Old 12-30-2012, 06:31 PM   #46
Phreaky Phil OP
Oddometer: 1,184
Originally Posted by Kokopelli View Post
Yes, the sandy stuff was a hoot. I don't know how people got through there on the big bikes and I hate to think what was like two up. Since I helped a little while the course was being set up, I had the pleasure of riding most of it three times. I was OK at speed, but as soon as I had to slow down, it was all over. I nearly ran into the back of Oscar's 950, while he was stopped..
Muriwai Beach is iron sand, when I cleaned the bean can recently, it had attracted a lot of the magnetic metal fuzz. One of the reasons that I think I'll stay off the beach from now on. Woodhill might be OK, but I hate that salt getting in everywhere.
Vege loves his suspension. I can't believe how fast he is on gravel, I don't usually like getting passed, but when Chris Birch went past on Inland road on his 990, it was great to watch. The laws of physics do not seem to apply to him. I seem to be attracted by gravity a lot more, it's not happy until I am horizontal.
I've just drained a couple of hundred ml of oil from the rear boot of the final drive on the R80GS it must have accumulated there for a while. I was expecting the usual table spoon full, not a puddle on the ground. Since the gearbox is still full, I am not too worried. I hear wet shaft drives last longer :-).
Mine used to leak, even after I had had the final drive rebuilt, and as I am anal about oil leaks it drove me nuts. We figured it was migrating down between the shaft and the sleeve as it shouldnt be able to get past the seal, so Mike D put some crc wicking compound into it. Havent looked in there for a long time to see if there is any oil there.
In the deep sand the front end wanted to spear off sideways. I tried riding it fast, dirtbike style but that nearly ended in tears so we just had to slog it out slowly. The soft front forks dont help as when the front would grab and want to go sideways it would just compress the forks and tuck the front under.
I have never seen Chris ride on gravel before but if its anything like on a dirt bike it would be spectacular.
If he has another school we should come up and see if he can teach us to ride sand 2up better. Not sure if he has done any 2 up adv riding.?
We tried both standing a couple of times (on the Beemer ), weird. I would need to shift the controls around a bit as its set up for sit down riding. And Dawn needs something around my waist to hang on to.
Phreaky Phil is offline   Reply With Quote
Old 12-30-2012, 08:11 PM   #47
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,251
Dawn is amazing, the stuff you two do together and she seems to be enjoying herself. Has she never wanted to ride herself? We'll be heading off tomorrow, starting with the Off-limits ride in Waiouru. It's amazing how much stuff we can pack on Gerda's bike, all I have to carry is one bag.,
R1150GS
R80GS Basic
Kokopelli screwed with this post 12-30-2012 at 08:23 PM
Kokopelli is offline   Reply With Quote
Old 12-30-2012, 08:46 PM   #48
Phreaky Phil OP
Oddometer: 1,184
She did have a go and has a learner licence but would rather be a pillion.
Travelling light is good ! Give it to someone else to carry
That ride sounded good. I would like to explore that area myself, but we are trying to get some things done around the house that I have been putting off for a long time
Enjoy the ride and do a report for us.
Old 01-01-2013, 12:16 PM   #49
elmontanero
Practicing...
elmontanero's Avatar
Oddometer: 1,426
This is good information - does using these different Swings/FD provide better/longer/higher rear ends?
Seems like swapping front ends gives Airheads always comes with the need to sort out the rear, is there a preferred Oilhead Swing Arm/ Final Drive that gives you the best rear suspension for the effort?(besides weight/disc brake) I've seen the HPN:
HPN-Sport: The "light" HPN for the sports rider.With the reinforced BMW GS frame, the BMW R1100GS swingarm and the best accessories parts from Brembo, Marzocchi, WP Suspension, Acerbis and HPN we created a motorcycle with superb handling on- and offroad
Among the info: Teleskopic front fork: Marzocchi Magnum, ø50mm, 285 mm travel. Shock absorber: Special built WP Suspension with adjustable compression and rebound damper settings and hydraulic adjustable spring preload
Swing arm: BMW R1100GS Series
Originally Posted by Airhead Wrangler View Post
I have different numbers for this:
Rear End Comparison:
I also got curious about the conversion to the R1100GS rear end and wondered what it would weigh compared to a monolever rear end:
R1100GS
final drive 16.7
paralever rod 1.3
swingarm 7.8
drive shaft 5.2
rear wheel 14.7
disc 2.0
caliper 1.8
shock 10.0
59.5 lbs total
R100GS or GSPD
rear wheel 14.2
swingarm w/ all bearings, pins, lower boot 6.2
tie rod 1.0
driveshaft 4.4
final drive 17.8
brake shoes, cam, lever 1.9
shock 8.4
53.9 total
R80ST
swingarm w/ bearings and pivot pins 7.3 lbs
driveshaft 3.9
final drive 16.2
rear wheel 13.0
brake pads, cam, lever 1.4
shock 6.3
48.1 total
HP2 just for curiosity's sake
final drive 17.4
swingarm 9.6
paralever tie rod .9
rear wheel 11.3
driveshaft 4.8
rear disc 2.1
rear caliper 2.1
shock 4.9 (I find that very hard to believe)
53.1 lbs total
"And if we have food and covering, with these we shall be content."
elmontanero is offline   Reply With Quote
Old 01-01-2013, 12:28 PM   #50
elmontanero
Practicing...
