12-30-2012, 06:31 PM
#46 | |
Oddometer: 1,215
In the deep sand the front end wanted to spear off sideways. I tried riding it fast, dirtbike style but that nearly ended in tears so we just had to slog it out slowly. The soft front forks dont help as when the front would grab and want to go sideways it would just compress the forks and tuck the front under. I have never seen Chris ride on gravel before but if its anything like on a dirt bike it would be spectacular. If he has another school we should come up and see if he can teach us to ride sand 2up better. Not sure if he has done any 2 up adv riding.? We tried both standing a couple of times (on the Beemer ), weird. I would need to shift the controls around a bit as its set up for sit down riding. And Dawn needs something around my waist to hang on to.
12-30-2012, 08:11 PM
#47 |
Yeah, right!
Oddometer: 4,282
Dawn is amazing, the stuff you two do together and she seems to be enjoying herself. Has she never wanted to ride herself? We'll be heading off tomorrow, starting with the Off-limits ride in Waiouru. It's amazing how much stuff we can pack on Gerda's bike, all I have to carry is one bag.
R1150GS R80GS Basic __________________ Kokopelli screwed with this post 12-30-2012 at 08:23 PM |
12-30-2012, 08:46 PM
#48 | |
Oddometer: 1,215
Travelling light is good ! Give it to someone else to carry ![]() That ride sounded good. I would like to explore that area myself, but we are trying to get some things done around the house that I have been putting off for a long time ![]() Enjoy the ride and do a report for us. |
01-01-2013, 12:16 PM
#49 | |
Practicing...
Oddometer: 1,444
This is good information - does using these different Swings/FD provide better/longer/higher rear ends?
Seems like swapping front ends gives Airheads always comes with the need to sort out the rear, is there a preferred Oilhead Swing Arm/ Final Drive that gives you the best rear suspension for the effort?(besides weight/disc brake) I've seen the HPN: HPN-Sport: The "light" HPN for the sports rider.With the reinforced BMW GS frame, the BMW R1100GS swingarm and the best accessories parts from Brembo, Marzocchi, WP Suspension, Acerbis and HPN we created a motorcycle with superb handling on- and offroad Among the info: Teleskopic front fork: Marzocchi Magnum, ø50mm, 285 mm travel. Shock absorber: Special built WP Suspension with adjustable compression and rebound damper settings and hydraulic adjustable spring preload Swing arm: BMW R1100GS Series ![]() Quote:
"And if we have food and covering, with these we shall be content." |
01-01-2013, 12:28 PM
#50 |
Practicing...
Oddometer: 1,444
And this one too:
![]() HPN-Rallyesport: The "long-distance" HPN for the adventurer. With the reinforced BMW GS frame, the BMW R1100GS swingarm. Teleskopic front fork: Marzocchi Magnum, ø50mm, 285 mm travel, or WP Suspension Upside-Down 295 mm travel Shock absorber: Special built WP Suspension with adjustable compression and rebound damper settings and hydraulic adjustable spring preload Swing arm: BMW R1100GS serie or welded aluminum construction, 245 mm travel
01-02-2013, 04:34 AM
#51 |
Gerd
Oddometer: 185
All weights can be found here (and elsewhere): http://www.bmwetk.info/parts-catalog/flt/MS/BMW/VT/P.
The difference between theory and practice practically is larger than the difference between theory and practice theoretically. BMW Airhead -> www.zeebulon.de/bmw BMW R1100GS -> www.zeebulon.de/R1100GS XT 500 -> www.zeebulon.de/xt |
01-02-2013, 09:45 PM
#52 |
Oddometer: 1,215
I drained the remaing fuel from my GS tank this arvo. It weighs 6.2kg. As a comparison the Touratech site lists the 43litre tank as 7.6kg package weight. Not sure if that is boxed up but either way only 1.4kg heavier.
Anyone have an empty one to weigh ? How about the 19 litre tank ? |
01-03-2013, 12:17 AM
#53 |
In need of repair
Oddometer: 1,459
The important thing with the 43l tank is it gets the weight below the spine of the bike, so regardless of actual weight, it feels lighter (assuming the same fuel load between tanks).
You'd also need to include the fittings for the big tank (two on the front of the frame & one at the rear, & the rubber damper mod frame). |
01-03-2013, 01:20 AM
#54 | |
Oddometer: 1,215
I would assume the Touratech weight would include the brackets as its the shipping weight. Do you get the same steering lock with the 43l tank and USD as stock tank and forks ? |
01-03-2013, 01:29 AM
#55 | |
Chronic Noob
Oddometer: 2,306
If the Earth is flat why are my tyres round? |
01-03-2013, 07:07 AM
#56 |
More tacos than you
Oddometer: 5,198
It actually gives you a bit more clearance than the stock tanks.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
01-04-2013, 08:53 PM
#57 |
Yeah, right!
Oddometer: 4,282
The ride was awesome. I am still at National Park, so no photos yet (watch out on McCardigan's thread). I really love that front suspension. It took some really big hits and some jumps (well, not huge ones) in it's stride, never once got close to bottoming out. The scenery was stunning and this ride is right up there with the best I've done, for a very reasonable price.
I can now confidently run my airhead at high 3rd gear speeds on deep loose gravel/sand, let's call it a river bed. Tank tracks with with wash outs and ruts, were soaked up really well. My riding definitely went up a notch and should now be close to average. If I could sort out that slight stall off idle, I would be a happy man. I am also really liking those new Husqvarnas (BMW is easier to spell, that's why I am riding one, or two), that could be a nice commuter with adventure riding duties (checking lotto ticket, again).
R1150GS R80GS Basic __________________ |
