01-05-2013, 10:02 AM
#16 |
NoMoTDM still Gary
Oddometer: 3,710
Go buy yourself a cheap multimeter. Check the voltage of your resting battery. It should be at least 12.5 volts, preferably higher. Check the battery when cranking the engine. It should not drop below 10 volts. Check it again with the engine running. I would expect some where around 14.4 volts.
Those are ball park numbers and there are posts that are more exact with the regulator used on the F800gs. If you are getting around 14.4 volts with the engine running, it is not your stator. If the voltage is in the 15 teens or higher, it is the regulator. Readings in the 13 teens with a partially charged battery, your stator is probably going. Voltage the same as your resting battery voltage, is a clue your stator is shot. Big drops in voltage at the battery when cranking, usually means a battery short. Battery voltage drops below 12.5 after being fully charged indicate a bad battery. Until I did some voltage checks, I would not rush out and buy something yet. Temps in the low 30's makes the initial start on my bike a slow affair.
BMW Motorrad USA customer service: "We make superior motorcycles and continue to improve them." |
01-05-2013, 10:29 AM
#17 | |
Oddometer: 2,820
Erling |
01-05-2013, 03:04 PM
#18 | |
Oddometer: 470
And, whats important, to have a good humor. And you have. Thats why I like reading your posts. Simple as that. No clue about radar systems but I worked as aircraft mechanic so our jobs were somehow linked.... ![]() Regards Steve |
01-05-2013, 05:15 PM
#19 | |
Oddometer: 2,820
Cheers....![]() ![]()
Erling |
01-06-2013, 03:48 AM
#20 |
Oddometer: 470
01-08-2013, 03:58 PM
#21 |
It's been useful
Oddometer: 198
Sorry for the slow reply, I don't see why this wouldn't be covered under warranty... the fellow in the video had a company rewind his stator for £120 (instead of replacing the whole alternator/generator from BMW for an eye-watering amount of cash).
Planned: Alpine Adventure loop (FR/BE/LU/MC/IT/CH/LI/AT/DE/NL)—Jun 2013 My F800GS blog Brand new from the ground up with an emphasis on aesthetics— ride reports, photo reports, tips and experiences |
01-21-2013, 07:49 AM
#22 |
2wheeledadventurer
Oddometer: 12
I thought I would close my personal loop - I had a bad battery. My 2009 still had the original Exide with ~200 CCA. I replaced it with a Yuasa YUAM6RH4H YTX14H-BS Battery, pushing out 240 CCA and I've had zero issues with cold weather starts since then. The battery is definitely more powerful and the engine catches noticeable quicker than when I first bought the bike.
Its been outside during my workdays (I park on the street). Today its a balmy 26 degrees in NYC ( -3C for you non 'Muricans) I'm going to go play with my multimeter when I get home just for shits and giggles... Steve |
01-21-2013, 12:39 PM
#23 | |
It's been useful
Oddometer: 198
