Old 12-31-2012, 05:23 PM   #121
Hipster
Hipster's Avatar
Oddometer: 1,812
A side benefit of the external filter/pump is an approx 1/2 gallon of extra fuel capacity.
Originally Posted by cjracer View Post
So is anyone still interested in a EXTERNAL filter/ pump/ regulator setup for the 990 ADV/SD?
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 01-01-2013, 10:34 AM   #122
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,187
Yes but you already knew that
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 01-04-2013, 12:42 AM   #123
srad600
srad600's Avatar
Oddometer: 670
Originally Posted by Vicks View Post
Fot the moment there are no alternative (after market) options available for the white sock filter. I used the stock KTM filters (both sock and the roung paper filter) alongwith non-KTM fuel pump unit. Homemade filters using different filter material have also worked.
Thanks for the reply. I just finished swapping out the filters and o-rings, & went for a little 200mile ride. Shes running like a top again.
Re: the filters, they didn't really look that dirty, so no I'm thinking that the available surface area for the sock filter especially may be just too small? I'd bet a filter of similar width, but with added thickness and length would significantly improve filter longevity and performance. Looks like there is plenty of room for that.
I'd also be interested in an external pump/filter system. Disassembly and reassembly of the internal unit was not rocket science, but it does take a while, expecially with crash bar removal, etc. I'd be nice to simply detach a few lines and go.
srad600 is offline   Reply With Quote
Old 01-04-2013, 04:39 AM   #124
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,000
Originally Posted by StevenD View Post
I'm in need of them now :) any idea about the waiting time still required?
Sorry but the production process is rather bumpy and I cannot predict or give my word until I receive the items in my hands. Sorry about that.
Cheers.
Old 01-04-2013, 01:48 PM   #125
dirtyac
Ktooner
Oddometer: 36
OE Fuel Pump price increase
Just an FYI. KTM has increased the price on the 990 fuel pump to $540.00 from $495.00. The 690's fuel pump prices have also jumped to $391 for the pre '11 models and to $525 for the '11 and up. So the need for alternatives gets even greater! Thanks for the effort so far from those working on solutions.
11 KTM 690 Enduro, 06 KTM 200XCW, 07 KTM 990 Adventure S, 86 Honda Nighthawk S
dirtyac screwed with this post 01-05-2013 at 06:24 AM
dirtyac is offline   Reply With Quote
Old 01-16-2013, 04:39 PM   #126
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,973
Got the 990 SD fired up last night with the new setup!
FPR needs to be dialed in, but it runs. That's a plus. It's been so cold and icing around here I'm a little fearful of a new bike with slicks out on the road. Might have to mount up some knobbies, or stud the tires.........
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer screwed with this post 01-16-2013 at 05:44 PM
cjracer is offline   Reply With Quote
Old 01-16-2013, 04:59 PM   #127
bikyto
bikyto's Avatar
Oddometer: 2,187
FPR needs to be dialed in, but it runs. That's a plus. It's been so cold and icing around here I'm a little fearful of a new bike with slick out on the road. Might have to mount up some knobbies, or stud the tires.........
External FPR?
Old 01-16-2013, 05:42 PM   #128
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
Originally Posted by bikyto View Post
External FPR?
Fuel Pressure Regulator?
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 01-16-2013, 05:43 PM   #129
Dusty
Dusty's Avatar
Oddometer: 1,299
External FPR?
1+....
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 01-16-2013, 05:47 PM   #130
bikyto
bikyto's Avatar
Oddometer: 2,187
Thanks. I'm familiar with them. On the 990s, it's inside the tank with the fuel pump. Hence the question
Old 01-16-2013, 06:04 PM   #131
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,973
Should be up to 38F on Thurs and Fri. If the glacier recedes from the driveway, I'll take is for a test spin.
Best chance before it's down to -5F this weekend.
Old 01-16-2013, 06:51 PM   #132
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
Ah clearly I misunderstood the question. :)
Old 01-20-2013, 08:50 AM   #133
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,973
Yesterday I got out on the test bike for a lap around the neighborhood.
This bike was in a front end crash with a car. 3,200 miles. Front rim is bent - won't hold more than 20 psi when tire is cold (20F). Radiator was smashed - I fit a 950 ADV Radiator in for test purposes. Oil tank was cracked - welded that back up to seal it. Hung the headlight back on with a few bolts and zip ties.
No point to stick a bunch of money in this as a test "RAT" bike. I've got other ideas for that in the future.
As long as it runs and is ride able, I'm happy.
I have more adaptor plates made, o-ring sealed to the tank with pick-up and return line fittings. I'm running a CPR filter kit on the bike so I have room to fit the external Filter, Pump, FPR.
The FI light is blinking and I need to look it over for vacuum leaks and confirm SAS and all the junk were removed properly once it warms up and I have more time.
Well...... The bike runs, idles great, revs nice. I let it idle for about 20 min and it was stable. Fuel pump stayed cool to the touch. Fuel lines were cold, so that's a plus. Now it's time to toss on the gear and helmet.
Remember, Flat front tire with dinged up rim.....
When pulling out of drive, RPM revved up a bit..... something I failed to check in my excitement. Throttle cable play from lock to lock. I guess something needs a look at when I get a chance. NO biggy for now though. Let see what it's like.
Well.... It's no ADV. This thing is LOW, and planted, but still has room for my 6'4" body. Steering was very heavy, Low air in tire, but the engine felt nice with a small hick up off bottem. Not sure if that's mapping, with all the mods and screwing around or the NEW FP setup. Straight line, this thing comes alive in a big way around 5,000 RPMs. Front end up...... Ooops. upon contact to ground I think more air got pushed out of tire. Very flat now. Hard to corner. Time to head back to the garage before I'm in the ditch. Big smile though. This is going to fun. This would be a blast at a track day.
I'm happy with the first ride even with the small issues. New bike to me and this should be a great test bike for Engine and FI mod testing in the future. Easy to do engine swaps and strap down to dyno.
These are the same rims as I use on the 17" ADV/SE rim conversion so I'll put a new front rim on it when time and weather allows and get out for round 2.
The Tank adaptor plates are complete and if anyone is interested in one to build there own kit, contact me.
I hope to have a complete External 990 FI pump kit ready in Spring. This should install and fit very well on a 990 ADV
It's 10F hear now, so bike is parked until it warms up a bit, at least back to 40F.
cjracer screwed with this post 01-20-2013 at 08:03 PM
Old 01-20-2013, 10:14 AM   #134
bikyto
bikyto's Avatar
Oddometer: 2,187
Count me in!!!!
Old 01-20-2013, 01:10 PM   #135
pilacs
pilacs's Avatar
Oddometer: 72
Thumb
I'm in.
pilacs is offline   Reply With Quote
Times are GMT -7.   It's 08:01 AM.
