Old 01-02-2013, 12:29 PM   #76
Zoolion
Zoolion's Avatar
Oddometer: 58
New Garage, lots of setup and projects
Fisrt on the list was to get this guy working
Combo solid/oil furnace set up for wood only. HEAT!
More pics
From the other side
"I'd hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." - Hunter S. Thompson
Zoolion is offline   Reply With Quote
Old 01-02-2013, 12:32 PM   #77
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,493
Originally Posted by D.T. View Post
Looks like chemical attack. ABS or polypropolyne?
All I did in the garage today was look around on my laptop. And got another day older.
I'm not sure what kind of plastic, but the gas might have an effect on it, combined with the pressure of the female QD.
Jim
Old 01-03-2013, 05:07 PM   #78
victor441
victor441's Avatar
Oddometer: 972
made a bead breaker...
fabricated a crude yet (hopefully) effective bead breaker from scrap and attached it to a bicycle work stand I made from other scrap years ago....ugly but $0.00. 2x boards will go across the legs to support the wheel and tire...
victor441 is offline   Reply With Quote
Old 01-03-2013, 06:02 PM   #79
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,540
Still working on freeing up my engine.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 01-03-2013, 06:05 PM   #80
RickS
RickS's Avatar
Oddometer: 595
Carried in a free floor jack my wife got from a relative.
RickS is offline   Reply With Quote
Old 01-03-2013, 06:11 PM   #81
JimVonBaden OP
"Cool" Aid!
Oddometer: 53,493
For better/different leverage you might want to add a second attachment point for the upper bar a couple inches lower.
Jim
Old 01-03-2013, 06:21 PM   #82
Ratski
Ratski's Avatar
Oddometer: 759
Im not sure if it counts, but after work, I mounted my ice tires for my KTM, but I did it in the basement.
Ratski is offline   Reply With Quote
Old 01-03-2013, 06:57 PM   #83
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,655
Put the last piece of sheetrock up on the ceiling. One more wall to to go then get the garage door openers back up and running so I can put the cars back inside and out of the cold.
CanadianX is offline   Reply With Quote
Old 01-03-2013, 08:23 PM   #84
victor441
victor441's Avatar
Oddometer: 972
Jim
I considered that and still might do it but first am going to try adding 2x boards for front wheels, skinny vintage tires, etc. and see if that does the trick, raising the wheel 1.5" or 3" will change the angle of the linkage and the leverage quite a bit...I set it up initially so it will handle the fattest MC tires I have with one board across the legs.
Old 01-03-2013, 08:35 PM   #85
JimVonBaden OP
"Cool" Aid!
Oddometer: 53,493
Jim
Old 01-04-2013, 01:04 AM   #86
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Looks like you could do semi tires with that bad boy! Nice!
kirkster70 is offline   Reply With Quote
Old 01-04-2013, 08:52 PM   #87
victor441
victor441's Avatar
Oddometer: 972
Thanks! it actually is not as big or heavy duty as it looks in the picture but I did not have a wheel off a bike to give a sense of scale....but it should be able to pop the bead on big stiff tubeless MC tires at least
Old 01-04-2013, 09:08 PM   #88
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,494
If possible, Victor
post a video of a GS rear wheel with a Kenda Big Block tire?
notorious for hard to break down.
looks nice, I like the idea and design
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 01-04-2013, 09:46 PM   #89
victor441
victor441's Avatar
Oddometer: 972
Originally Posted by mouthfulloflake View Post
If possible, Victor
Thanks! I don't have that specifically but do need to change the rear Tourance tire on my Tiger 955i soon and I'll post something on that (if it works ;-) I didn't design it myself, looked at a bunch of MC bead breakers on the web and based mine on the one that looked the best
Old 01-05-2013, 04:44 AM   #90
roger123
roger123's Avatar
Oddometer: 1,621
Worked on this little guy. Sig Mosquito (.22 Cal), having problems with the slide "sticking" back while shooting, needs a "thumb bump" to go back into battery.
Polished up the feed ramp to try and aid feeding.
Also noticed the slide was pretty rough and was dragging very hard on the hammer, I think that may be the biggest issue. Polished up really well, we'll see on Tuesday when I go to the range how she runs.
'14 Tenere ES
COG 5903
roger123 is offline   Reply With Quote
Times are GMT -7.   It's 02:02 AM.
