Old 12-31-2012, 01:45 PM   #826
Jetstreamer
Sandlapper Brapper
Jetstreamer's Avatar
Oddometer: 192
You should rig it so GPS only works when you are honking. That way you never rely on it!
- George
2009 XT250
Jetstreamer is offline   Reply With Quote
Old 12-31-2012, 01:50 PM   #827
mwalker
mike
Oddometer: 75
Ha!...I think that would happen if I tie into the switched side, If I tie into the hot side.. where do I tie the black wire from the gps... the frame?
mwalker is offline   Reply With Quote
Old 12-31-2012, 02:21 PM   #828
ER70S-2
ER70S-2's Avatar
Oddometer: 6,449
Careful, some GPS run on 3-5 volts. The circuitry is in the plug and can't be wired directly to 12v.
If that's ok, then the black goes to the frame.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 01-02-2013, 09:21 PM   #829
Chay
Oddometer: 96
Can anyone link me or recommend a throttle lock that will fit my '09 XT 250? It would really help when digging in jacket pockets when riding.
Chay is offline   Reply With Quote
Old 01-03-2013, 12:16 PM   #830
Roadrunner
(Negativus Supersonicus)
Roadrunner's Avatar
Oddometer: 23,338
Try pulling over.....it's a lot safer.
"System change is not for the conceptually or interpersonally fainthearted." - Sarason
Roadrunner is offline   Reply With Quote
Old 01-08-2013, 06:56 PM   #831
Jetstreamer
Sandlapper Brapper
Oddometer: 192
How hard do you guys ride your XTs? Anyone ever inadvertently hurt their bike? What's the roughest that it's seen?
- George
2009 XT250
Old 01-08-2013, 09:01 PM   #832
The Cameraman
Oddometer: 218
Hi George,
I managed to fall sideways onto a sharp rock, whilst trail riding, which sheared off my exhaust header pipe right at the joint where it sits into the exhaust port!
Still managed to get me home, despite having no power and making an awesome racket!
Regards
Reggie
The Cameraman is offline   Reply With Quote
Old 01-08-2013, 09:08 PM   #833
150ron
150ron's Avatar
Oddometer: 1,354
Ive dropped mine in the trails many times,
Ive also had it on the freeway for about 40+ miles going WOT, the bike just keeps going and going.
clean fresh oil, clean air filter, gas in the tank, and it will run.
Never a single issue, and i can honestly say i rode the shit out of that bike.
Just some dude...
150ron is online now   Reply With Quote
Old 01-09-2013, 06:01 AM   #834
FLYNLOMOTO
FLYNLOMOTO's Avatar
Oddometer: 50
Mine is sort of new but I have ridden it pretty hard so far and dropped it a few times. No probs!
The dirt track that I ride on has some jumps and other than bottoming out the front forks the bike seems
really tight and durable. Everything is really "tucked" under the frame so there's like nothing to break.
No radiators or colant lines to bust. I have barkbuster hand/lever guards, rear brake master cylinder guard, and
factory belly pan so mine's pretty bullet-proof!
For Town: Monster S2R800
For Country: 2012 XT 250 Wolfman bags/TurboCity Brake Guard/Yamaha Skid Plate/FMF Powercore 4/Barkbusters/Trail Tech Gauges
>Baseball, Basketball, & Football all require one ball, Motocross requires two.
Hong Kong
FLYNLOMOTO is offline   Reply With Quote
Old 01-11-2013, 08:15 PM   #835
Hans_Krugger
Rock Jock
Hans_Krugger's Avatar
Location: on an interflurviate ridge in the Interior Lowland
Oddometer: 25
Do Newbies Dump in the Woods?
Yea, I dumped mine. Kind of a basic requirement. Hauled it down to Wayne, went on one set of trails - made it with no problems. Second time went down - didnt look too closely at the countrour lines on the topo map...took it down stuff I could not ride up - then when I did try to get it back up out of the ravine, lost it several times and dumped it (failed to lean forward to get up over the bumps and steps going up slope). Had to basically winch it out of the ravine using old climbing gear (set up a "z pully" system used for crevass rescue).
Hans_Krugger is offline   Reply With Quote
Old 01-16-2013, 05:47 PM   #836
frog13
frog13's Avatar
Oddometer: 1,340
Good thinkin Hans!.
frog13 is offline   Reply With Quote
Old 01-18-2013, 07:37 PM   #837
Roadrunner
Roadrunner's Avatar
Oddometer: 23,338
You can see a good sized "ding" on my exhaust pipe here.
http://www.advrider.com/forums/showp...&postcount=759
Old 01-21-2013, 06:08 PM   #838
frog13
frog13's Avatar
Oddometer: 1,340
How much weight did the current FI XT250 gain from previuos XT's. Anyone switch from a 225 to the FI XT250?.....if so, much difference in the two?. TIA.
Old 01-21-2013, 08:37 PM   #839
Old White Truck
Old White Truck's Avatar
Oddometer: 120
Originally Posted by frog13 View Post
How much weight did the current FI XT250 gain from previuos XT's.TIA.
The Yamaha website says:
2012 XT250: Wet Weight = 291 lbs
2013 XT250: Wet Weight = 291 lbs.
Old White Truck is offline   Reply With Quote
Old 01-22-2013, 02:48 AM   #840
greer
Oddometer: 3,801
I believe the 225 was 268 wet.
Sarah
'08 DR650
greer is offline   Reply With Quote
Times are GMT -7.   It's 10:43 AM.
