Old 12-23-2012, 04:29 PM   #5956
larry31
Back Roads Explorer
larry31's Avatar
Oddometer: 174
Seasons Greetings
Here's wishing you all Seasons Greetings. What ever your traditions are for this time of year.
All ride safe and the best for the New Year.
Larry31
larry31 is offline   Reply With Quote
Old 12-24-2012, 03:20 AM   #5957
Jacl-Kampuchea
Booze Merchant
Jacl-Kampuchea's Avatar
Oddometer: 561
Whaddya Know!
My engine is fine
Valves perfect, piston and rings perfect and cylinder completely unscored. Looks like brand new, in fact
Can anybody guess what the problem was?
I'll post a video of the head, piston and the problem item that made me think the engine had gone "boom".
Merry whatever it is to you all, by the way.
CambodiaYeah!
Jacl-Kampuchea is offline   Reply With Quote
Old 12-25-2012, 03:37 AM   #5958
Jacl-Kampuchea
Booze Merchant
Oddometer: 561
Perfect!
Starter Clutch shat itself, making the horrible sounds and I feared the worst.
CambodiaYeah!
Old 12-25-2012, 10:43 PM   #5959
scrambler66
scrambler66's Avatar
Oddometer: 137
NX250 starter motor
Originally Posted by Jacl-Kampuchea View Post
Whaddya Know!
My engine is fine
Good to hear that your Nixie is all right. Every report of destroyed engines challenges my strong belief, that the NX250 is indestructible (well, some guys are able to manage even this).
Problemes with the starter motor are unusual, too (let’s say it was the stupid previous owner fault) - I know a few cases with bad roller bearings of the starter motor. What part exactly screwed up? Pictures would be good
btw. Honda is not selling the roller bearings separately, so you would have to buy a new starter motor
scrambler66 screwed with this post 12-25-2012 at 10:50 PM
scrambler66 is offline   Reply With Quote
Old 12-26-2012, 03:18 AM   #5960
Jacl-Kampuchea
Booze Merchant
Oddometer: 561
Piston looking good.
My mechanic gave the cylinder a tiny hone, here it is before cleaning after the hone:
The head: Valves in good shape. Some ever so light scoring on cam journals, but not bad enough to worry about:
Below is the part that failed, post repair.
At some point in the bike's life the bearings on the top had failed and Khmer mechanics had welded on a similar item from a car - a common fix here.
This type of repair never lasts too long because the car item is not designed for motorcycle engines compression. Also, it was missing two thrust washers which can be seen in the picture below of the repaired item and the old, busted roller bearing set from the car.
Should b back on the road tomorrow running as well as ever.
CambodiaYeah!
Old 12-26-2012, 05:36 AM   #5961
Orkodelamuerte
Orkodelamuerte's Avatar
Oddometer: 78
Originally Posted by Honda Scoot View Post
A timely question as we just completely went through a 1988 NX125. Still not quite done, as it is missing the front sprocket cover and parts that were missed from the first order to Service Honda.
http://advrider.com/forums/showthrea...731237&page=18
The NX250 and NX125 are VERY different bikes.
Items that are shared:
Front and rear reflectors - I still need the fronts and the little stems to mount them
Tail light lens
Front Turn Signals - The rears have looooong mounting stems
Mirrors - NX125s are cheaper as the rubber vibration mounts are not included
Handle Bars are both 7/8" diameter
Not much is the same.
This is what you are looking for: NX 150 - Made in Brazil.. it shares almost everything with the NX 125 except for the cylinder and the rear fender stuff..
http://www.youtube.com/watch?v=nL5983DBHTY
Orkodelamuerte screwed with this post 12-26-2012 at 05:43 AM
Orkodelamuerte is offline   Reply With Quote
Old 12-26-2012, 10:06 PM   #5962
scrambler66
Oddometer: 137
Xre300
Talking of Brazil – have you ever considered parts from the XRE300? The engine is almost identical to the NX250 and it’s also manufactured in Brazil, so parts may be easier to get in Argentina . You would need a parts list of the XRE to check which engine parts actually fit.
Old 12-27-2012, 05:55 AM   #5963
Orkodelamuerte
Oddometer: 78
This is what I use for my NX 250 in argentina:
XR 250 - Tornado
CBX 250 - Twister:
Old 12-28-2012, 02:36 PM   #5964
Dirtstar1
Human torpedo
Oddometer: 102
Nx650 dominator for sale in San Diego
Hi guys. I know this isn't a 250, but just in case one of you wanted a bigger bike to complete your nx collection, where it is!
http://sandiego.craigslist.org/ssd/mcy/3507092461.html
Photobucket Pictures, Images and Photos
Dirtstar1 is offline   Reply With Quote
Old 12-28-2012, 10:06 PM   #5965
scrambler66
Oddometer: 137
MSR Footpegs with Offset
Originally Posted by Dirtstar1 View Post
Very nice and clean Dommie, I especially like the XR600 stainless steel manifolds
@ all
As I learned from this forum, KLR footpegs should fit our Nixies - MSR footpegs are available with 13mm offset for enhanced shifter area. Which would be neat for anyone with a shoe size larger than 7
Unfortunately, for a try those pegs are fairly expensive if ordered from Europe, so I was wondering if anybody already tried them – or would like to
Old 12-28-2012, 10:52 PM   #5966
Dirtstar1
Human torpedo
Oddometer: 102
@scrambler66, do you think that honda grabbed that header off the shelf for that? Under the bike it's duals all the way back. Stock un altered. Thanks for the complement. As far as foot pegs are concerned, I used crf 50 pegs. They cost about $35 on eBay in any color and near any alloy.
Old 12-29-2012, 02:52 AM   #5967
Jacl-Kampuchea
Booze Merchant
Oddometer: 561
Bugger,
Decided to throw a new camchain into the bike while it was open, tensioner was fine.
Got the head back on and we went to adjust the valves to discover one exhaust valve was beyond adjustment. It was also Taiwanese shit and not OEM.
Head back off, new OEM oil seals x 4, Hot Cam shims , 2 OEM Exhaust valves and a big clean up or the inlet valves. This crap's getting expensive
CambodiaYeah!
Old 12-29-2012, 10:27 AM   #5968
Orkodelamuerte
Oddometer: 78
my guess, faulty CDI
This is what happens... Now that I finally got my bike back and runing, I'm having a new issue.
As soon as the engine gets hot enough to start the fan, I get short on spark, The engine will start failing and would not cease until I let it cool down a little.. If I go quiet and below 5k revs, then nothing but perfection happens.
Another thing that I noticed is that when that happens or is about to happen (the spark issue) the tach will go crazy, showing 3k revs when Im pretty sure I'm going 1.5k.. but dont know if related...
My final thought was that my CDI is bad... what do u say?
pd.: engine and carb are more than perfect... so dont focus on that.. My alternator has been repaired 1 month ago, and regulator is brand new.
Old 12-29-2012, 01:24 PM   #5969
Jacl-Kampuchea
Booze Merchant
Oddometer: 561
Does not not sound like CDI to me, though it's possible.
Certain that it's losing spark? Or is that just your impression?
CambodiaYeah!
Old 12-29-2012, 04:55 PM   #5970
Orkodelamuerte
Oddometer: 78
Yep. Out of nowhere, I get gas, air but no spark. I get ramdom explotions, and if i quit forcing the throttle, engine will stop. same as when you run out of gas.
It feels as if when engine is hot, the CDI pulse will not catch up with the revs, so it fails to get a continuous spark..
Times are GMT -7.   It's 08:12 PM.
