Old 01-01-2013, 03:50 PM   #1
Denase OP
Denase
Oddometer: 28
Question Replacing Grips
I have a 2007 R1200GS Adventure. I would like to replace the grips with a set of universal grips I like. Can that be done or do I have to buy the expensive BMW grips. My bike has heated grips.
Denase is offline   Reply With Quote
Old 01-01-2013, 04:16 PM   #2
rdwalker
Oddometer: 2,545
Grip Puppies
Unless your heart is really set on these particular replacements, don't worry about replacing, just slide Grip Puppies over your old ones.
I have them on all my bikes; the oldest pair installed 5 years ago, still shows no UV or wear damage after about 40k miles. I got them originally to reduce vibration imparted on my hands. They also worked well for general comfort (slightly increasing diameter of the grips). There is no loss of heating.
One of the best deals ever. Installation takes about 10 minutes. Get the small size, you will need to shorten them a bit with scissors, lube with dishwasher fluid and just slide on.
Replacement of OEM grips is not easy (there is a pictorial somewhere here on ADVrider) and you are risking damaging the heaters, extra cost.
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker screwed with this post 01-01-2013 at 08:03 PM
rdwalker is online now   Reply With Quote
Old 01-01-2013, 06:13 PM   #3
Denase OP
Denase
Oddometer: 28
Thanks I will check those out.
Old 01-01-2013, 06:23 PM   #4
TOTim
TOTim's Avatar
Oddometer: 191
This is how I did mine.
I used some generic grips as replacement.
http://www.advrider.com/forums/showt...highlight=grip
TOTim is offline   Reply With Quote
Old 01-02-2013, 04:48 AM   #5
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,900
There is an excellent tutorial in the Hall of Wisdom (bottom of every page on advrider) for doing GS/GSA grip replacement.
Current: 2014 R1200GSW & 2007 DR650
jdub is online now   Reply With Quote
Times are GMT -7.   It's 05:43 PM.