Oddometer: 1,426
And this one too:
HPN-Rallyesport: The "long-distance" HPN for the adventurer. With the reinforced BMW GS frame, the BMW R1100GS swingarm.
Teleskopic front fork: Marzocchi Magnum, ø50mm, 285 mm travel, or WP Suspension Upside-Down 295 mm travel
Shock absorber: Special built WP Suspension with adjustable compression and rebound damper settings and hydraulic adjustable spring preload Swing arm: BMW R1100GS serie or welded aluminum construction, 245 mm travel
Old 01-02-2013, 04:34 AM   #51
Basic_Gerd
Gerd
Basic_Gerd's Avatar
Oddometer: 184
All weights can be found here (and elsewhere): http://www.bmwetk.info/parts-catalog/flt/MS/BMW/VT/P.
The difference between theory and practice practically is larger than the difference between theory and practice theoretically.
BMW Airhead -> www.zeebulon.de/bmw
BMW R1100GS -> www.zeebulon.de/R1100GS
XT 500 -> www.zeebulon.de/xt
Basic_Gerd is offline   Reply With Quote
Old 01-02-2013, 09:45 PM   #52
Phreaky Phil OP
Oddometer: 1,184
I drained the remaing fuel from my GS tank this arvo. It weighs 6.2kg. As a comparison the Touratech site lists the 43litre tank as 7.6kg package weight. Not sure if that is boxed up but either way only 1.4kg heavier.
Anyone have an empty one to weigh ?
How about the 19 litre tank ?
Old 01-03-2013, 12:17 AM   #53
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 1,431
The important thing with the 43l tank is it gets the weight below the spine of the bike, so regardless of actual weight, it feels lighter (assuming the same fuel load between tanks).
You'd also need to include the fittings for the big tank (two on the front of the frame & one at the rear, & the rubber damper mod frame).
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 01-03-2013, 01:20 AM   #54
Phreaky Phil OP
Oddometer: 1,184
Yes,the big tank would certainly carry the same quantity of fuel lower than the original, I take it from your post that its noticable ? Thats a lot of fuel when you fill it up though. My DR Safari tank holds 38l and its bloody heavy to lift off the bike when its full.
I would assume the Touratech weight would include the brackets as its the shipping weight.
Do you get the same steering lock with the 43l tank and USD as stock tank and forks ?
Old 01-03-2013, 01:29 AM   #55
Rucksta
Chronic Noob
Rucksta's Avatar
Oddometer: 2,293
43 lt tank (paintable) with mounting hardware, Fuel cap & taps 8.3kgs or about the same as the steel 32lt Dakar tank
If the Earth is flat why are my tyres round?
Rucksta is online now   Reply With Quote
Old 01-03-2013, 07:07 AM   #56
Airhead Wrangler
More tacos than you
Airhead Wrangler's Avatar
Oddometer: 5,111
It actually gives you a bit more clearance than the stock tanks.
R80ST Gets The HPN Treatment
Ducati Pantah 500SL Rebuild
Seattle to TDF on an airhead
WTB R100R Mystic sidestand and mount.
Airhead Wrangler is online now   Reply With Quote
Old 01-04-2013, 08:53 PM   #57
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,251
The ride was awesome. I am still at National Park, so no photos yet (watch out on McCardigan's thread). I really love that front suspension. It took some really big hits and some jumps (well, not huge ones) in it's stride, never once got close to bottoming out. The scenery was stunning and this ride is right up there with the best I've done, for a very reasonable price.
I can now confidently run my airhead at high 3rd gear speeds on deep loose gravel/sand, let's call it a river bed. Tank tracks with with wash outs and ruts, were soaked up really well. My riding definitely went up a notch and should now be close to average.
If I could sort out that slight stall off idle, I would be a happy man. I am also really liking those new Husqvarnas (BMW is easier to spell, that's why I am riding one, or two), that could be a nice commuter with adventure riding duties (checking lotto ticket, again).
R1150GS
R80GS Basic
Times are GMT -7.   It's 09:13 AM.
