01-06-2013, 08:34 PM
#16 | |
R90SS/6
Oddometer: 153
01-06-2013, 09:04 PM
#17 | |
because I can
Oddometer: 6,082
[EDIT] Oops mattcfish! There is ambiguity in the numbers from BMW too! I knew there was in the wording but . . . . The same amount? Three degrees is THE classic amount to change a single cam. You can't do it much more without running into troubles and if you do it much less it won't make much difference. The room for adjustment is SMALL. If you think about it, hopefully the need for a mid stroke arrived at TDC and the biggest degree wheel that you have room for will start making sense. The tiniest difference is a BIG difference! IMO rocker arm ratios and swing radii are best left out of the picture if possible! Spec duplication is key and super touchy! I have worked with people trying to time cams with the TDC determined at TDC. WAY too much crank to piston movement at TDC to even get close as far as duplicating cam specs! It's simple geometry! Usually retarded for emissions? I don't know but it makes since to me to advance them. Why? Advancing them makes them more efficient at lower rpm. Emission testing is done at idle and cruise ie low rpm. Remember that it is easy to get all this stuff mixed up in your head when you are writing about it. Just one for instance: A BMW service bulletin that says that 336's had there timing retarded. Wrong. It's advanced. supershaft screwed with this post 01-07-2013 at 01:03 PM |
01-07-2013, 01:47 AM
#18 | |||||||||||
Oddometer: 327
The BMW service bulletin that is floating around here in Germany is from July 1980 and it says: The position of the key slot of the cam is changed by three degrees. The timing numbers show an advance of six degrees with respect to the crank.
Are these specs correct? These are the same numbers shown here: http://bmwmotorcycletech.info/cams.htm Anyone ever checked them? |
01-07-2013, 09:47 AM
#19 |
Oddometer: 720
What does " remapping the bean can curve " mean?
I thought they had bobweights for advance?
01-07-2013, 10:29 AM
#20 | |
Oddometer: 327
Geometry of these bushings can be found here (under Mechanik): http://www.derdicke.de/mot/dz.html |
01-07-2013, 12:58 PM
#21 | |||||||||||
because I can
Oddometer: 6,082
That I hadn't noticed. Like I just mentioned earlier, I have noticed other errors in the 336 bulletins. Like I have pointed out many times before, I have never timed mine. I am just going by what I have heard and read and seen with other cams as far as saying that cam specs are at the crank but then again I am starting to see all kinds of weird ways to list cam specs out of Germany such as specs with 0 lift compared to most all other cam sources I have seen and read of. I had noticed ambiguity in the wording but not the numbers until now. If I am wrong I won't feel too bad because when most tuners say they have advanced a cam three degrees, they mean at the lift check point with the wheel on the crank. They don't mean it's really 1.5 degrees because we know that the cam spins at half the speed of the crank? Or put another way: Most tuners are mostly talking and concerned with when that intake valve is closing in relation to the crank just like all the other spec numbers are in relation to the crank. Timing the valves IS the whole point! Pj has timed his. supershaft screwed with this post 01-07-2013 at 01:18 PM |
01-07-2013, 01:09 PM
#22 |
because I can
Oddometer: 6,082
They do have bob weights in the advance. You can limit or extend the weights' travel with the weight stops thusly changing the advance range in degrees and then you can alter the weight's weight and extend or reduce the curve in relation to the rpm. The weight stops bend back and forth without breaking very easily. I have done it dozens of times.
01-07-2013, 01:23 PM
#23 |
combustophile
Oddometer: 1,559
That is unfortunate, as you offer a lot of good and interesting information on the topic.
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton "...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater- |
01-07-2013, 01:36 PM
#24 | |
Oddometer: 720
Gottcha, I played around with the mapping of my ignition but only enough to replace the Boyer and its creeping advance. The Ignitech is nice bit of kit, comes with rev limiter and you can adjust the curve with the motor running. Would work a treat on a road bike. ![]()
01-07-2013, 01:42 PM
#25 | |
because I can
Oddometer: 6,082
01-07-2013, 01:46 PM
#26 | |
Oddometer: 327
Now we all miss things from time to time.
For example I completely missed this Quote:
Back to timing: of course specs are with respect to the crank. Anything else would be pure nonsense IMO. Back to the question, how the late 336 are timed. PJ has the numbers? PJ????? |
01-07-2013, 01:58 PM
#27 |
because I can
Oddometer: 6,082
I have timed other cams but not a 336 but, still, I am going to be real surprised if BMW advanced the 336 six degrees and has been calling it three degrees all these years. One thing that is starting to sink in is something that many a tuner has warned me about cams. There are no industry standards! Trends but not standards.
I am just glad we have for the most part moved on past discovering specs with lift check points. |
01-07-2013, 01:59 PM
#28 | |
Oddometer: 327
http://www.advrider.com/forums/showthread.php?t=830041 Some info Voltaire may not have: you can run it with an inductive trigger like Voltaire or a hall sensor. Means AFAIK that you could use the BMW unit (if you can freeze the mechanical advance). Some guys over here use a complete can unit from a Volkswagen which has no advance. In case you are interested I would check these information. As I prefer another solution I don't pay too much attention to the threads about that topic so I'm not a 100% sure. Alternatively the german reseller here offers the complete package with a trigger mounted on the alternator. Ignitech does not offer special BMW parts. |
01-07-2013, 02:18 PM
#29 |
Oddometer: 327
01-07-2013, 02:27 PM
#30 |
Old and in the way
Oddometer: 161
3 Degrees maximum change?
[QUOTE=The same amount? Three degrees is THE classic amount to change a single cam. You can't do it much more without running into troubles and if you do it much less it won't make much difference. The room for adjustment is SMALL. If you think about it, hopefully the need for a mid stroke arrived at TDC and the biggest degree wheel that you have room for will start making sense. The tiniest difference is a BIG difference! IMO rocker arm ratios and swing radii are best left out of the picture if possible! Spec duplication is key and super touchy! I have worked with people trying to time cams with the TDC determined at TDC. WAY too much crank to piston movement at TDC to even get close as far as duplicating cam specs! It's simple geometry!
Usually retarded for emissions? I don't know but it makes since to me to advance them. Why? Advancing them makes them more efficient at lower rpm. Emission testing is done at idle and cruise ie low rpm. Remember that it is easy to get all this stuff mixed up in your head when you are writing about it. Just one for instance: A BMW service bulletin that says that 336's had there timing retarded. Wrong. It's advanced.[/QUOTE] I have been running my R1200GS cams 9 crank degrees advanced for 5 years and 25,000 miles. Doing so gave me more midrange power (which is what I wanted) with the possible expense of some top end. I rarely go 7,000+ rpm's anyway so I wouldn't notice. Modern auto engines with variable valve timing, while not Airheads, advance cam timing as much as 7 degrees and retards it up to 45 degrees for a total of 52 degrees variability. Having been involved in drag racing for several decades I am very familiar with the effects of advancing, and in my case more often retarding cam timing to change power characteristics. In my experience cam timing changes of more than 3 degrees are commonly done but usually for reasons other than producing maximum peak horsepower. Chuck |
