Old 12-28-2012, 08:00 PM   #32101
ba_
ba_'s Avatar
Oddometer: 2,722
Originally Posted by MeefZah View Post
That's how I did it.
I actually found one of the 17mm nuts on the back side was loose when I did mine, despite them being lock nuts.
Thank you
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Old 12-28-2012, 08:26 PM   #32102
scottmac
scottmac's Avatar
Oddometer: 1,584
Originally Posted by ba_ View Post
Thank you
Taking the entire top piece of the triple clamp off is definately the easist solution. That's what I did to
install fat bars and then risers for a scotts sub mount stabilizer.
scottmac is offline   Reply With Quote
Old 12-28-2012, 09:16 PM   #32103
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 532
Originally Posted by krussell View Post
I'm trying to decide what sort of rear rack to put on my WRR. While the billet racks look nice, I'm concerned about the small mounting area. I really like the mounting approach of the TCI Borrego, seems much more distributed/robust. At some point, in addition to the rear rack, I think I'm going to add a Wolfman saddlebag setup with racks. I have several questions for folks who have used any of these.
1) Anyone use a billet rack and had it break the mount point?
2) Anyone use a TCI Borrego AND the wolfman racks?
My plan is to get the Borrego with a hard case bracket and use a small pelican box for around town. Then for longer trips ditch the top case and use a wolfman saddlebag setup along with a dry bag across the top.
Another option would be a Giant loop setup instead of the wolfman, which eliminates any rack conflict, I think.
Any suggestions or experience would be appreciated.
krussell,
I thought of the same mounting and rack combo a month back but it will not work without some modification;(already had the Wolfman racks mounted) TCI Borega needs the same mounting location. So I got one of the Big racks from
http://www.automotivemachine.com/index.php?option=com_content&view=article&id=51&Itemid=56
If interested in it let me know and I'll show you a pic of it mounted so you can get a more realistic idea of size.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 screwed with this post 12-28-2012 at 09:28 PM
pfy50 is offline   Reply With Quote
Old 12-28-2012, 11:20 PM   #32104
jrou111
Stair Climber
jrou111's Avatar
Oddometer: 256
Originally Posted by alansz400 View Post
That cover comes off real easy. I took mine off when my site glass was pushed in. Heres what it looks like with the cover off. I reused the gasket and havent had any oil leaks. I wounder if somthing came loose inside the motor and got wedge between the gear and the case?
Update:
I opened up the side case...not good.
Looks like the nut on the counterbalancer backed off and went for a ride, until it got wedged in the gears on the waterpump.
I've got a replacement clutch case cover on the way (complete with waterpump gear), so I think it shouldn't be too difficult to repair. Hopefully.
Anybody seen anything like this on a WR250? Seems pretty uncommon.
jrou111 is offline   Reply With Quote
Old 12-29-2012, 06:34 AM   #32105
1Down-5Up
1Down-5Up's Avatar
Oddometer: 109
For the cheapie guys out there I used a piece of 3/4 " plywood to replace the tin lid on the Yamaha rear rack.
Nice thing is you can cut them to any shape to experiment. My latest one is cut to fit the Wolfman tail bag.
I have a plywood box for my 68 cc chainsaw that I just screw to the plywood plate and it holds.
I'm going to try a trip with a few overnights so I'll make a bigger one to hold the hammock, bag, and other bulky gear.
In this pic I have my FatMax saw tucked under the bag and the anti-slip stuff contact glued onto it.
1Down-5Up is offline   Reply With Quote
Old 12-29-2012, 07:40 AM   #32106
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,474
I made my own as well from a scrap piece of .25" aluminum. Picture is before painting. After seeing it my wife said I should have just bought one. Guess she wasn't impressed with my machining skills. I made some aluminum spacers to fit it above the fender of the type that are supplied with the purchased aluminum racks.
