Old 12-30-2012, 09:26 PM   #1021
SansSand
Dirty Smile
SansSand's Avatar
Oddometer: 35
Best hand guards for 2012 f650
What is the best hand guards for 2012 f650 and a person who will most likely fall a lot...on rocks
Антивирус Русский медведь
SansSand is offline   Reply With Quote
Old 12-30-2012, 09:43 PM   #1022
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 574
I have bounced my barkbusters off of hundreds of rocks, LOTS of hard drops.
My wife bent her Bars before she bent the barkbusters too bad.
I have had to take them off a couple times and straingeten them out with a big hammer.
I have talked to sombody who aledgedly broke a set of barkbusters, but I have beat the tar out of mine.
If I were to get another pair, I would get Highway Dirtbikes, aka HDB. They are built wayyy tougher than the barkbusters.
My .02
Ryan
XOVERLAND.COM Our vendor thread HERE
Season 1 Done!! HERE 6 Full Episodes Free on our website!!!
If you like it, "Like" us on FaceBook
2010 F800gs (Mine) 2011 F650gs (Wifes)
grndzr0 is offline   Reply With Quote
Old 12-31-2012, 01:07 AM   #1023
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 1,952
Send a message via Skype™ to Loutre
I'd buy the Barkbusters/Storms or the Kobras (from SWM) since they are reinforced and also give you some weatherprotection.
Keep the smile on your face! F800GS - The ORANGE ones are faster!!
An Otter on the road: From Lille to Limoges in 12 Days
An Otter on the road: I'm coming up so you better get this party started!
Loutre is offline   Reply With Quote
Old 12-31-2012, 01:22 AM   #1024
Snowy
Oddometer: 1,116
I had a look at these, they don't appear to be built super strong. Where do they get this extra strength from?
I used some Cycra ones on one of my other bikes and they seem to be built a lot stronger than the Barkbusters. I haven't binned it hard enough to test them yet. But I have destroyed a couple of sets of Barkbusters. Plus about 5 sets of handlebars, on my other bikes.
My trail videos. Yes, I need to learn to edit. Baby steps...
https://www.youtube.com/user/DRMZ650?feature=mhee
Snowy is offline   Reply With Quote
Old 12-31-2012, 09:29 AM   #1025
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 574
It looks like heavier material.... It seems I saw some pictures somewhere of a side by side of the HDB and the barkbusters, and the HDBs were heavier, However, I could be mistaken.
Ryan
Old 12-31-2012, 11:03 AM   #1026
machinebuilder
Oddometer: 691
I think the extra strength comes from the way they bolt to the bar end and then the bar clamp. I've only seen 1 set on a bike and they are beautiful. I thought they're a bit pricier than I wanted to spend.
I have some cheaper ones with an aluminum bar that i made some bar ends so they'd work with the grips. I haven't tweaked the bars yet and the levers are well protected
2009 BMW F800GS NON ABS
the best thing to buy for your bike is gas.....Neduro
Remote is not found on the coffee table.......seen on a T Shirt
machinebuilder is offline   Reply With Quote
Old 12-31-2012, 11:19 AM   #1027
DoWorkSon
Oddometer: 113
Originally Posted by runnin4melife View Post
I suggest using a piece of cut up tubing that you can put between your rim and tire when using irons unless you want to scuff up your rims. This method has worked much better than rim savers for me but it is user dependent I guess. Also talc up your tube. Some people say it doesn't matter but I have had issues in the past. If it is wet out just roll with it until you can do a proper fix.
What does the talc powder do?
DoWorkSon is offline   Reply With Quote
Old 12-31-2012, 11:36 AM   #1028
runnin4melife
Oddometer: 488
Talc acts as a barrier between the tube/tire, aids in reduction of friction and reduced vulcanization of the rubber. A tire/tube combo generates a fair amount of friction when driving and this reduces the chances of a tube failure, and permits the removal of a tube without destroying it. Some people say it doesn't do anything but I have had tubes fixed to the tire when a shop didn't use talc on a tire change.
runnin4melife is offline   Reply With Quote
Old 12-31-2012, 01:18 PM   #1029
JRWooden
Oddometer: 3,438
+100 on the talc!
Some of the inner tubes are slightly tacky out of the box or at best are not slippery....
The talc also helps make sure the inner tube can slide around inside the tire and get "settled" when mounting and inflating the tube ... I strongly recommend it!
Old 01-01-2013, 06:12 AM   #1030
HighFive OP
Bike-aholic
HighFive's Avatar
Oddometer: 2,064
Originally Posted by Vettel View Post
This is a damn good thread and I have read every page. Thank you all.
Glad you've found it helpful.
Once upon a time....not so very long ago, I just needed a few questions answered. Never imagined it would turn into this. I'm still taking notes!
Good stuff,
HF
HighFive is offline   Reply With Quote
Old 01-01-2013, 02:19 PM   #1031
SansSand
Dirty Smile
SansSand's Avatar
Oddometer: 35
Thanks everyone cycra and barkbusters are what I was looking at...seems like my heated grips may cause issues. Will keep you all posted.
Old 01-05-2013, 09:21 AM   #1032
SansSand
Dirty Smile
SansSand's Avatar
Oddometer: 35
Went with storm barkbusters but the SW engine guard
Old 01-15-2013, 05:02 PM   #1033
Scubalong
Scubalong's Avatar
Oddometer: 181
Here is my first dump question on here.....
Why is my temperature gage blinking when it is below 39°F on my 800GS?
As memories serve in the manual it is warning for ICE condition? Correct me if I am wrong
Thanks in advance
ADV Rock
Scubalong is online now   Reply With Quote
Old 01-15-2013, 05:45 PM   #1034
proeasy
Oddometer: 143
Thanks in advance
ADV Rock
Don't have a GS but must be a German thing as my Audi and VW blink on the dash when temp hits 39 deg. Lurking here may pull the trigger on a F800GS.
Paul O
BMW R1100 RT
Husky TE-510
Husky TE-630
Honda XR-400
Specialized Stumpjumper PRO + Stumpjumper Carbon 29'r PRO
proeasy is offline   Reply With Quote
Old 01-15-2013, 08:37 PM   #1035
toowheels
on a mission...
toowheels's Avatar
Oddometer: 837
Thanks in advance
ADV Rock
Yes you are correct that's exactly what it is saying...well actually it's cold and a possibility of ice. Mine flashes at 3*C though and hasn't stopped flashing for a few days now.
Turn the grips up and enjoy the ride!
Dave
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes
& Giant Loop for Canada
www.motooverland.com
toowheels is offline   Reply With Quote
Times are GMT -7.   It's 06:38 PM.
