-01
Old 12-28-2012, 04:09 PM   #50689
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Originally Posted by Brown Falcon View Post
...Any advice for removing the right side engine cover? Does the brake lever need to come off?
I don't know if you have to remove the rear brake pedal to remove the clutch cover. However, I decided it was best to remove the rear brake pedal.
P.S. Have fun with the cotter pins.
Spud
Old 12-28-2012, 04:20 PM   #50690
mcma111
mcma111's Avatar
Oddometer: 12,902
When having to remove the clutch cover I leave the pedal in place but I remove both the brake pedal and brake light switch springs along with the master cylinder bolts. This way you can depress the pedal to get the clearance you need to remove the clutch cover.
Am I going to tell all of you guys ALL of my secrets ???
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-28-2012, 04:24 PM   #50691
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Originally Posted by ThumpnRed View Post
Thank you, Red. I looked online at AutoZone and O'Reilly, but I can't find that flasher anywhere. Do you remember approximately how much it cost?
Spud
Old 12-28-2012, 04:43 PM   #50692
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,577
Spud
I dont... I bought it several years ago when I was fighting with my blinkers. I ended up with several different flashers. I think any turn signal flasher would work.
Old 12-28-2012, 04:52 PM   #50693
Mossy-Back
Brown Falcon
Mossy-Back's Avatar
Oddometer: 1,657
Thanks Steve. I was thinking about trying that so I didn't have to remove the pins. Anything I need to watch out for when removing that oil line above the filter cover?
'05 CRF450X
Old 12-28-2012, 04:58 PM   #50694
Memnok
Fly high, go far.
Memnok's Avatar
Oddometer: 374
I have my battery under my seat. The fuse block is ziptied to the frame rail... easy access by pulling off the number plate. The hot wire from the fuse runs to the 30 terminal on the relay. The 85 terminal goes to the green wire that fed the dash light. The 86 terminal goes to the black dash light wire. the 87 terminal wire goes to the heater. The other heater wire goes to a ground.
Can you link the relay too? This sounds like a great idea. I wanted to run them off of something switched, but worried that the additional draw from the warmers would blow a fuse. The relay sounds perfect.
Clint >>> 2007 XR650L <<<
Good government is no substitute for self-government. Mahatma Gandhi
That government is best which governs least, because its people discipline themselves. - Thomas Jefferson
Memnok is offline   Reply With Quote
Old 12-28-2012, 05:43 PM   #50695
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Thank you, Red. I think this electronic flasher will work well; it only costs $9.49.
http://www.napaonline.com/Catalog/Ca...D12_0335211065
I analyzed the DPCO switch cirucuit, with the help of an electrical engineer. The Tusk Heated Grip Kit consumes about 9.0 watts per grip on low setting, with the resistor consuming about 7.2 watts. The high setting consumes about 17.8 watts per grip. Therefore, the low setting generates about 1/2 the heat of the high setting, and wastes 7.2 watts from the resistor.
The DPCO switch circuit consumes about 4.42 watts per grip on the low setting, which is about 1/2 the heat generated by the Tusk setup on low heat, and 1/4 the heat generated by the high setting. Therefore, I won't be using the DPCO switch. I think I am going to follow your example, and install an electronic relay. The LED dimmer is very nice, and inexpensive; however, it's just too large for me.
Spud
Spud Rider screwed with this post 12-28-2012 at 08:43 PM
Old 12-28-2012, 06:19 PM   #50696
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,577
I'm not sure I understand your question. I'll do my best to answer what I think you are asking. If I am way off... let me know. The power to the heater runs through the relay. The relay is also wired to the dash light wire which is only hot when the key is on. If the key is not on, there is no juice flowing to the grip heaters.
Old 12-28-2012, 07:02 PM   #50697
mcma111
mcma111's Avatar
Oddometer: 12,902
You may have to remove the mid pipe bolt to have enough movement for the clutch cover to come off. Remove the top banjo bolt and the pipe will be plenty loose. Be sure to keep track of the copper crush washers and which banjo bolt goes where. IIRC the black banjo bolt is on the bottom. It has a larger hole/passageway.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-28-2012, 07:23 PM   #50698
Memnok
Fly high, go far.
Memnok's Avatar
Oddometer: 374
I think I figured it out. I was not sure which relay to use, but it looks like I can use a 4 pin single pole.
Old 12-28-2012, 08:32 PM   #50699
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,280
+1
You need to remove the small bolt that holds the oil pipe to the head also.
Leave the mid pipe bolt and pull the cover off about 1/2" to get the room to remove the lower banjo bolt completely from under the exhaust.
Assemble in reverse of dissasembly.
Remove the brake lever to have clear access, clean and grease the petal shaft upon re-assembly.
I am sure you have read about the O ring on the oil tube and the crank end seal.
Regards
Fritzcoinc
fritzcoinc screwed with this post 12-28-2012 at 08:46 PM
fritzcoinc is offline   Reply With Quote
Old 12-28-2012, 08:49 PM   #50700
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,577
Grip Heater Wiring Diagram
Pictures are always easier...
Times are GMT -7.   It's 07:48 PM.
