Old 01-01-2013, 02:33 AM   #7006
Peanuts
Peanuts's Avatar
Location: Beautiful but often rainy North Yorkshire, UK
Oddometer: 1,731
Originally Posted by Vicks View Post
I've been concerned about the not so tight FMF can in the hanger which can lead to a cracked rear header pipe and took care of it. Cut a few strips of rubber and added them into the hanger so that the can stays put and fully supported by it.
Looks like you lost a screw out the end of the can.....
Peanuts is offline   Reply With Quote
Old 01-01-2013, 06:42 AM   #7007
vonotto
vonotto's Avatar
Oddometer: 250
New Scotts Steering stabilizer with top triple tree & 3/4 inch riser {need more height}
Scotts rear disc guard. Nice piece of bling
"It flicked me pretty high and I landed back on the bike so hard I thought I'd swallowed my own nuts!"
vonotto is offline   Reply With Quote
Old 01-01-2013, 02:25 PM   #7008
zgfiredude
Oddometer: 874
After discovering Geek's awesome thread, "Welcome new 9x0 owners...." http://advrider.com/forums/showthread.php?t=769525
I got started on the suggestions it contains:
1. Adjusted the steering stops. It was amazing how far out they were!
2. Removed the rubber foot peg isolators....
3. Trimmed the rear mud flap to prevent swing arm scoring. Very easily done, trimmed off about 1/4" x 6" off each edge.
4. Drilled 1/8" drain holes in the lower back ends of the swing arm for water drainage, and removed/cleaned/anti-seized the adjusters to prevent seizing and corrosion.
And these were the suggestions from reading only the first couple of pages from the thread!!
A huge "thanks" to Geek and everyone else for contributing to that thread for us newbies! I'm getting to know the bike and taking care of preventive maintenance type items while seriously "Jonesing" to ride!!
zgfiredude is offline   Reply With Quote
Old 01-01-2013, 03:20 PM   #7009
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,263
Man, thats is one clean install. and HOW IN HELL IS YOUR ENGINE SO CLEAN ????
mine is quite shabby in comparison and leaks at a few joints.
Did you pre-assemble the hoses and then wiggle the entire assembly into place ? Mine used to lead at the thermostat housing and after i replaced the clamp, its now leaking at the cross-over joint (between the bores)
It's a fully rebuilt engine from KTM USA factory mechanic, that's why it's so clean. I used my old hose assy to model the new Samco hoses in place, and built it up piece by piece.
Only had the radiator hoses to connect when I lifted the engine into the frame. Oeticker clamps are great. Used smooth edge Euro groove-screw clamps on the radiator connections (from a KTM dealer), they don't leak.
The cheapie sharp perforated edged screw clamps can damage all kinds of hoses.
cyborg screwed with this post 01-01-2013 at 09:13 PM
cyborg is offline   Reply With Quote
Old 01-01-2013, 03:22 PM   #7010
Qwik
Adrenaline Addict
Oddometer: 6,947
Beautiful day for a ride in the Bay Area of Cali.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 01-01-2013, 03:56 PM   #7011
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 1,081
Broke my frame
Rode down to Hollister and was having a real fun time, then began hearing some noise when in the air. Stopped to check it out and found the tabs for the center stand stops have broken off, and the PA biker side stand bracket which is bolted to those had sled back and was making contact with the chain when air borne. Looks like I'll need to do some welding soon. Now wear can I get some orange frame paint?
dogsslober is offline   Reply With Quote
Old 01-01-2013, 05:18 PM   #7012
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
Originally Posted by dogsslober View Post
Now where can I get some orange frame paint?
Kubota shop probably. It'd be pretty damn close.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 01-02-2013, 06:15 AM   #7013
xcflyn
xcflyn's Avatar
Oddometer: 1,152
Secretary has to work out of her car to make room for some heated indoor storage.
Actually I am my own secretary and this was a spare office. GF says it should go up on in storage above the offices but I kinda like it here.I pay the bills - I win (for now - she still does the books and has other functions I like )
xcflyn is offline   Reply With Quote
Old 01-02-2013, 08:43 AM   #7014
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,579
Moby just spent a month in dry dock for the following:
New dual horns (sounds like a steam ship)
Black Dog skid plate
Welded enlarged side stand pad
Cannisterectomy
Rear ABS disconnect switch
Nerf bars (thanks Geek!)
Gobi bags
Givi Trunk
Replaced snorkel with pre filter
HDB hand guards
Throttle lock
KTM heated grips
0.52 fork springs
Fresh oil in shock & forks
Additional power outlet on dash
The only remaining tasks are an upgrade of the clutch slave cylinder, addition of highway pegs, and a Seat Concepts seat.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 01-02-2013, 09:25 AM   #7015
Vicks
gets stuck in sand
Vicks's Avatar
Oddometer: 3,204
Yes, and that too :-)
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally and 2012 KTM Adv990
530Exc Adventurization re-build
Vicks is offline   Reply With Quote
Old 01-02-2013, 05:51 PM   #7016
Qwik
Adrenaline Addict
Oddometer: 6,947
Added some Carbon Fiber Bling to My Katoom. Now I just have to find a damned 31mm Socket so I can split the cases on my old motor.
Old 01-03-2013, 10:38 AM   #7017
DeepSea
electronically challenged
DeepSea's Avatar
Oddometer: 247
Qwik, I got one you can use. I'm in the East Bay.
CDR 2012 ------ Too Lazy to write my own RR
Commercial Diving flashlight and tools
It's not me. My bike is Narcoleptic.
Research is what I'm doing, when I don't know what I'm doing.
DeepSea is offline   Reply With Quote
Old 01-03-2013, 06:17 PM   #7018
go2cnavy
Dont Worry Be Brappy
go2cnavy's Avatar
Oddometer: 575
Walked past it on the way to work cause it's too cold to ride.
go2cnavy is offline   Reply With Quote
Old 01-04-2013, 06:33 AM   #7019
Eataz
Eataz's Avatar
Oddometer: 49
First ride of the year! From Sweden.
Eataz is offline   Reply With Quote
Old 01-04-2013, 07:37 AM   #7020
beergut
Thumper
beergut's Avatar
Oddometer: 414
I'm a 950 owner
See ya' KLR!
beergut is offline   Reply With Quote
Times are GMT -7.   It's 03:32 AM.
