Old 01-02-2013, 06:20 PM   #1
norschweger OP
norschweger's Avatar
Oddometer: 242
950 not sounding good, oil lamp flickering
Last time I started the engine (after 3 days of parking) it did not sound good, seemed to run on one cylinder only, after a while it seemed to be ok. Today (after 3 days again- walking city-tourist : ) ) the sound seems to be worse, it sounds as if the valves did not get any oil. In addition the oil lamp is flickering, even in gear.
I cannot see any obvious failure, oil level is good, screws to the exhaust were pretty tight.
Later I started the engine again to show a mechanic. This time the oil lamp first did not work at all, then just in neutral, then it went off again.
The last oil change is 2000 km ago. I did not have a new oil filter though (means the filter is 8000km old). There were no signs of malfunction until some days ago, The valves have been adjusted 8000 km ago.
Any ideas?
Thanks a lot!
norschweger is offline   Reply With Quote
Old 01-02-2013, 06:22 PM   #2
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
Leaking water pump seal and or failed oil filter.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 01-02-2013, 06:28 PM   #3
smilin'Ed
Ed
Oddometer: 583
compression check is easy to do and can give a quick idea of what internal conditions might be.
Pull oil filter, screen and magnetic plug and look for debris.
smilin'Ed is offline   Reply With Quote
Old 01-02-2013, 06:30 PM   #4
joneswgareth
Welsh Rarebit
joneswgareth's Avatar
Oddometer: 196
Sounds like water pump seal failure and water in the oil.
Take off the clutch cover and see if there is milky oil. If there is you need to change the seal and change oil and filters.
See here how to do it http://www.ktm950.info/how/Orange%20...ater_pump.html
950 SE
joneswgareth is offline   Reply With Quote
Old 01-02-2013, 07:49 PM   #5
norschweger OP
Oddometer: 242
Thanks for the quick and helpful answers. It makes perfect sense and even explains why I have to refill coolant without seeing a leak, And in 3 days the water had much more time to intrude than with every-day-riding. Maybe that is also a reason why the clutch slips when the engine is cold and why the oil level differs (had to add quite a bit. Plus that I noticed some weeks ago that there was pressure in the oil tank (when unsrewing the dipstick...pffff!). Allright, good to know who the enemy is...so long, time to eat and have a beer.
Ciao : )
Old 01-02-2013, 08:23 PM   #6
Qwik
Adrenaline Addict
Oddometer: 6,824
If you have a paper element oil filter odds are it will be wavy from absorbing water. That causes it to stop passing oil through. Pleats should be straight.
Topes never seem to make me go any faster.
Qwik is online now   Reply With Quote
Old 01-03-2013, 11:33 PM   #7
norschweger OP
Oddometer: 242
Today we stripped the girl and opened the engine. The machanic (KTM, but no experience with a bike like this) says the timing chain is that lose that the tensioner cannot tighten it enough (front cylinder) and that there was no leakage from the water pump (oil looked normal, but I could not communicate with him why he was so sure about excluding this probable failure just by opening the pump to the rotor).When turning over the engine there is a clic-sound at one point (seems to come from the valves (front cylinder). i hope tomorrow will bring more clarity and an inexpensive and fast solution...(they have already talked about three weeks for parts..., guess there must be a faster way from the States)
Old 01-04-2013, 08:13 AM   #8
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
I would be very cautious at this point - everything else you have posted points to a leaking water pump seal. The tensioner is hydraulic (this why it clatters on start up and when the oil light flickers). You have said that the coolant is disappearing, where is it going? Also what has a loose cam chain got to do with low oil pressure.
Have a look at the oil filter and maybe post a pic-up. It is pretty apparent if there is water in the oil.
Old 01-04-2013, 08:31 AM   #9
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,943
Take a good look on our thread and see what you are looking for, specifically the oil filter photo showing wrinkles
http://advrider.com/forums/showpost....&postcount=719
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 01-04-2013, 10:35 AM   #10
BoulderGuy
out ridin'....
BoulderGuy's Avatar
Oddometer: 433
Don't worry about the "click" noise as you turn the motor over- that's normal. As far as the noise at start up, it could be a loose cam chain tensioner but it could also be coolant in the oil. Like someone else said, the coolant has to be going somewhere! First thing I would do is pull the filter and check the condition of it and the oil. My 950 will flicker here and there and I'll get some clatter from the cam chain, especially when the oil is about due to be changed. Low RPM's at idle can also be a culprit. RPM's should be around 1400 as I recall.
BoulderGuy is offline   Reply With Quote
Old 01-04-2013, 10:51 AM   #11
1stiski
Ride that nasty thing
1stiski's Avatar
Oddometer: 1,644
Check the easy , obvious first,, OIL, FILTER, CLUTCH cover, etc.. Also the seal rings on the coolant pipe that goes into the pump are suspect for leaking and not showing any obvious clues ( loss of coolant). As for the cam chain, I would not touch anything there until you can truly access the oil / coolant. No point in diving into extra cost . Yet.
"04" 950 Adventure S 37,000+ miles
2003 Harley XL883 converted to CAFE (2013-14)
"Grim Brother" #1
1stiski is offline   Reply With Quote
Old 01-04-2013, 12:04 PM   #12
norschweger OP
Oddometer: 242
Thanks once more to all of you! I really appreciate your help!
So, today I pulled the clutch cover and confirmed what we all think. There is white greasy stuff. The oil screen looks good. The oil does look more or less normal (I would say).
The guys in the "KTM"(?)-shop know less than me (in that case) and look at me as if I was an alien when I show and explain what i think. I even showed them your posts, in spanish. They do not reaaly seem to be interested. Not sure if I hurt their pride by showing them that most of what we did yesterday was not neccessary (I told them from the start that we should check the coolant issue and they said it was fine)
I said: order all the parts we most probably need. But no, he first wants to be sure what exactly we need and says in the same time that it might take 3 weeks (from Austria). Do you think he would make an effort to find out WHAT EXACTLY we need?! It is ME who is wrenching...not sure if I want to lay my trust in their hands but now I have 10000 parts everywhere and hope that the guy knows where they all belong...
Old 01-04-2013, 12:12 PM   #13
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,677
The guys in the "KTM"(?)-shop know less than me.
And that..............is why, I hesitate to buy another.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is online now   Reply With Quote
Old 01-04-2013, 12:14 PM   #14
norschweger OP
Oddometer: 242
oil filter
forgot one detail: the oil filter looks as expected, wavy.
Old 01-04-2013, 12:34 PM   #15
DockingPilot
Oddometer: 9,677
It is your waterpump seal that failed btw.
No doubt.
Frank Reinbold
Times are GMT -7.   It's 08:07 PM.
