Old 01-08-2013, 09:40 PM   #1
FakeName OP
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,874
Ultra heavy duty tubes on the street
Forgive me, I'm big bike n00bish.
I'm buying my first set of tires (606/908)for the 990, and the website from which I purchase tires warns that UHD (or even HD) tubes should not be used on the street. While I often ride the road between dirt destinations, I've been using UHD tubes on the 525 for years without event.
Is there some reason about which I'm ignorant that the UHD tubes are a hazard on the big bike, on the street? I'm sure "heat" is one possible explanation.
Thanks.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 01-08-2013, 09:58 PM   #2
corndog67
Oddometer: 1,281
I recall hearing that there were heat buildup issues at the speeds the big bikes are capable of, probably a fear of lawsuits or something if one of them fails at some seriously high speeds. I guess tubes move around a bit inside of a tire carcass, and the heavier tubes probably build more heat.
corndog67 is offline   Reply With Quote
Old 01-08-2013, 10:04 PM   #3
srad600
srad600's Avatar
Oddometer: 688
I don't really know what the supposed issues with UHD tubes are but I do know that I run (and have run for the past 7,000 miles or so) Michelin UHD tubes in both my tires. I've also run the bike at some serious speeds (80+ offroad , and well over 100 on tarmac - closed course of course ) with no issues so far. The high speed riding is irregular and of course, something bad could happen one day...but so far no issues.
srad600 is offline   Reply With Quote
Old 01-08-2013, 10:27 PM   #4
buzybraza
buzybraza's Avatar
Oddometer: 381
I have run UHD tubes on my SE for over 6k miles exclusively on the highways with no problems. Several + several sustained hi-speed runs (for me anyways...) 100+ mph.....
buzybraza is offline   Reply With Quote
Old 01-08-2013, 11:04 PM   #5
BartG
BartG's Avatar
Oddometer: 174
dont run them soft on tar with heavy loads for long times, they do get VERY hot. I run at a higher psi on tar anyway and never had a problem...
Do find the wheels balance with more difficulty though making my ride less "smooth" at higher speeds.
BartG is offline   Reply With Quote
Old 01-08-2013, 11:45 PM   #6
corndog67
Oddometer: 1,281
I do recall one time, on an XRL650 that was all hotrod, and would cruise at close to 100, that when I pulled a tire off, there was all this rubber dust in there, and a mechanic/tire guy told me that was the tube moving around at speed, grinding itself apart, maybe that is what they are trying to avoid.
Old 01-09-2013, 02:45 AM   #7
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,893
Same as the otehr guys - I use Michelin UHD exclusively and have never had an issue with them on the long haul, dirt or otherwise. Put them in and forget about them. They last longer than the tyres!!!
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 01-09-2013, 03:19 AM   #8
genghis9021
Arak Connoisseur
genghis9021's Avatar
Oddometer: 250
Uhd
I've used the UHD in a K60 for the Frankfurt to UB run which was everything from 140kph Autobahn to 15kph path, in lots of rain and tremendous heat in the Uzbek deserts (Kyzl Kum, etc).
Haven't changed that tire but will look for the "dust" allegedly from the inner tube when I do.
But I won't use a UHD again. REALLY made balancing the wheel difficult. That tube weighs more than my front tire (Karoo2) !
I run a Tubliss in the front and the lack of heat from ANY tube contributed to that tire lasting 50% longer than previous experience.
2011 Husky TE 630 2011 Husaberg FE 570S
2006 KTM 950 'S' ADV 2005 Suzuki DRZ 400 SM
"The perfect is the enemy of the good." 4 bikes in 3 countries.
Orange, it's the new black Tour.
genghis9021 is online now   Reply With Quote
Old 01-09-2013, 06:28 AM   #9
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,845
I ran UHD for a while after initial purchase of the bike, having run HD and UHD on dirt bikes for years.
There were no problems with the tubes failing, other than one time with lower pressure I spun the wheel in the tire and ripped the stem out. This wasn't the fault of the tube. I probably put ten or fifteen thousand miles on those tubes through several tires, primarily street miles with many gravel roads and a few trails.
When it came time to replace the UHD tubes I considered how I had a number of puncture flats with them over the course of time. Avoiding punctures and pinches was the primary reason for going with UHD in the first place. It didn't seem to be working out for me.
