Old 12-29-2012, 01:20 PM   #1
docgonzo OP
Old Gadfly
docgonzo's Avatar
Location: within 20 miles of the Center of the Universe
Oddometer: 14,064
"If it ain't broke".... 2002 1150GS
My 1150 GS now has 89,000 local miles on it. Commuting and day rides for 10 years. No road trips of any merit, due to work and family stuff. I ride the bike hard. In all kinds of weather.
Question: the bike has never run better. Starts easily, idles nicely, accelerates like a scalded cat. But I haven't had the throttle bodies "synched" recently, or adjusted the valves. Oil changes and fluids changed regularly. Keep good rubber on the big yellow pig. Rub off the dirt when required.
So, if it ain't broke, does that mean the throttle bodies are synched and the valves are fine?
My feeling is that after all the regular maintainence valve adjustments over the years, the valves are now "stretched" about as far as the metal will go, and don't need as frequent adjustment. Foolish self delusion?
later, *
docgonzo is offline   Reply With Quote
Old 12-29-2012, 02:37 PM   #2
Hay Ewe
Just a Wannabe
Hay Ewe's Avatar
Oddometer: 3,000
It doesnt hurt to check
The airplane you get on, would it be ok if they hadn't done a check because it was running just fine?
Hay Ewe
Moments before you die, your life will flash before your eyes - make sure the film is worth watching - my Grandad
Don't go gentle into the long final good night from which no man has yet returned.
Moose Antlers need love too.
Hay Ewe is offline   Reply With Quote
Old 12-29-2012, 03:16 PM   #3
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,898
I stretched valve clearance checks out to every 12k miles quite some time ago (114k miles on the bike now), and rarely find any of them needing even minor adjustment but I still check 'em just to be sure. Since TB synch is all about getting the engine as smooth (balanced) as possible, I only do that when I can feel that it needs done (once in the last 45k miles or so).
Current: 2014 R1200GSW & 2007 DR650
jdub is offline   Reply With Quote
Old 12-29-2012, 03:51 PM   #4
Multiplicity
Oddometer: 172
Throttle cables will stretch less and less and that could be why the TB's are still close.
Multiplicity is offline   Reply With Quote
Old 12-29-2012, 03:54 PM   #5
The Walrus
Gone and back again.
The Walrus's Avatar
Oddometer: 9,038
........yup........
Everbody's preachin' at me that we all wanna git to heaven, trouble is, nobody wants to die to git there.-BB King
Reality is what does not go away when you stop believing in it. -Philip K Dick
I wanna be skinny, but my ass is too big. - Charles Barkley
When choosing between two evils, I always like to try the one I've never tried before. - Mae West
Experience is what keeps a man who makes the same mistake twice from admitting it the third time around.
The Walrus is offline   Reply With Quote
Old 12-29-2012, 04:13 PM   #6
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,796
Could go either way.
I just tore into my 1150 for a new clutch and a leaking right head gasket. I figured while I've got one head off, I'll pull the other and clean the carbon off that one too.
I'm glad I did, I found a valve that was burned and not seating properly.
Prussian Blue tells the story:
The valve is toasted and is only a matter of time before it left me stranded somewhere.
This GS has 103k miles.
If you're all about the destination, take a fucking flight. - Frank Turner
Got brap, and twice as much fuel as you. - Akarob
Twilight Error is offline   Reply With Quote
Old 12-29-2012, 11:20 PM   #7
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,198
If you plan to keep the bike get both heads done. New guides, new exhaust valves, grind/lap intakes, new seals.
Good for another 103k
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 12-30-2012, 01:47 AM   #8
Twilight Error
Oddometer: 22,796
I'm going to buy a set of heads from the Beemer Boneyard and have them redone. Time and budget are forcing me to half-ass the repair now, but I do plan on keeping it for another 100k miles.
Old 12-30-2012, 04:11 AM   #9
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 5,017
I'd say you can double the valve adjustment interval if your personally familiar with how much they have needed adjustment in the past. I'm assuming your letting the shop do the deed so unfortunately, the adjustment is only as good as the last guy set them. I wouldn't let a shop work on my bike for free, but that's just me.
bemiiten is online now   Reply With Quote
Old 12-30-2012, 04:37 AM   #10
Jim Moore
Jim Moore's Avatar
Oddometer: 14,585
TE, what are you seeing there that suggests a burnt valve? I know nothing about the insides of engines.
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is offline   Reply With Quote
Old 12-30-2012, 07:40 AM   #11
Multiplicity
Oddometer: 172
If a valve gets tight it can burn. Time and miles are why this one is in this condition, IMO.
Old 12-30-2012, 08:14 AM   #12
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,820
Your photos suggest that there was wet carbon present in the combustion chambers. This could be due to several factors. How do the piston tops look? Same wet carbon? If so, I would continue to look for a source for oil in the combustion chambers.
New exhaust valves and stem seals with a valve job according to the specs in the BMW REProm. One exhaust seat looks like it has a nick in it. Take the heads to an expert who knows how to shrink new valve seats into the alloy heads and perform the multi angle valve seat grinding.
def is offline   Reply With Quote
Old 12-30-2012, 09:05 AM   #13
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,198
My photos? I did not post any.
Old 12-30-2012, 01:50 PM   #14
docgonzo OP
Old Gadfly
docgonzo's Avatar
Oddometer: 14,064
Thanks everyone for your opinions. I'll probably wait with throttle body synching for a while, since the bike is idling and running nicely. I'll check the valves in the springtime to make sure they are not out of whack. I'm gonna bet they are pretty much in spec., as they were the last time they were checked. These old GSs, once broken in, seem to be pretty tough machines. Took the old yellow pig about 25,000 miles before it stopped burning oil, so I guess they design them to break in slowly, but last longer then most bikes. Stock seat became comfortable about the same time!
later, *
Old 12-30-2012, 03:22 PM   #15
rdwalker
Oddometer: 2,545
... The valve is toasted and is only a matter of time before it left me stranded somewhere.
I think that's crap. Barely 100k on the clock and you already have engine trouble? I'd go complain to the dealer.
Sorry... Could not resist...
However: would that type of failure show up on an external check? That is, with routine maintenance, such as valve-clearance adjustment?
Or, if you did not coincidentally pull the head, would you get a nasty surprise without any advance warning?
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker is online now   Reply With Quote
Times are GMT -7.   It's 07:11 AM.
