Old 01-02-2013, 08:08 PM   #1
davisdrafting OP
Oddometer: 10
DR200SE OEM blinker (wings) mod
The hardest part is removing the pins from the connector, they are retained by plastic from the connector not metal on the pin which is typical.
Cut stem about 1/2" from last ridge
From Drop Box
Chop off about 1/2" from flat mounting surface and remove rubber
From Drop Box
Drill the end that fits in the blinker out to 1/2" dia. (a 1/2" step drill works best) insert threaded mount into hole 1/8: apply super glue and press together in vise.
From Drop Box
Reassemble.
From Drop Box
davisdrafting is offline   Reply With Quote
Times are GMT -7.   It's 01:33 AM.