I weighed the added cost of UHD against running a regular tube and RideOn sealant, and decided to go with the sealant instead of UHD. It seems like I've had fewer flats running a regular tube with sealant. Certainly no more flats than with UHD. The additional costs and issues with UHD, to me, provide marginal, if any, advantage over regular or HD tubes on our big bikes.
Other advantages to running regular tubes with sealant include:
  • Less gyroscopic mass in the wheels make cornering transitions easier.
  • No worries about overheating tube or tire.
  • Less heat may increase tire life.
  • Tire/wheel balance is less problematic.
  • Carrying spare tubes is less bulky.
  • Fewer flats and punctures are sealed quickly.
  • Lower replacement costs.
  • Greater availability of regular or HD tube at dealers.
For me the promise of higher reliability with UHD wasn't worth the extra expense and drawbacks associated with these tubes. I think that on a full on light weight dirt bike, like those used by enduro and hare scrambles racers, the UHD will offer some protection against pinch flats when running low pressures. On our gargantuan beasts it is probably better just to run a little higher tire pressure, lighter tubes, and sealant.
For me it is an ongoing study.
YMMV
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 01-09-2013, 06:41 AM   #10
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,681
Running the 908 rear with UHDs would get VERY hot on tarmac.
I've had it melt two patches on a multi-flat ride where I was forced to use patches.
I'd get 50-100 miles and patch would leak & peel off from the heat.
Tire was barely touchable
I just run Metzler or Bridgstone standard tubes after that loooong weekend.
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 01-09-2013, 08:14 AM   #11
Martynho
No more Chilegringo.
Oddometer: 408
Tyre explody
I had a UHD tube explode into shreds on a (140kph+asphalt run in 35-40C temps, in a Heidenau K60 rear. I managed to stay on but have never used them since
Martynho is offline   Reply With Quote
Old 01-09-2013, 09:18 AM   #12
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,845
I had a similar problem with patches failing. For me it turned out it wasn't heat, but old patches. It seems they have a shelf life of about a year, after which they won't chemically bond properly.
After losing three consecutive patches I did some research and learned that fresh patches work best and become less effective over time. I bought new patches and cement and it worked the first time and has been holding for months now.
If your patches are over a year or two past manufacture, including time in distribution, sitting on the shelf at the store, and in your repair kit, it is probably time to replace them.
Could be that riding on low air pressure leaking from a poor bond led to the heat you noticed.
Something to consider.
Old 01-09-2013, 10:03 AM   #13
FakeName OP
FakeName's Avatar
Oddometer: 1,874
Yeah, sorta what I thought. I've been exchanging email with the tire folks who've assured me that the 990/606/908 combination is no problem for the UHD tubes despite the earlier warnings.
But I do question the UHD paradigm. I've run them for years on the 525, but the big bike is different. The 606 run on the smaller bike carries a load of something like 275 lbs at fairly low sustained speeds. The same 606 on the big bike will carry closer to 375 at much higher sustained.
Further, the small bike will be lower psi- I usually run about 10-13. I think if I run that low pressure on the big bike (off road), I'll be buying a new front rim pretty quick.
Do I really gain a lot of flat protection with the thicker tubes?
Thanks for all the input so far, keep it moving!
2014 500EXC Black
Old 01-09-2013, 12:25 PM   #14
Newbusa
Newbusa's Avatar
Oddometer: 625
Ran the Michelin heavy duty tubes in my K60 tires in hot and cold conditions on pavement and above normal speeds never had a problem.
2010 990R Adventurer.
2007 Tuono 1000R
Newbusa is offline   Reply With Quote
Old 01-09-2013, 12:57 PM   #15
bigdave-gs
Explorer
bigdave-gs's Avatar
Oddometer: 2,661
Never saw a need for UHD tubes. If a thorn or a nail goes through the tire carcass, it's going to go through the tube. Buy two name brand standard weight tubes for the price of one UHD and put the other in your panniers.
I'd be unstoppable if not for Law Enforcement and Physics !
When your 6'8" with a 40" inseam, the bikes that fit you are limited ! ! !
2004 BMW R1150GS Adventure for street work / KTM 950 Super Enduro for Dirt work !
bigdave-gs is offline   Reply With Quote
Times are GMT -7.   It's 08:56 PM.
