Old 12-28-2012, 04:34 PM   #1
Nuclear biker OP
Nuclear biker's Avatar
Oddometer: 18
Re-keying the BMW adventure case
I just got a top case from my father off his old bike. The problem is the lock for the bracket is locked closed. Can I get it re-keyed to my bike at the dealer if its locked.
Thank you,
Nuclear biker is offline   Reply With Quote
Old 12-28-2012, 05:41 PM   #2
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Probably any good locksmith could do it.
My local locksmith picked and keyed my Studebaker ignition cylinder and made me 2 new keys for it for $25.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 12-28-2012, 07:42 PM   #3
Brit in SF
Brit in SF's Avatar
Oddometer: 204
Try the dealer. My local dealer rekeyed the top box I bought from an inmate for free.
My lock was unlocked which probably made it easier. It can't hurt to ask.
BMW R1200 GS Adv 30 Year SE
Brit in SF is offline   Reply With Quote
Old 12-28-2012, 09:53 PM   #4
Multiplicity
Oddometer: 172
You can buy the kit and DIY, or pay the dealer. I had a problem when keying my new cases and had to remove the lock on my top case. It has a spring loaded tab you need to depress to allow the cylinder to slide out. It's not easy, but you can do it if you have a small pick set. The kit only has 3 code inserts, so it's a simple job after you get the code sorted.
Multiplicity is offline   Reply With Quote
Times are GMT -7.   It's 01:10 AM.
