Old 12-29-2012, 11:15 AM   #1
michnus OP
Lucky bastard
michnus's Avatar
Oddometer: 1,295
Question Xenon in HP2 standard headlight? What is my options?
Hello boys.
I got myself one kick ass good looking HP2 but the headlight beam is piss poor. Has any one fitted a H4 xenon light to the standard headlight, and did it improve the light?
I had a look at some other options but most involve adding an additional light. The way I see it, it's going to break or rattle lose with time and falls. The TT option is stupidly expensive and not an option.
Any advice?
michnus is offline   Reply With Quote
Old 12-29-2012, 02:06 PM   #2
MJS
MJS's Avatar
Oddometer: 1,912
Get the euro lens assembly if you want to stay with the stock light housing. It has better optics than the US version. You could do the HID conversion to that housing also.
The Baja Designs 6" HID Pre Runner light can be installed to the stock mounting points with a bit of work. Lots of light output but you give up hi/low.
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Old 12-29-2012, 02:17 PM   #3
michnus OP
Lucky bastard
michnus's Avatar
Oddometer: 1,295
Thanks MJS, do you have link to the Euro lens setup?
The 6" Baja is too big, I had look at it and do not really like it.
Old 12-29-2012, 04:09 PM   #4
blaster11
Heading North!
blaster11's Avatar
Oddometer: 7,037
My plan is to upgrade to this as well.
http://www.maxbmwmotorcycles.com/fic...I_EURO%20LIGHT
blaster11 is offline   Reply With Quote
Old 12-30-2012, 05:25 AM   #5
GSMarc
GSMarc's Avatar
Oddometer: 1,120
Euro lens is also shit.
I have installed a Xenon in place of the bulb but the target is more to be seen by others durind day than for a good night lighting.
8000 K
I have added a single Touratech Xenon in parallel on high beam, great result.
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc screwed with this post 12-30-2012 at 05:31 AM
GSMarc is offline   Reply With Quote
Old 12-30-2012, 05:29 AM   #6
GSMarc
GSMarc's Avatar
Oddometer: 1,120
Old setting (xenon inside lens) high beam
New setting with parallel TT Xenon high beam
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 12-30-2012, 09:04 AM   #7
MJS
MJS's Avatar
Oddometer: 1,912
8000 K
IMO, You'll get better results with a 4500K or 5000K lamp. Doesn't change the optics but gives better color rendition of the warmer colors.
Old 12-30-2012, 09:22 AM   #8
GSMarc
GSMarc's Avatar
Oddometer: 1,120
you are right but I wanted to be different from BMW and Mercedes Xenon lights when in trafic
Such a 'blue' light catches the eyes immediately
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 12-30-2012, 07:28 PM   #9
oldfool
Oddometer: 614
hp2 headlight
I use the euro glass with a blue bulb and it is way better then stock. Richard
oldfool is offline   Reply With Quote
Old 12-30-2012, 11:11 PM   #10
michnus OP
Lucky bastard
michnus's Avatar
Oddometer: 1,295
thank you Marc for the reply, it seems like a good way to go. I want to try and keep the bike as is, the Baja light is just to big for me.
What other aftermarket xenon's are available other than the TT option? It's hellish expensive that light.
Oldfool, the blue light I have tried and it's still just 55w and not much better, imho.
Old 12-30-2012, 11:22 PM   #11
configurationspace
delooper
configurationspace's Avatar
Oddometer: 9,054
There's plenty of more or less similar aftermarket H4 HID replacement bulb+ballast kits. I went with something very similar to GSMarc's setup, but without the Touratech add-on.
I think my main beam is around 4500k. It lights things up quite well. Not a perfect beam distribution but it's a big improvement over stock. I find the H4 HID kits in the HP2 reflector tends to be a bit uneven, skewed towards focusing the light up high. So you have to adjust the height of the lamp quite carefully for it to be a good fit. Putting a passenger on the back throws most of the light onto oncoming traffic.
I strapped the ballast onto the left side of the fuel tank, just behind the radiator. That seems to cause no electrical problems.
configurationspace is offline   Reply With Quote
Old 12-30-2012, 11:47 PM   #12
GSMarc
GSMarc's Avatar
Oddometer: 1,120
HELLA Ref 1F0 008 390-001
here is the TT one
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 12-30-2012, 11:54 PM   #13
michnus OP
Lucky bastard
michnus's Avatar
Oddometer: 1,295
here is the TT one
thanks Marc.
btw, I was in your valley in Brugge the last couple of days consuming a lot of Zot beers
Old 12-31-2012, 12:16 AM   #14
advNZer?
advNZer?'s Avatar
Oddometer: 2,922
you need a proper HID housing to get the best out of it.Make sure the existing housing is clean(inside and out) and get a PLUS rated H4 bulb is prolly going to be your best bet with the std housing
aka BMWST?
advNZer? is offline   Reply With Quote
Old 12-31-2012, 12:25 AM   #15
michnus OP
Lucky bastard
michnus's Avatar
Oddometer: 1,295
AdvNzer, I see these people sell an unit with a small ballast and with different lumens.
http://www.xtralights.com/xetronicdi...ypesingle.aspx
Times are GMT -7.   It's 08:41 PM.
