Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 12-27-2012, 05:56 PM   #331
DropinParts
Ducatista
DropinParts's Avatar
Oddometer: 97
Originally Posted by yukonjon View Post
So from where the tank meets the seat to the crease where the seat slants up is about 15 inches. See pics. This is without following the seat contour and just straight across. If I measure to the upper portion of the "backrest area" it is about 17 inches. So a 2 inch further back slant for the upper butt lower back area. Hope this helps.
Is the front of the Corbin seat at the same location as the stock seat? That's why I mentioned a fixed point on the tank. It appears that the front of the Corbin goes higher up the tank than the stock seat, but I may be wrong.
There are two roads in life, the twisty one is vastly more fun.
DropinParts is offline   Reply With Quote
Old 12-27-2012, 06:31 PM   #332
yukonjon
yukonjon's Avatar
Oddometer: 156
That's what I get for reading too quick. I think the seats are close to the same spot but just in case I did it again. From the rear edge of gas cap where paint starts, to the lower edge of back rest area is about 25.5 inches.
yukonjon is offline   Reply With Quote
Old 12-28-2012, 09:35 AM   #333
JWalton
How do I wheelie?
JWalton's Avatar
Oddometer: 22
LED Lights for our Tigers?
I scrubbed the tiger threads & didn't see anything other than Pilot3's tail light mod... Anyone else play around with LED options for the signal lights? My wife who followed me the other day said my OEM's were weak in direct sunlight and advocated an immediate upgrade for the sake of safety!! So, any thoughts? Google says there are a couple of options:
Touratech rings the bell with their $$$$ version (175/pr).
Then there is this $$ version from Weizer (59/pr).
Since it is a matter of "safety" , & fully condoned spending from Mrs. W, I'm looking for something to compliment Pilot3's tail-light add-on.
JWalton is offline   Reply With Quote
Old 12-28-2012, 10:20 AM   #334
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,712
I've yet to find an LED signal solution that's as bright as an OEM incandescent bulb. I do have LED signals similar to your first option on my Husky, but it's done for the sake of smaller size, rather than visibility.
If you get some signals that are quite bright, I'd like to know about them!
Old 12-28-2012, 10:26 AM   #335
some call me...tim
some call me...tim's Avatar
Oddometer: 282
Rizomas are the ticket if you're looking for a bright LED solution. Like all things MC related, the good stuff ain't cheap. http://www.pjsparts.com/catalog/inde...d7e13277d27c88
some call me...tim is offline   Reply With Quote
Old 12-28-2012, 10:58 AM   #336
JWalton
How do I wheelie?
JWalton's Avatar
Oddometer: 22
Rizoma Signals...Hmmm
Thanks for the lead Tim... They're 50/each, but still cheaper than the Touratech's. I talked to a sales [] and he's says the fitment is a piece of cake... Like he'd say anything contrary. I'm headed to the shop to ask the guys about fitment/wattage/amperage concerns.
Old 12-28-2012, 11:11 AM   #337
some call me...tim
Oddometer: 282
I don't think there should be any fitment issues, and I wouldn't think there'd be any wattage/amperage issues either. The one thing that would be an issue, that's the same with all LEDs, is that you'll get the fast blink rate since they have a much lower resistance. The solution is either to solder in some resistors on the circuit, or get a new flasher relay. I know the relays are easily found for Japanese bikes for ~$20 on ebay. I don't know if it'd be any different for the Triumphs.
Or of course, there's option 3 of just letting it blink fast.
Old 12-28-2012, 01:25 PM   #338
backwoodsKLR
backwoodsKLR's Avatar
Oddometer: 9,739
Anyone tried the OEM LED turn signal option? They are $65.93 on BB. (I guess that is for one complete assembly.)
2013 Tiger 800XC
Explore: Backwoods, MS
MS Tag-O-Rama Map / Jackson, MS Local Tag-O-Rama Map
backwoodsKLR is offline   Reply With Quote
Old 12-28-2012, 02:09 PM   #339
DropinParts
Ducatista
Oddometer: 97
I just measured my stock seat and its 24.5 inches between the same two points. Since it then slants back from the lowest point, it would probably be more comfortable.
Thanks for doing that for me.
Old 12-28-2012, 05:23 PM   #340
JWalton
How do I wheelie?
JWalton's Avatar
Oddometer: 22
Couldn't find them.. do you have a link backwoods? Nice bike by the way
Old 12-29-2012, 11:33 AM   #341
backwoodsKLR
Oddometer: 9,739
Thanks... LINKY (hope it works)
BB part number: 29374291
2013 Tiger 800XC
Old 12-30-2012, 07:33 AM   #342
backwoodsKLR
Oddometer: 9,739
Got my 15T sprocket installed. Did a short test run and love it!!!!
5300 RPM = 70MPH
6000 RPM = 78MPH
Approximate indicated on dash readings....
Lofted front wheel. Accelerated from 60 - 90 to pass a slow car in an instant!!!!
Can't wait for more extensive testing!!!!! .
2013 Tiger 800XC
Old 12-30-2012, 08:16 AM   #343
JWalton
How do I wheelie?
JWalton's Avatar
Oddometer: 22
Signals & Sprockets
Ordered Rizoma LED signals. I'll post some before/after pic's when they get here.
Got my 15T sprocket installed....Lofted front wheel.
KLR - I've seen/read several posts about the sprocket mod. Did you do it for more low end torque? I noticed that its hard to crawl along in 1st without lots of clutch... Lofted front wheel?
(sorry for the nOOb questions!)
-JW
Mean Green Machine '13 Tiger 800XC
Old 12-30-2012, 09:53 AM   #344
backwoodsKLR
Oddometer: 9,739
-JW
I was running some single track and had to clutch a lot. In a parking lot, idle speed is 10-12MPH with stock gearing. A bit too fast for picking your way in rough terrain.
sent from my Galaxy S3 using Tapatalk 2
2013 Tiger 800XC
Old 12-30-2012, 11:09 AM   #345
McKay
McKay's Avatar
Oddometer: 966
Who did you order from?
Jeff
McKay is offline   Reply With Quote
Times are GMT -7.   It's 11:55 PM.
