Old 01-02-2013, 05:40 PM   #6646
cynicwanderer
cynicwanderer's Avatar
Oddometer: 555
'84-'90 XR600R are damper rod style forks that fit XL axle, '91-'92 are cartridge style forks that fit XL axle. '93-2000 XR600R, all XRL650L and all XR400R are cartridge style forks with larger axle. not all calipers/rotors are interchangeable, even if the wheel is fitted/centered.
Originally Posted by MentalGuru View Post
'91 and newer XR600R's are cartridge forks and use a 17mm axle.
Swap to the 17mm bearings wheel bearings that fit with the later XR600R larger axle and spacers.
With XR400 forks one washer needs to go on the axle treads to center the wheel correctly.
cynicwanderer is offline   Reply With Quote
Old 01-02-2013, 06:25 PM   #6647
m2h
"Old guys rule"
m2h's Avatar
Oddometer: 130
Originally Posted by crobox View Post
There are two "tubes" on the carbs that are a bit mysterious to me. I'm hoping someone can help me figure out what to do with them....
A: If you blow air into this tube it comes out somewhere inside the main body of the carb. I have seen pictures of other bikes where this tube is just capped off with something like an automotive vacuum cap. Is that the right idea?
B: Air blown in here also comes out in the carb, actually from the little hole that's visible about an inch to the left of the red oval in this picture. However, I have no idea what to do with this one.
Mine have petrol hose attached and fed down to a securing loop on the right side behind the brake lever. Probably better than leaving them as is in your pik.
m2h
m2h screwed with this post 01-02-2013 at 06:28 PM Reason: incorrect info
m2h is offline   Reply With Quote
Old 01-02-2013, 06:32 PM   #6648
m2h
"Old guys rule"
m2h's Avatar
Oddometer: 130
Originally Posted by Stretchah View Post
Happy New Year Guys
Since I got the XL I've had intermittent starting problems and after replacing and sorting out quite a few of the porevious owners errors and lack of maintenance, it seemed to be getting better. I then noticed that the compression seemed to be really strong sometimes and hardly there on other occasions. I was thinking it may be a valve issue and the other week the bike died a few times on the way home and lost compression so took the AA for the rest of the way.
I dropped the engine out and yesterday i finally had the time to strip it down and here's what I found:
The intake valve seats seem to have sunk and one has broken up
You can see the amount of sinkage better on this one
Thankfully it looks like I haven't lost any of the seat into the barrel and the piston looks fine:
I've also checked over the cams, cam chain, sliders and Rockers and everything else looks fine, so, hopefully once I've got new valve seats and valves fitted all should be good. There's a local firm that specialise in working on older single cylinder bikes including Xls, so, thinking I'll get them to fit the seats and new valves and then I'll put it back together myself to keep the costs down.
Let me know if there's anything else worth doing while I'm at it?
Oh boy, now you've got me worried My compression seems to be the same
m2h
Old 01-03-2013, 01:01 AM   #6649
Stretchah
Oddometer: 123
M2h, I hope it's not the same issue, but, it may be worth checking out to be on the safe side. Like Brucifer said I was lucky the chunk of seat didn't come off and cause more damage. The related issues I was having was that it would randomly die on rides too and was a pig to start when comp was low. When it was high I needed decomp to get over TDC and when low I could kick it sitting down without .
Something else to look for perhaps is when I took the carb boots off I noticed that I had black soot in the bell mouth of one of the carbs where the valve wasn't closing and the exhaust gases were blowing through.
I'll keep my fingers crossed it's an easier fix for you :)
On the upside I took the cylinder off and its very smooth and no damage at all, so, going to get a hone and new rings Dropping the head and Barrel into the shop on Saturday, so ,will keep you updated on progress, can't wait to get her back on the road
____________________
84 Harris Magnum 2
84 XL600R
85 Vespa PK135
Stretchah is offline   Reply With Quote
Old 01-03-2013, 07:18 AM   #6650
brucifer
brucifer's Avatar
Oddometer: 2,384
Stretcha, did you measure your cylinder and piston? I had an XR600 cylinder that "looked" perfect but once measured was out of specifications, so I ended up having to bore it.
