Old 01-03-2013, 05:44 PM   #1
Captdan OP
Oddometer: 120
machine services in Greenbay for drive shaft repairs?
Gents, my r1200 GSA tossed a forward u-joint recently. I've got a lead on Machine services in Greenbay, seems they replace the u-joints with Servicable ones for a decent price. Would certainly appreciate hearing from anyone here that knows first hand if they are good at what thy do or not. I know about Bruno in Canada, but would rather stay with a US company if possible.
1965 Cushman super silver eagle, 1968 BMW R-60/2, 1974 R-90/6 cafe, 2008 R-1200 GSA.
Captdan is offline   Reply With Quote
Old 01-03-2013, 07:57 PM   #2
BKFoster
Oddometer: 134
I just read this.....
.....it may help.
http://www.advrider.com/forums/showp...0&postcount=35
BKFoster is offline   Reply With Quote
Old 01-04-2013, 03:09 PM   #3
Captdan OP
Oddometer: 120
Originally Posted by BKFoster View Post
Thanks, sending to Bruno. Never heard anything bad about his work.
Old 01-04-2013, 08:24 PM   #4
def
I have little to say
def's Avatar
Oddometer: 6,337
Send a message via Skype™ to def
The interesting thing about Jim Moore's experience with the Green Bay outfit is that after the GB refurbished driveshaft failed, his post says he replaced the front half with an extra unit he had laying around. That unit also failed 10,000 miles later. Something seems amiss here.
At this point, I would not blame an outfit that has been doing driveline repairs since the early 1950s, in Wisconsin, no less.
Remember, there are a bunch of smart Germans in Wisconsin who not only make fine cheese and sausage, but have been running successful businesses dealing with mechanical systems. Briggs & Stratton, Kohler and Allen-Bradley come to mind.
And, while I believe Bruno is probably a fine fellow, I would speak to the Green Bay outfit and ask them what happened to the failed shaft before discounting them offhand.
def is offline   Reply With Quote
Old 01-04-2013, 09:16 PM   #5
Captdan OP
Oddometer: 120
Good points... There certainly is a price difference between the two. I'm just looking for the best fix as I don't relish the idea of another drive shaft explosion on a major trip. Really sucks I can tell you.
Old 01-05-2013, 11:47 AM   #6
def
def's Avatar
Oddometer: 6,337
Well Cap't Dan, I agree...a breakdown on a trip is more than inconvenient.
I just cannot imagine that the Green Bay outfit did a poor job of repair on the BMW driveshaft. We just don't know enough to make an educated guess.
If it were me, I would call them and explain your concerns and point them to the post dealing with the driveshaft failure.
If I ever need driveshaft repairs, I'll be speaking with them before I decide which repair shop to use.
I'll bet they would like to see the failed shaft and determine the mode of failure.
Here is what I would ask:
1- Do they offer a warranty on their work? What is the source for the parts they use?
2- Are there any particular challenges to performing a reliable repair on these BMW shafts?
3- Do they repair the shock rubber portion of the shaft assembly?
4- How do they balance the shaft after repairs?
These are all good questions that they should be willing to answer.
Old 01-05-2013, 11:51 AM   #7
Iron Rey
Oh shit, not him!
Iron Rey's Avatar
Oddometer: 731
I cannot speak for their ability to repair/rebuild/remanufacture motorcycle driveshafts but I have used them for years to make driveline gear for my engine testing business, from less than 5HP to over 16,000 HP and have never had an issue, their engineering department is top notch. Having said that, I really do not believe these shafts would be their forte, what they CAN do is harmonically balance anything in relation to speed and engine configuration, it is a true science.
Iron Rey is offline   Reply With Quote
Old 01-05-2013, 02:17 PM   #8
BlairBear
Oddometer: 132
drive shaft
They did mine, about 1k on it so far. Mine didn't come apart, so no damage. Happy with what I got back. It was 225 or 250 to replace both joints. I think all they do is drive train service. I would use them again. Look at their web site that convinced me. When you call them ask for Mitch ( shop forman, I think). He knew exactly what I was talking about. Took 5 days round trip.
BlairBear is offline   Reply With Quote
Old 01-05-2013, 07:34 PM   #9
Jim Moore
Jim Moore's Avatar
Oddometer: 10,335
I may have explained it poorly the first time I told the story. Let me try again. At 100k miles on my GS I decided to replace the driveshaft as part of a minor overhaul. I bought a used driveshaft and sent it to MSI. When I got it back I installed both halves of the refurbished driveshaft and kept my original driveshaft as a spare. 5000 miles later the front half of the refurbed driveshaft failed. I replaced the front half with my old front half. The rear half failed at a later time. I replaced it with the other half of my old driveshaft. The bottom line for me is that both u-joints on the driveshaft refurbed by MSI failed in a relatively short period of time.
Jim Moore
"Marines good. Press bad"
-Turkish
Jim Moore is offline   Reply With Quote
Old 01-06-2013, 03:02 PM   #10
bemiiten
SWM Adventuer
bemiiten's Avatar
Oddometer: 4,153
Jim, Did they machine the driveshaft to accept circlips or weld washers over the caps? Also, did you grease the u joints before you installed the driveshaft? I'm assuming the joint failed, or was their a problem with the yoke?
bemiiten is offline   Reply With Quote
Old 01-07-2013, 06:04 AM   #11
Jim Moore
Jim Moore's Avatar
Oddometer: 10,335
It was a couple years ago, but I seem to remember that it looked to me like they welded something over the caps. The u-joints were greased when I got them back. They told me I was going to have to re-grease them every year or so. I never got to that point. The joints themselves failed.
Jim Moore
-Turkish
Old 01-07-2013, 08:30 AM   #12
kimokk
kimokk's Avatar
Oddometer: 103
Did you get to talk to their customer service or tech rep? What was their response? Thanks.
'09 BMW R1200GSA Adventure!
IBA #49426
kimokk is offline   Reply With Quote
Old 01-07-2013, 08:34 AM   #13
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,181
Machine Services in Greenbay. Is there web address and phone number a secret and you can't post it. Googled it and found all kinds of stuff.
Is this them: http://www.machineservice.com/techni...joint-failure/
Customer Service: 1-800-677-8711
scooteraug02 is offline   Reply With Quote
Old 01-07-2013, 09:35 AM   #14
Jim Moore
Jim Moore's Avatar
Oddometer: 10,335
Yeah, I sent the first one back to them and they replaced it for free. After the second one I didn't bother. They were perfectly pleasant to work with, but my overall goal was to make the bike more reliable.
Jim Moore
-Turkish
Old 01-07-2013, 09:49 AM   #15
Tbone
off-ramp slayer
Tbone's Avatar
Oddometer: 4,027
14k on my rebuilt from Machine Services with no issues.
http://advrider.com/forums/showthread.php?t=785520
Tbone is offline   Reply With Quote
Times are GMT -7.   It's 05:00 PM.
