Old 01-02-2013, 12:25 PM   #16
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,557
Originally Posted by corndog67 View Post
I don't understand why you would get an expensive option when you don't want ABS? Or is the ABS standard? Personally, I don't want it myself. I'm one of those old fucks that thinks (probably wrongly) that I can brake better than the computer. Just wondering.
ABS was standard and the only thing I could find within 3 states. BMW's ABS system works very well but KTM didn't quite pull it off. I actually found it to be more of a hindrance than a help.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee
Katoom119 is offline   Reply With Quote
Old 01-02-2013, 12:35 PM   #17
JerryH
Vintage Rider
Oddometer: 1,878
First of all, I don't own a KTM. But I am about as anti ABS as it is possible to get. EVERYBODY else seems to want ABS, and many have refused to buy a bike they otherwise liked because it didn't have ABS. I never understood the appeal of ABS, and would much prefer to control the brakes myself. The reason I posted this is I have got a lot of not so nice comments about my opinions on ABS, and now I see a thread by someone who WANTS to disable it? Can you explain why you would want to disable something that most riders would gladly pay over $1000 for?
Save the environment. STOP the developers.
"You can't please everyone, so you got to please yourself" Ricky Nelson
JerryH is offline   Reply With Quote
Old 01-02-2013, 12:51 PM   #18
spencergt66 OP
Oddometer: 359
Because when the pavement ends and the dirt begins I dont always stop sometimes I speed up, and when a corner comes up it is only then @ 85mph that I realize the FUCKING ABS is still on and im not even Kind of slowing down . Or you stop on a trail shut the bike off to BS for a sec or check a map take off down a hill and remember half way down that the ABS reactivated since you restarted the bike .. Its a Dirt bike I ride it like one and it should work like one
spencergt66 is offline   Reply With Quote
Old 01-02-2013, 04:23 PM   #19
Capt.saveaho
Capt.saveaho's Avatar
Oddometer: 273
When is abs good... When you aren't paying attention, like when you are just cruising, looking at the scenery and OH SHIT!!!! I HATE abs but it has saved my life before, it has almost cost me my life as well. I am a proponent for a switch which is what I plan on doing. I have ridden with a number of ex-racers and they all say the same thing, it's good for those oh shit moments, where most accidents happen, but when you're riding hard or in the dirt forget about it. There's my 2 cents.
2007 525exc
2011 990 Adventure with 08 S suspension!!!
13hp road race 50
Capt.saveaho is offline   Reply With Quote
Old 01-05-2013, 09:36 AM   #20
spencergt66 OP
Oddometer: 359
Hmm
Was going to order front brake lines but I see an issue I have a high fender kit and need 2 longer brake lines not the 1 long and 1 cross over? can I just order 2 front lines (longer tupe) also wont I need a long banjo bolt for the Brake master to tie in 2 brake hoses?
Old 01-05-2013, 09:57 AM   #21
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 849
I think you'd be better off having a shop make you up the two lines
you'll need. They can make the perfect length your bike needs, for the
way you have it set up ( higher bars, taller bar risers, etc.)
Yes you will need a double banjo.
Be sure to spend some time routing the lines around the clutch and other wires. On the low fender bikes when the suspension is compressed the brake line flex is below the brake line bracket/junction at the lower triple clamp. With the high fender and two lines the lines will flex/ extend up above the handle bars. Potentially rubbing or hanging up on wires, cables or brackets, GPS etc.
Max
Da oggi la strada
é senza limiti
MAXVERT is offline   Reply With Quote
Old 01-05-2013, 11:15 AM   #22
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 4,909
Originally Posted by spencergt66;[URL="tel:20402235"
20402235[/URL]]Was going to order front brake lines but I see an issue I have a high fender kit and need 2 longer brake lines not the 1 long and 1 cross over? can I just order 2 front lines (longer tupe) also wont I need a long banjo bolt for the Brake master to tie in 2 brake hoses?
are you thinking of the 950 setup?
The '07 & '08 990S model brakeline setup is basically the same as the standard ABS model around the low fender/high fender area.
I can't argue with going the custom route, it's likely cheaper., and maybe better for some setups
I picked the lazier way. Point and click.
Ride OREGON First .com
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 01-07-2013, 04:21 PM   #23
DirtJack
DirtJack's Avatar
Oddometer: 347
An ABS defeat switch in the rear sending sensor shuts off the ABS instantly. If left in the open position, the default is no ABS the next time you start the motor. Put the switch where it can be easily reached with your left or right thumb. Works for a lot of us.
Proud to be supporting Pyndon in the 2013 Dakar !
2007 KTM 990 Adventure
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
1998 KTM 400 RXC (sold)
DirtJack is offline   Reply With Quote
Old 01-07-2013, 05:30 PM   #24
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 950
Send a message via Skype™ to ciedema
For me I like the idea of it on the front, but not the back. That said on my '11 you have to nail the brakes pretty hard for it to activate.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
No Four Wheel Drives, No Fixers and No Fricken Whingers
Personal Attacks - the last refuge of the intellectually impaired.
ciedema screwed with this post 01-07-2013 at 05:46 PM
ciedema is online now   Reply With Quote
Times are GMT -7.   It's 11:52 PM.
