Old 12-20-2012, 09:09 AM   #1
coconuttele OP
Oddometer: 78
KTM Cluster
Anyone out there have an "extra" 07 990 instrument cluster laying around another could borrow? Still no speed or odometer reading. Have chased wires, swapped sensors, tested and retested everything. Everything else in the cluster works???? Anyone have ideas out there?
coconuttele is offline   Reply With Quote
Old 12-20-2012, 02:04 PM   #2
Peanuts
Peanuts's Avatar
Oddometer: 1,666
Connect a thin wire to the red/black wire, tap it repeatedly to ground (brown wire), this gives a pulse similar to the speedo sensor, your speedo should read a speed while you keep tapping the wire.
Peanuts is offline   Reply With Quote
Old 12-20-2012, 05:04 PM   #3
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
If the test above shows the speedo works.
Just a stupid suggestion - Magnet still in the disk or changed disks? You can test it by using a multi-meter and checking the contacts close when the wheel spins.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 12-21-2012, 04:54 AM   #4
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,146
did you happen to have changed toe brake disk bolts with stainless or something? it will ONLY work with the mild steel, preferrable original, disk bolts.
Or are we talking abs here? did you disable abs? then the speedo is out too.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is online now   Reply With Quote
Old 12-21-2012, 09:43 AM   #5
coconuttele OP
Oddometer: 78
so im seeing a few red/blk wires under here, which one am I suppose to be testing? The sensor wire is black/white or white.
Old 12-21-2012, 11:10 AM   #6
Peanuts
Peanuts's Avatar
Oddometer: 1,666
Looking at the wiring diagram, its actually orange/black.
It is in the speedo connector, pull the rubber cover back, its right there in the middle of the top row.
poke a narrow wire in there, then tap the other end of the wire on the aluminium front subframe or any brown wire.
Old 12-22-2012, 06:36 AM   #7
coconuttele OP
Oddometer: 78
Put a wire on the org/blk wire then to the frame. The speedo jumps around showing a varity of numbers. So now what is the next step of repair? Thanks for the help.
Old 12-22-2012, 07:58 AM   #8
Peanuts
Peanuts's Avatar
Oddometer: 1,666
Does your 990 have ABS? Is the ABS working? Try locking the rear brake, its safest ;)
Old 12-22-2012, 08:53 AM   #9
coconuttele OP
Oddometer: 78
ABS is working, both front and rear, Even swaped sensors to be sure. My ABS shut off in center of the dash lights up, but I cannot shut down the system there by holding in the button.
Old 12-23-2012, 02:16 PM   #10
coconuttele OP
Oddometer: 78
any ideas on this out there?
Old 12-24-2012, 04:30 AM   #11
Peanuts
Peanuts's Avatar
Oddometer: 1,666
I am pretty sure that ABS models get their speedo signal from the orange/black wire on the ABS unit. Try the same wire grounding tapping trick there. If the speedo indicates, I guess you need to borrow an ABS unit...
Old 12-28-2012, 09:33 AM   #12
DeepSea
electronically challenged
DeepSea's Avatar
Oddometer: 242
Coconut, I had a very similar problem. While riding my luggage key got jammed into the ABS disable button. It destroyed the button.
ABS DID work but speedo and ODO did not.
I also could not disable the ABS (with the button).
http://advrider.com/forums/showthread.php?t=824402
If my memory is correct, part was $37. Good luck. Hope it's as simple as the button swap out.
CDR 2012 ------ Too Lazy to write my own RR
Commercial Diving flashlight and tools
It's not me. My bike is Narcoleptic.
Research is what I'm doing, when I don't know what I'm doing.
DeepSea is offline   Reply With Quote
Old 12-30-2012, 03:48 AM   #13
coconuttele OP
Oddometer: 78
Is there a way to jump the wires at the button to get any test result there? Looking at the button itself, it is broken on one corner, probably got some moisture in there at some point and shorted the whole system out. Will try to order a new one $40 is a better test, rather than $400 for a new cluster.
Old 12-30-2012, 04:58 AM   #14
Peanuts
Peanuts's Avatar
Oddometer: 1,666
That button is quite complex, lots of wires go to it!
Old 12-30-2012, 03:47 PM   #15
pebble35
pebble35's Avatar
Oddometer: 1,546
Daft question but have you tried swapping your cluster onto another bike ? Would identify if it was a cluster problem or a wiring/sensor issue.
If you are stuck I will have a speedo cluster for sale in the new year - complete (apart from clear plastic cover) and working. About 5,000 miles from memory. Will want about 125 plus postage (they are about 380 new over here).
Sent from my iPad using Tapatalk HD
Proud to be supporting Pyndon
www.lyndonposkittracing.com
www.bikersjersey.com for all your KTM parts
A 2,400 KM ride around Egypt by Scooter - ride report here
pebble35 is offline   Reply With Quote
Times are GMT -7.   It's 04:11 AM.
