Old 01-07-2013, 06:21 AM   #1
disston OP
ShadeTreeExpert
disston's Avatar
Oddometer: 10,215
Cracked Luggage Rack
I have the Krauser side bags on my '75 R90/6. The racks are chrome. The one on the right side has a crack in the weld that holds one part of it together. It is cracked all the way through for almost one half of it's circumference. So I figure to have this welded and wonder (since I don't do welding) do I look for MIG Welding or TIG Welding or just what do I ask for.
This should be a small job and I can take the racks off if need be but do I or should I remove the racks to weld them? Can it be repaired in place?
The metal inside the cracked area is rusted. Should I clean the rusted part down to bare metal before looking for a welder?
What should this cost me?
---Albert Einstein
Old 01-07-2013, 06:55 AM   #2
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,529
Take the rack(s) off and drop them off at the welder. It's thin tubing and he'll need to use his best weld-foo. Let him do the prep. On the cost, "if you have to ask, you can't afford it."
--Bill
'73 R60/5 Toaster
Old 01-07-2013, 07:03 AM   #3
rambozo
rambozo's Avatar
Oddometer: 585
I'd look into getting your welder to add a strengthening plate
while he's at it
rambozo is offline   Reply With Quote
Old 01-07-2013, 07:36 AM   #4
no5s
Terror at 2 mph
no5s's Avatar
Oddometer: 357
Rack
If you are going to rechrome, it would be much cheaper to buy a good used rack.
12 Super Tenere
84 R80 ST
64 R50/2
65 Triumph TR6 Desert Sled
65 Triumph T100SC TT Bike
no5s is offline   Reply With Quote
Old 01-07-2013, 08:57 AM   #5
disston OP
ShadeTreeExpert
disston's Avatar
Oddometer: 10,215
Well I don't think I will rechrome. I think this was broken many years ago in a 360* flip over. The bike has always been just so so. I don't have any bent parts and the bags were not cracked. The front end was slightly bent but I fixed most of that last year. Sub Frame might be slightly bent but if it is it matches the rest of the bike. I have the racks off right now. I'll look around for a welder. Bob's might even do it. Or know somebody who will.
---Albert Einstein
Old 01-07-2013, 09:50 AM   #6
ME 109
ME 109's Avatar
Oddometer: 3,135
Mig, tig, arc or braze. All will work.
Tig will be neatest straight up, Mig will clean up, arc if you have to, brazing will be strong enough.
All will destroy chrome in the immediate area.
Lord of the Bings, kangaroo farmer
ME 109 is online now   Reply With Quote
Old 01-07-2013, 10:13 AM   #7
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,606
Yeah, method doesn't really matter so much in this case. They'll probably use mig or tig though. Additionally you can have them grind the welds flush and blend them them with the surrounding material. If you don't plan on rechroming, you'll at least want to hit the welds with some paint to keep them from rusting.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-07-2013, 10:50 AM   #8
pecos
BAM!!
pecos's Avatar
Oddometer: 552
Don't waste your time. Buy a new side rack for $35 off ebay and be happy. All of this we are saying to encourage you to take an interest in the things that make up the systems on your motorcycle.
pecos is offline   Reply With Quote
Old 01-07-2013, 11:16 AM   #9
disston OP
ShadeTreeExpert
disston's Avatar
Oddometer: 10,215
You got me good.
Guess I'll look for used racks. I can still use this one. It is pretty solid when on the bike.
---Albert Einstein
Old 01-07-2013, 11:20 AM   #10
ignatz72
call me iggy
ignatz72's Avatar
Oddometer: 626
That was good pecos! I just read the other thread, and that gave me a good chuckle.
Current: 93 R100GS, 03 XR650R
Prior: 73 CB350, 77 R100/7, 83 R100RT, 04 XR650L
I love every motorcycle I've owned and even some that I haven't.
ignatz72 is offline   Reply With Quote
Old 01-07-2013, 12:32 PM   #11
supershaft
because I can
Oddometer: 9,116
If they are like most all BMW tube saddle bag racks, welding them will not work because they are brazed. Gas, stick, MIG, TIG will make a mess of them. For some reason, nothing but sloppy crap welds can be had anywhere close to brazing. They need to be re-brazed. I braze gussets on them and use the back cross brace. They crack all the time without them.
Old 01-07-2013, 12:40 PM   #12
pecos
BAM!!
pecos's Avatar
Oddometer: 552
Just having fun.
Old 01-07-2013, 01:11 PM   #13
disston OP
ShadeTreeExpert
disston's Avatar
Oddometer: 10,215
Just having fun.
You had me rolling on the floor.
Sometimes I am full of a lot of wordy BS. I used to write what is called "Copy". Advertizing for radio. I tend to speak in lines sometimes too.
---Albert Einstein
Old 01-07-2013, 03:34 PM   #14
Bill Harris
Oddometer: 8,529
You are multidimensional, Charlie...
--Bill
'73 R60/5 Toaster
Old 01-07-2013, 06:12 PM   #15
disston OP
ShadeTreeExpert
disston's Avatar
Oddometer: 10,215
I was an AM radio Disc Jockey when I was in High School. Some of the other older guys will remember how it used to be. It wasn't unusual in those days to work at a small time radio station when in High School. I also worked part time for AFRTS when I was over seas in the Army. And went back to radio after the Army. It's really a much longer story. I tell this story sometimes in some of the Inmates Threads like in the MNwilly Memorial Stay Sober Thread.
It's been over 41 years now since I was last On the Air. Some parts of such things are getting foggy and sometimes the memories are like it happened yesterday.
Sorry for all the digression. Now back to clutch repair.
---Albert Einstein
Times are GMT -7.   It's 02:36 PM.
