Old 01-05-2013, 11:42 PM   #1
DiabloADV OP
Semi-Occasional
Oddometer: 1,534
Shift linkage boss?
When did the airhead frames first get the boss to which the shifter linkage attaches? As opposed to the shifter that attaches directly to the shifter shaft on the gearbox...
I find pics of /5 and /6 bikes without it, and later bikes with it. But when did it first appear?
'74/'70 R98/6/GS Traveling Bike (construction under way)
'91 Bill Holland Steel w/Dura Ace
DiabloADV is offline   Reply With Quote
Old 01-06-2013, 12:29 AM   #2
Rob Farmer
Rob Farmer's Avatar
Oddometer: 3,733
I'm not too sure but I thought it was 77/78 but a lot of bikes had it retrofitted because it improves the gear change so much.
Rob Farmer is offline   Reply With Quote
Old 01-06-2013, 01:33 AM   #3
carpetburn
Oddometer: 110
correct- i fitted one to my/6
carpetburn is offline   Reply With Quote
Old 01-06-2013, 02:05 AM   #4
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 1,600
It's easy enough to find pix of 1978 models with the direct gear lever, and even some 1979 ones. I'm guessing it's during the 1979 model run starting with the straight rod with the rubber bellows cover.
edit: Have a look at this 1978 brochure...
boxerboy81 screwed with this post 01-06-2013 at 02:15 AM
boxerboy81 is offline   Reply With Quote
Old 01-06-2013, 10:08 AM   #5
rambozo
rambozo's Avatar
Oddometer: 75
Both my 78 and 79 have the rubber bellow shifter as per that photo
Robs probably right with 77/78 year
rambozo is offline   Reply With Quote
Old 01-06-2013, 10:28 AM   #6
CanadaBiker
Oddometer: 120
Does it really improve shifting that much?
I have a direct on my '77, but I haven't been able to put many miles on the bike since I got it. Although, my left foot feels a bit cramped on the peg and that the shifter doesn't stick out far enough to get my toe under it. But I wonder if changing to the linkage would improve that specific issue.
1977 BMW R100/7
CanadaBiker is offline   Reply With Quote
Old 01-06-2013, 11:02 AM   #7
outfit
outfit's Avatar
Oddometer: 609
I've retrofitted both my Mono and /7 to direct year's ago The gear linkage may well have been okay when new, but the sloppiness soon set's in. Anyway's I think it was just a publicity stunt by BMW in answer to press complaint's.
outfit is offline   Reply With Quote
Old 01-06-2013, 11:57 AM   #8
DiabloADV OP
Semi-Occasional
Oddometer: 1,534
My bike is a 74 90/6, and has the shifter boss. So I guess it was retro-fitted. How would somebody tell a /7 frame from a /6 frame?
Old 01-06-2013, 12:28 PM   #9
supershaft
because I can
Oddometer: 6,048
It had to of been late '78? I remember lots of our customers making the retro-switch. Lots of people said that it improved shifting quite a bit. I do too. Sloppy? The have replaceable bushings, bearings, and bolts. I have repaired quite a few of them and then they are like new again.
supershaft is online now   Reply With Quote
Old 01-06-2013, 09:51 PM   #10
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 492
Serial number?
If your gonna be dumb, you gotta be tough
When you get knocked down you gotta get back up,
I ain't the sharpest knife in the drawer but I know enough, to know,
chollo9 is offline   Reply With Quote
Times are GMT -7.   It's 10:41 PM.