2014.5 Kawasaki KLR650 NE-2008 Yamaha TTR110-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
For sale--1996 Honda XR600R--
brucifer is offline   Reply With Quote
Old 01-03-2013, 07:28 AM   #6651
Stretchah
Oddometer: 123
Hey Brucifer, I haven't as my tape measure isn't that accurate ;) So, I'm actually taking the cylinder to the workshop too, so, they can check it out properly and hone or rebore as required, that way at least I'm sure, but, hoping for just a hone and rings. If it's a rebore I may look into a high comp piston alternative
84 Harris Magnum 2
84 XL600R
85 Vespa PK135
Old 01-03-2013, 09:08 AM   #6652
brucifer
brucifer's Avatar
Oddometer: 2,384
Ha ha, yeah, you have to have a pretty good eye with a tape measure.
Well, good luck to ya. Here's to hoping it's just a hone.
Old 01-03-2013, 02:34 PM   #6653
cynicwanderer
Oddometer: 555
mine runs better when B is covered with a plug. it's a vacuum port used to go to the big evap. can on my CA legal '85. there is a vacuum controlled valve in the can that is activated when the motor runs. it effects the mixture when you don't have anything connected to it and will drive you crazy.
m2h
Old 01-03-2013, 10:38 PM   #6654
crobox
crobox's Avatar
Oddometer: 324
Thanks.
Are you running "A" open, uncapped?
-Christian
Current Bikes: 2006 KTM 950 ADV S, 2002 XR650L, 1988 Hondasuki KLNX250R
Previous Bikes: 1986 Honda XL600R,Honda XL250R (2 of them), Honda XL600R, Kawasaki KLR600, Honda Nighthawk, BMW K1100LT, BMW R100GS, BMW R60/6, BMW K75, Husqvarna 430XC
Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com
crobox is offline   Reply With Quote
Old 01-03-2013, 11:47 PM   #6655
cynicwanderer
Oddometer: 555
A is a vent and I think on mine it just goes down in a tube in front of the swingarm.
Thanks.
-Christian
Old 01-04-2013, 09:49 AM   #6656
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,067
Originally Posted by Moparmanpete View Post
Any one know of a windshield that fits, I saw some by Maier Mfg but don't know if they will fit right.
I need something, I feel like I'm wearing a parachute on the highway
Pete
TCI products makes one, as well as some other touring type accessories.
https://tciproductsusa.com/index.php...roducts_id=532
Carter Pewterschmidt is offline   Reply With Quote
Old 01-04-2013, 02:16 PM   #6657
brucifer
brucifer's Avatar
Oddometer: 2,384
Are you sure "B" is vacuum? On my '84, it's the float chamber vent.
Old 01-04-2013, 04:13 PM   #6658
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Thanks Carter, I like how they made the mounts for that, but the price .
Anyone make a windshield?
Pete
Is this what you are looking for??? I think they will fit just fine. The DR650 ones might work well also.
http://www.ceebaileys.com/honda/xr650lws.html
MentalGuru is offline   Reply With Quote
Old 01-04-2013, 08:07 PM   #6659
crobox
crobox's Avatar
Oddometer: 324
Bruce-
It seems to make sense (to me) that it's vacuum... at least on my carbs. You can't really see it in the picture, because of the angle, but "B" is a short bent steel tube which just goes straight into the side of the intake-side of the main bore of the carb. The place it enters is actually visible in the pic as a small hole, or port, in the bore... about one inch to the left of the red oval surrounding "B". So it does stand to reason that it's vacuum. It doesn't go anywhere near the float chamber, at least not on mine.
By the way, thanks for chiming in with the original answer!
-Christian
Old 01-04-2013, 08:09 PM   #6660
crobox
crobox's Avatar
Oddometer: 324
I meant to say - Has anyone made their own windshield?
I've thought about it... and may yet do it a little further down the road.
I've had good results in the past putting gentle bends into plexiglass using a heat gun.
-Christian
Times are GMT -7.   It's 03:12 PM.
