12-28-2012, 11:23 AM
#61 | |
because I can
Oddometer: 6,213
12-28-2012, 12:21 PM
#62 |
Oddometer: 137
Can anyone comment on this batch of 336 cams, on sale right now at Max BMW:
http://www.maxbmwmotorcycles.com/fic...3&rnd=08102012 from the parts fiche, "30.00% OFF-Getting rid of inventory!"
2004 BMW R1100S / 2003 Ducati M800Sie / 1986 R80 G/S / 1981 BMW R100RS (Sold ) / 1977 Kawasaki KE100 (1st Bike |
12-28-2012, 12:45 PM
#63 | |
because I can
Oddometer: 6,213
12-28-2012, 07:39 PM
#64 | |
R90SS/6
Oddometer: 155
buy one and measure
I'll buy 2! |
12-28-2012, 07:58 PM
#65 |
Oddometer: 137
I have a lathe, all the right measuring tools and instruments, and I'm ready to plunk down my card to buy one. Referring to this sketch, at the peak of each lobe, we're looking for taper from back to front across the face, right?
2004 BMW R1100S / 2003 Ducati M800Sie / 1986 R80 G/S / 1981 BMW R100RS (Sold ) / 1977 Kawasaki KE100 (1st Bike mendoje screwed with this post 12-28-2012 at 09:02 PM Reason: added pic |
12-28-2012, 10:39 PM
#66 |
Oddometer: 952
12-28-2012, 11:32 PM
#67 |
because I can
Oddometer: 6,213
Better yet, ask the parts guy to get out his plastic parts guy caliper and measure it for you. There are at least two tapered lobes there to compare the tapered lobes and the flat lobes if they have any.
#68 |
because I can
Oddometer: 6,213
12-29-2012, 12:06 AM
#69 |
because I can
Oddometer: 6,213
What's retail now? That can't be much over dealer? When they are ground right they are awesome cams as you now know too! They do it all. Especially upper midrange! Right where I ride all the time. Man I am loving my new setup with my old 70k miles on it now 336!
12-29-2012, 01:14 PM
#70 |
Oddometer: 736
I bought a bean can 336 about 4 years ago, but ended up using a pre bean motor so had the local cam expert convert a 308 to 336, which included making a set of 'masters'
More recently got him to convert a R65 cam to 336 as well for a 500 race motor project.....and yes the phasing was taken into account.... ![]() You can see where material has been added. Out of curiosity I put the vernier across the lobes and yes there is a taper. The 336 in the R90 runs ok but I have not been able to get a good idle, not really an issue in a race bike, pulls really well up to the rev limiters cut out 7500. I used to use the tach but they read about 500 rpm high from memory, with the Ignitech you can read the RPM off the laptop during set up. |
12-29-2012, 01:48 PM
#71 | |
because I can
Oddometer: 6,213
Why set your rev limiter so low? Piston speed is super safe until you are real close to 9000rpm. If your valves aren't floating and they shouldn't be with titanium spring retainers, rev it higher for more power. If it isn't making more power up there you still might be able to use the over rev to your advantage at some tracks. 336's have good usable over rev. |
12-29-2012, 02:19 PM
#72 | |
Oddometer: 736
The motor was put together on a real low budget just to see if riding on the track was for me, the valve train is stock at this stage. Been looking at SS Manley valves ( lighter), titanium retainers and beehive springs.Another 1000 rpm would sure be useful, would be able to stay in front of the featherbed Dominator 850 after passing him on the corner under brakes.... Had a good season with the old girl, surprised quite a few, expecially the Harleys. |
12-30-2012, 06:07 AM
#73 | |
Oddometer: 11
New 336° cam from BMW
Daniel |
12-30-2012, 10:13 AM
#74 | |
Oddometer: 736
So its really going to be an R45 motor with R65 heads, 336 cam and a light valve train. I have not heard of anyone doing this....probably good reason. Cylinder wall needs a smidgen taken out but shrouding could be an issue....as might the 36mm inlet ports.....its suck it and see territory. For a r50/5 the 308 cam would probably work better .....once again pure supposition. |
12-30-2012, 10:23 AM
#75 |
Oddometer: 3,476
To me, a 1070 kit with Mikunis would look [sort of] the same as an R50. Close enough!
