01-08-2013, 07:28 PM
#1 |
Oddometer: 462
Fitting an SMT screen on a 950SM?
Not sure who could best answer this but thought I would ask anyways..any thoughts on how difficult it would be to mod he tall Givi 990smt screen to fit the 950SM headlight?
http://www.ktmtwins.com/givi-ktm-990...ing-windscreen Looking at the picture it looks like it could go either way.. |
01-08-2013, 09:44 PM
#2 |
Oddometer: 462
Calsci screen
http://www.calsci.com/motorcycleinfo/KTMSMTprod.html
NOT the best looking but if this could mean a wind free cockpit..I am interested..although subjectively i think it would look worse with the 950 SM(R) headlight shape?.. The feedback on it is the most consistently great of the bunch.. Someone in the UK tinted one and i think it looks pretty good.. http://www.ktmsmt.com/viewtopic.php?f=10&t=3812 |
01-08-2013, 10:13 PM
#3 |
Oddometer: 462
01-08-2013, 10:26 PM
#4 |
Oddometer: 462
hmm aeroflow
http://www.aeroflowscreens.com/990950AeroScreen.htm
this could work on the outside of my 690 screen.. |
01-09-2013, 03:44 AM
#5 |
V-Twin
Oddometer: 260
You can also use a ktm690r screen:
KTM Part Number(s): 75008065044 Assembly is as follows: 1. Paste your whole cockpit except your lamp with painting tape; 2. Hold the glass at the right height, pushing it against the shell so that all four holes are flat against the base pressed on. 3. Mark the holes on the painters tape with a felt pen. It is important for the glass as high as possible to assemble. The top 2 holes sit with me about 1cm below the upper edge of the coaming. This is important because the lower holes in this way, exactly above the mounting bracket which are located on the rear part of the fairing located. Measure this several times carefully, so that he sits in the middle and at the right height. For this I have 4 or 5 times removed of the bowl from the counter, the 4 screws from the top cover counter to loosen. 4. The scary part .... You stand with the drill in your hand for a virgin nice cockpit section .... for drilling with 4mm, then 6.8 and finally 10mm.Ik have first made the top 2 holes and each hole after the window for monitored to determine that I was not the lead. 5. Removing paint tape. 5. Install the 4 rubber "Threaded Inserts" and then the window with the screws and washers securing. 6. Attaching the counter plate. 7. Drive it.
'10 990SMT |
01-09-2013, 12:23 PM
#6 |
Oddometer: 462
thankyou sir
Apologies for not being clearer..i have that screen fitted..very happy with it but trying to find something better either to add or exchange...
01-11-2013, 12:56 PM
#7 |
Motorcycle Maniac
Oddometer: 870
You can do an add-on Slipstreamer Spitfire screen:
Young at heart '06 950 Adventure, '07 950 SuperMoto '09 Versys (w/Woodys Adventure wheels) |
01-11-2013, 10:08 PM
#8 |
Oddometer: 462
HEYYYY WTF..where did that picture come from?? I have combed the internet..please give us more info..whats your height..wheres the wind hitting you..more pics? and a link please
THANKS |
01-11-2013, 10:21 PM
#9 |
Oddometer: 462
and nice mod with the SMT handguards
01-12-2013, 07:07 AM
#10 | |
Motorcycle Maniac
Oddometer: 870
http://www.motorcycle-superstore.com...indshield.aspx ![]() This is the best angle for me: ![]()
Young at heart '06 950 Adventure, '07 950 SuperMoto '09 Versys (w/Woodys Adventure wheels) mcmann screwed with this post 01-12-2013 at 07:17 AM |
01-12-2013, 12:32 PM
#11 |
Oddometer: 462
and it looks like you have a little screen behind it?
01-12-2013, 12:38 PM
#12 |
Oddometer: 462
15 might not be tall enough for me..may look for something like this
http://www.ebay.com/itm/Slipstreamer...407e7f&vxp=mtr 17inch tall..the 690 screen is 9 inches tall unless i could get that 15inch to start at the top of my 690 screen? does it work like that? lukeinlondon screwed with this post 01-12-2013 at 12:46 PM |
01-12-2013, 12:51 PM
#13 |
Motorcycle Maniac
Oddometer: 870
Yes, it sits on top of my summer 690 screen. I just lowered it one inch to reduce some helmet noise. I would not want a taller over shield.
With 690 screen:
01-12-2013, 01:04 PM
#14 |
Oddometer: 462
so the 'slip' is mounted half way up your summer screen for better height?
01-12-2013, 02:42 PM
#15 |
Motorcycle Maniac
Oddometer: 870
Young at heart '06 950 Adventure, '07 950 SuperMoto '09 Versys (w/Woodys Adventure wheels) mcmann screwed with this post 01-13-2013 at 05:14 AM |
