Old 01-07-2013, 10:20 AM   #1
go2cnavy OP
go2cnavy's Avatar
Oddometer: 545
Battery Tender Lead to Jump Start
I have a battery tender lead hard wired to my 990 to make battery maintenance easier.
I am doing a 4-day trip in June where three of us will be riding in a team. Instead of carrying jumper cables, I was thinking that if everyone else had a battery tender cable hardwired to their bike, we would simple carry a long battery tender cable extension to jump a bike if needed. Has anyone tried this?
Is it May yet? RR15
go2cnavy is offline   Reply With Quote
Old 01-07-2013, 10:33 AM   #2
wpbarlow
Oddometer: 11,113
Originally Posted by go2cnavy View Post
... Has anyone tried this?
I tried it once as a test before installing a new battery. The wire/plugs got hot enough to get very soft so I discontinued the test.
I'd suggest bringing lightweight jumper cables.
wpbarlow is offline   Reply With Quote
Old 01-07-2013, 10:48 AM   #3
go2cnavy OP
go2cnavy's Avatar
Oddometer: 545
Thanks. That's what I needed to hear. I wasn't sure if the gauge of the BT wiring would support jump starting. I do like the below bump start option, but I have a rekluse so it would be a pain for me to do.
Is it May yet? RR15
Old 01-07-2013, 11:00 AM   #4
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,822
I've made one similar and have used it. I won't try it as a "jumper cable" but will hook two bikes together and let the donor bike run for a while to give a little juice to the weak bike.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 01-07-2013, 11:01 AM   #5
FakeName
FakeName's Avatar
Oddometer: 1,822
BTW: A rekluse on a 990 is easy to bumpstart. A simple adjustment to the clutch slave makes the clutch pretty much "normal" again.
2014 500EXC Black
Old 01-07-2013, 12:19 PM   #6
go2cnavy OP
go2cnavy's Avatar
Oddometer: 545
Thanks. I just hate doing the freeplay gain trailside.
Is it May yet? RR15
Old 01-08-2013, 02:56 PM   #7
Stumpalump
Oddometer: 128
My tender wires have a fuse that would blow if I jump started it from there.
KTM 950A
Rokon 2X2
Montesa 315R trials
KTM 200 EXC.
XR400
Stumpalump is offline   Reply With Quote
Old 01-08-2013, 10:25 PM   #8
Fireball
Robot Doc
Fireball's Avatar
Oddometer: 2,572
I have the automotive plug installed on my battery to connect my battery tender. I also carry with me the clip on connectors to plug into my battery connector in case I ever need a jump start. Just remember if you do this to reverse the leads (black to positive, red to negative) as you'll be using these opposite of their intended purpose. Perhaps failing to do this is why a previous poster experienced blown fuses....?
More fun than clowns on fire
Fireball is offline   Reply With Quote
Old 01-09-2013, 05:54 AM   #9
Martynho
No more Chilegringo.
Oddometer: 408
Worked for me
+1 on this. Dont try to use the cable to jump start you will melt it or worse in a short time. But I have used this tecnique quite often with good result, make sure you leave the donor bike running!
Martynho is offline   Reply With Quote
Old 01-09-2013, 06:32 AM   #10
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,915
Technically, jump starting is when you connect a running vehicle up to a dead vehicle.
What are you guys saying by not jump starting? You transfer some charge from good to bad bike, disconnect wires, then try starting the bad (hopefully good) bike?
'06 KTM 950S Adventure
'12 Ram 2500, Cummins, 6-speed auto, Laramie Longhorn, RamBox.
DakarNick screwed with this post 01-09-2013 at 06:38 AM
DakarNick is offline   Reply With Quote
Old 01-09-2013, 08:10 AM   #11
Martynho
Oddometer: 408
Jump starting
Yep, precisely. Just use the cable to pass enough charge into the lame bikes battery in order for it to start.
Old 01-09-2013, 08:24 AM   #12
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,915
Thanks. That's what I thought but wanted to clarify. I was confused at first. I also added a "jump block" to my bike. It's actually from the hobby shop. It's a knurled metal "lug" with positive and negative sides. Alligator clips can clip to it. I tucked it under the right side skidplate. I can use it to charge or transfer some juice.
I have jumped my bike but only use jumper cables.
Times are GMT -7.   It's 01:32 AM.
