Old 12-28-2012, 09:52 PM   #50701
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,512
Originally Posted by Memnok View Post
I think I figured it out. I was not sure which relay to use, but it looks like I can use a 4 pin single pole.
That looks like it will work.
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is online now   Reply With Quote
Old 12-28-2012, 09:58 PM   #50702
Spud Rider
Spud Rider's Avatar
Oddometer: 3,758
Originally Posted by ThumpnRed View Post
Pictures are always easier...
That's a beautiful diagram, Red.
I found this heavy-duty, electronic flasher at NAPA; it only costs $9.49.
http://www.napaonline.com/Catalog/Ca...D12_0335211065
Spud
Old 12-28-2012, 10:01 PM   #50703
bwalsh
bwalsh's Avatar
Oddometer: 11,155
Originally Posted by Schultz! View Post
If i was in your shoes I would pick up the Dremel 3000, I have 2 4000s that I have had both repaired twice for burning out the speed controls for a total of 4 failures. The 3000 might get a bit hot running at low rpm or a large flap wheel but keeps asking me to punish it more with out a single issue.
Thanks! I'll have a look at the 3000. That was one of the reasons I didn't bite the bullet yet. I had read some not so good reviews on the 4000.
Originally Posted by Spud Rider View Post
Thanks for the reply, Red. If I may ask, how much did the heavy-duty, electronic flasher cost? I found one at AutoZone which costs $12.99.
I'm thinking of buying this DPDT Center Off (DPCO) switch from Radio Shack for $3.69.
http://www.radioshack.com/product/in...ductId=2062518
I would replace the Tusk SPDT switch with the DPCO switch from Radio Shack, and wire it in the following manner, as shown in the following thread.
http://www.advrider.com/forums/showthread.php?t=850635
The grip heaters would be wired in series for the "low" setting, which would double the resistance. Since I = E/R, if the resistance doubles as the voltage remains at 12V, the current should be reduced to half. Have I made a mistake in my calculations? I realize the "high" circuit is wired in parallel.
Spud
Here is the one I got...
http://www.autozone.com/autozone/par...ier=69839_0_0_
I also have one of those DPCO switches. Hmmm...
I'm in the middle of installing them and am having an issue with the way I ran the wiring. I have a PM to ThumpnRed. Ah! I've got mail!
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is online now   Reply With Quote
Old 12-28-2012, 10:11 PM   #50704
bwalsh
bwalsh's Avatar
Oddometer: 11,155
I plan to rethink the dash this winter. I want to incorporate a cigarette lighter power outlet and get my indicator lights back in play.
Thanks for the pics! There isn't much room behind the light is there?
I also have a 3000. I run a flex-shaft attachment on mine. I think it makes fine detail work easier.
http://www.dremel.com/en-us/Attachme...spx?pid=225-01
That would be a necessity.
2004 XR650L
Old 12-28-2012, 10:20 PM   #50705
bwalsh
bwalsh's Avatar
Oddometer: 11,155
Originally Posted by mcma111 View Post
Am I going to tell all of you guys ALL of my secrets ???
We'll eventually wear you down.
Nice work Thumpnred!
OK, I just got mine wired up just like you have on the diagram.
The issue I have is...the flasher clicks when the switch is on the "lo" setting and is quiet on the "hi" setting. Shouldn't it be the reverse of what's happening?
Why is that?
2004 XR650L
Old 12-28-2012, 10:27 PM   #50706
Spud Rider
Spud Rider's Avatar
Oddometer: 3,758
Originally Posted by bwalsh View Post
...I also have one of those DPCO switches. Hmmm...
Don't do it. I analyzed the circuits. The DPCO switch circuit consumes about 4.42 watts per grip on the low setting, which is about 1/2 the heat generated by the Tusk setup on low heat, and 1/4 the heat generated by the high setting. Therefore, I won't be using the DPCO switch. I am going to install an electronic relay.
The LED dimmer is very nice, and inexpensive; however, it's just too large for me.
Spud
Old 12-28-2012, 10:30 PM   #50707
Spud Rider
Spud Rider's Avatar
Oddometer: 3,758
...The issue I have is...the flasher clicks when the switch is on the "lo" setting and is quiet on the "hi" setting. Shouldn't it be the reverse of what's happening?
Why is that?
You got it right. The flasher sends power about half the time to the grip heaters when the switch is on the "low" setting. On the "high" setting, the wiring bypasses the flasher and sends full power to the grip heaters.
Spud
Old 12-28-2012, 10:32 PM   #50708
Memnok
Fly high, go far.
Memnok's Avatar
Oddometer: 353
I second that!!! That is a tremendous help.
Why is that?
On high, the grips are getting full power and the blinker relay is not in the circuit. On low power the blinker is in the circuit turning the power on and off to reduce the amount of time the grips are receiving power.
Clint >>> 2007 XR650L <<<
Good government is no substitute for self-government. Mahatma Gandhi
That government is best which governs least, because its people discipline themselves. - Thomas Jefferson
Memnok is offline   Reply With Quote
Old 12-28-2012, 10:33 PM   #50709
bwalsh
bwalsh's Avatar
Oddometer: 11,155
Don't do it.
Thanks! I saw that in your earlier post, right after I posted saying I had one. I won't do it.
Spud
Yeah, I know what you mean regarding the size...any size is too big for the cockpit on an XR. You have to have a good imagination to find mounting spots.
I thought you had bolted the switch. I forgot to look when you posted that pic earlier.
2004 XR650L
Old 12-28-2012, 10:35 PM   #50710
Memnok
Fly high, go far.
Memnok's Avatar
Oddometer: 353
Actually, Thumpnred, looking at your diagram, shouldn't the blinker relay be on the other side of the switch? Between the low pole and the blue line?
Old 12-28-2012, 10:38 PM   #50711
Spud Rider
Spud Rider's Avatar
Oddometer: 3,758
Red got it right. When the top of the switch rotates to one side, the contacts in the body of the switch connect on the opposite side.
Spud
Old 12-28-2012, 10:42 PM   #50712
bwalsh
bwalsh's Avatar
Oddometer: 11,155
I told ThumpnRed I was electrically illiterate. I was right!
So the resistor/flasher is for the low setting? If so then why is it on the wire that goes to the "hi" side of the switch? That's what is throwing me for a loop.
Thanks Guys! I couldn't have re-engineered these grip heaters without you!
Anyway...I got heated grips!!!
2004 XR650L
Old 12-28-2012, 10:52 PM   #50713
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 725
Thank you, Red. I looked online at AutoZone and O'Reilly, but I can't find that flasher anywhere. Do you remember approximately how much it cost?
Spud
I bought one of those for my bicycle to put turn signals on it to "dumb it down" for the masses around me, the two prong relay cost $7.99 at the time, the closest I could find now online is: http://www.oreillyauto.com/site/c/se...0381/C0335.oap
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
The multi-quote function is your friend.
My motorcycle is 5000 times faster then a centipede!
KyoXR is offline   Reply With Quote
Old 12-28-2012, 10:52 PM   #50714
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,512
The switch is confusing. Look at the pole that the bottom of the toggle points to.
Old 12-28-2012, 10:54 PM   #50715
bwalsh
bwalsh's Avatar
Oddometer: 11,155
Spud
OK, I just figured it out. Duh!
That flasher I posted is also carried by Advance auto for the same price, $6.99.
2004 XR650L
Times are GMT -7.   It's 12:04 PM.