FWIW in case it helps someone, I posted a question several pages ago asking about the mounting hole pattern spacing. The front-back spacing is 70mm and the side-side spacing is 50mm.
swimmer is online now   Reply With Quote
Old 12-29-2012, 08:00 AM   #32107
AZ TOM
Oddometer: 3,872
Originally Posted by KansasBob View Post
As I remember........... the consensus was that the bike is sprung stiff for the average rider and the rear shock didn't have near enough rebound damping........ even when maxed out. For a light rider like yourself, the lack of rebound damping, and stiff spring makes the problem even worse. The rear wheel hops up in the air when it bounces of rocks, ledges, and roots......... ect. The settings were to try and keep the rear wheel on the ground with the stock suspension. In other words....... the best you can get with what you got. The right spring for your weight and a re-valved rear shock with more rebound damping is what you "Need" but, if that isn't in the cards right away it's a good compromise especially for someone your weight.
Agree with almost all your advise with the exception of more rebound damping. Once I backed off the spring tension & increased the sag the rebound damping seems more than adequate, no more kicking me forward over the front wheel. Too much rebound damping will also keep the rear wheel off the ground & not return quick enough to follow the terrain.
AZ TOM is online now   Reply With Quote
Old 12-29-2012, 09:13 AM   #32108
oldtrucks
oldtrucks's Avatar
Oddometer: 286
Originally Posted by jrou111 View Post
Update:
After seeing the first picture I figured it would look like that inside. How many miles are on the bike?
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. -Benjamin Franklin
oldtrucks is offline   Reply With Quote
Old 12-29-2012, 10:13 AM   #32109
KansasBob
KansasBob's Avatar
Oddometer: 515
Yea, me too. The locking tab for the balancer gear nut is laying there in the case. Must not have been bent over all the way, or something. A close up of the locking tab would be nice
KansasBob is offline   Reply With Quote
Old 12-29-2012, 10:49 AM   #32110
jon_l
jon_l's Avatar
Oddometer: 3,037
Originally Posted by expatbrit View Post
I'm failing here -- I have a WRX and a WRX combo, both in blue.
Any issues with the turbo and the trailer?
Mine is the basic Impreza with 2.5 L engine. Pulls a trailer extremely well for a 4-banger.
'09 Honda CBF1000
jon_l is offline   Reply With Quote
Old 12-29-2012, 12:48 PM   #32111
alansz400
alansz400's Avatar
Oddometer: 890
Update:
Wow that sucks. Looks like it could have been alot worse. Luckily the case didnt get cracked. Getting ALL that metal out of the motor looks like its going to be the hard part.
alansz400 is offline   Reply With Quote
Old 12-29-2012, 01:11 PM   #32112
ArmyJoe
ArmyJoe's Avatar
Oddometer: 1,185
Plastic cutting boards work, too.
As it is, I'm scraping a boot trying to throw a leg over the bike. I'm going with the Automotive Machine & Supply Triangle Rack to keep it a low and contoured profile.
2009 Can-Am Spyder RS, 2008 Yamaha WR250R
My latest adventures detailed at ArmyJoe's Perpetual Picture Thread:
http://advrider.com/forums/showthread.php?t=888783
ArmyJoe is offline   Reply With Quote
Old 12-29-2012, 05:49 PM   #32113
shep546
shep546's Avatar
Oddometer: 215
Really thinking of ordering these side panels... only thing is I don't really feel they are worth the price.
shep546 is offline   Reply With Quote
Old 12-29-2012, 06:11 PM   #32114
Joe Watson
Joe Watson's Avatar
Oddometer: 1,030
A ride report will come at some stage, but I have been working on the video and thought I would post up Episode 1. A mate and I nailed down a date and set to work on making our dreams of a Cape York ride possible. Two very well set up WR250R's and a lot of planning later and we did it in September of this year.
Please subscribe to my youtube channel for more vids and to keep updated with the latest episodes.
Joe Watson is offline   Reply With Quote
Old 12-29-2012, 06:53 PM   #32115
ba_
ba_'s Avatar
Oddometer: 2,722
What that thing that is in the line of sight on your buddies bike?
Times are GMT -7.   It's 10:11 AM.
