12-29-2012, 11:15 AM
#1 |
Vagabond, yes I try!
Hello boys.
I got myself one kick ass good looking HP2 but the headlight beam is piss poor. Has any one fitted a H4 xenon light to the standard headlight, and did it improve the light? I had a look at some other options but most involve adding an additional light. The way I see it, it's going to break or rattle lose with time and falls. The TT option is stupidly expensive and not an option. Any advice?
www.atgear.co.za Hello Africa tell me how you doing? or register and follow us on www.Pikipiki.co.za Angola, it's not like they said Author: Metaljockey Namaqua land, and the three adventurous girls. South Africa/Lesotho longweekend trip |
12-29-2012, 02:06 PM
#2 |
Oddometer: 1,497
Get the euro lens assembly if you want to stay with the stock light housing. It has better optics than the US version. You could do the HID conversion to that housing also.
The Baja Designs 6" HID Pre Runner light can be installed to the stock mounting points with a bit of work. Lots of light output but you give up hi/low.
"You can follow me, but it's gonna hurt" |
12-29-2012, 02:17 PM
#3 |
Thanks MJS, do you have link to the Euro lens setup?
The 6" Baja is too big, I had look at it and do not really like it.
12-29-2012, 04:09 PM
#4 |
I lost my village!
My plan is to upgrade to this as well.
http://www.maxbmwmotorcycles.com/fic...I_EURO%20LIGHT |
12-30-2012, 05:25 AM
#5 |
Oddometer: 738
Euro lens is also shit.
I have installed a Xenon in place of the bulb but the target is more to be seen by others durind day than for a good night lighting. 8000 K ![]() I have added a single Touratech Xenon in parallel on high beam, great result. ![]() ![]()
GSMarc from BELGIUM 2008 HP2/MM ABS 2008 HP2/MM 2005 HP2E 2000 R1150GS (sold) GSMarc screwed with this post 12-30-2012 at 05:31 AM |
12-30-2012, 05:29 AM
#6 |
Oddometer: 738
Old setting (xenon inside lens) high beam
![]() New setting with parallel TT Xenon high beam
GSMarc from BELGIUM 2008 HP2/MM ABS 2008 HP2/MM 2005 HP2E 2000 R1150GS (sold) |
12-30-2012, 09:04 AM
#7 | |
Oddometer: 1,497
12-30-2012, 09:22 AM
#8 |
Oddometer: 738
you are right but I wanted to be different from BMW and Mercedes Xenon lights when in trafic
![]() Such a 'blue' light catches the eyes immediately
12-30-2012, 07:28 PM
#9 |
Oddometer: 390
hp2 headlight
I use the euro glass with a blue bulb and it is way better then stock. Richard
12-30-2012, 11:11 PM
#10 |
thank you Marc for the reply, it seems like a good way to go. I want to try and keep the bike as is, the Baja light is just to big for me.
What other aftermarket xenon's are available other than the TT option? It's hellish expensive that light. Oldfool, the blue light I have tried and it's still just 55w and not much better, imho.
12-30-2012, 11:22 PM
#11 |
delooper
Oddometer: 6,957
There's plenty of more or less similar aftermarket H4 HID replacement bulb+ballast kits. I went with something very similar to GSMarc's setup, but without the Touratech add-on.
I think my main beam is around 4500k. It lights things up quite well. Not a perfect beam distribution but it's a big improvement over stock. I find the H4 HID kits in the HP2 reflector tends to be a bit uneven, skewed towards focusing the light up high. So you have to adjust the height of the lamp quite carefully for it to be a good fit. Putting a passenger on the back throws most of the light onto oncoming traffic. I strapped the ballast onto the left side of the fuel tank, just behind the radiator. That seems to cause no electrical problems. |
12-30-2012, 11:47 PM
#12 | |
Oddometer: 738
here is the TT one
12-30-2012, 11:54 PM
#13 |
thanks Marc.
btw, I was in your valley in Brugge the last couple of days consuming a lot of Zot beers
12-31-2012, 12:16 AM
#14 |
Oddometer: 2,242
you need a proper HID housing to get the best out of it.Make sure the existing housing is clean(inside and out) and get a PLUS rated H4 bulb is prolly going to be your best bet with the std housing
aka BMWST?
12-31-2012, 12:25 AM
#15 |
AdvNzer, I see these people sell an unit with a small ballast and with different lumens.
http://www.xtralights.com/xetronicdi...ypesingle.aspx
