Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 01-06-2013, 04:24 AM   #16546
Boola-Boola
Scramblin' Man
Boola-Boola's Avatar
Oddometer: 113
Originally Posted by henryII View Post
I had to take out the fuel pump and put it in my spare tank since that came without.
Here some pictures of it..
Thanks for posting those pictures, henryII.
I'll be fitting the Arrow to my EFI Scram at some point which, according to the instructions, requires fuel tank removal for re-routing the wiring loom of one of the O2 Sensors. From your photo's I now know what is beneath the tank (and what is within it too).
My local dealer was telling me that (on EFI with ignition off) fuel does not flow from the tank when the fuel line is disconnected, but if disconnected soon after a recent engine run there may be a spurt of fuel as remaining pressure is released. Does this match your experience of disconnection and tank removal?
To fit the Arrow I'll be leaving the fuel pump undisturbed of course - just removing the tank - but nice to know if I won't have to drain the tank empty before disconnecting and removing it.
73's - Boola-Boola
-Triumph Scrambler EFI-
'You gotta deep-six your wristwatch, you gotta try an' understand, the time it seems to capture is just the movement of its hands.' (Walk in the Sunshine : Bob Weir)
Boola-Boola is offline   Reply With Quote
Old 01-06-2013, 04:50 AM   #16547
henryII
henryII's Avatar
Oddometer: 396
He maybe right, but I had a little to much gas and the fuel cap will leak. So I drained most of it out, its also easier to
work with the tank without gas in it. Remember to not wear a zipper sweater because you have to hold it close when
you take it off.
I have switch the exhaust between arrow and mojave, and I did not have to remove the tank just loosen it a little
to get to the cables. I think you manage without taking off fuel cable :-)
________________________________________
[/URL]
henryII is offline   Reply With Quote
Old 01-07-2013, 08:46 AM   #16548
ZappBranigan
Oddometer: 470
Metal Mule Pannier racks installed....
Wow, I just realized I haven't posted in this thread for almost a year! Well, anyway, I just wanted to pop in to say that I finally got around to installing the Metal Mule pannier racks I bought from a fellow ADV-Rider here. They'd been sitting in my garage since last February and I got tired of looking at them, so yesterday when the wife suggested I take the bike out for a ride (since it was so nice) I said "no, I think I'll go ahead and install that rack that I've had for so long!"
My prevoius setup was a Renntec rack (chrome) which I had to tweak a little to fit around the exhaust mount (at the time I got mine in 09, Renntec didn't make a rack for the Scrambler. My understanding is that they do now.) Onto that I mounted a cheap JC Whitney top case which has lasted much longer than I expected it to. Then, for my Sturgis trip in '09, I added the Triumph number boards as low-tech "saddlebag guards" and ran an inexpensive set of nylon throwover bags.
Anyway, first step was to remove my old stuff. The Metal Mule rack and pannier set comes in three pieces, the rear rack and the two side racks.
In addition to removing the seat, you also have to remove the rear fender (or as they say in England, "Mudguard.") I had never done this before so I had to interrupt the installation process to run down to the hardware store for a T30 Torx bit, since the fender is held in by 4 Torx-head bolts.
The reason the fender has to be removed is that Triumph for some reason put a threaded hole onto the inside of the shock-mounting bracket. This is the forward mounting point for the rack.
Once those bolts are in, there's a special bracket that goes on top of the rear frame bracket, this attaches both the rear rack and the side racks. The special bracket is the flat piece in the center of the picture.
After that is hooked up, the rear fender can go back in and then the side racks go on pretty easily. The side racks attach to the upper shock mounting brackets (on the outside) just like the Renntec rack did, and also to the back of the passenger footpeg brackets.
The side racks attach on the rear to the special bracket on the frame and also to another "bridging" bracket that connects the two side racks underneath the license plate.
Yes, it's a close fit to the rear turn signals, but once everything is bolted in, nothing touches the rack. It's SOLID!
Top case mounting plate attached easily and then the case went right on.
Seems like a very well built item. Too bad it's so hard to get and so expensive in the US.
Now all I need to get are some side cases (no, not going to put the 40mm ammo cans on there - too heavy!) Anybody got any side boxes or pelican cases for sale?
Martin (AKA ZappBranigan)
"Branigan's Law is like Branigan's Love: Hard, and Fast!"
Current Ride: 2002 BMW R1150R
ZappBranigan is offline   Reply With Quote
Old 01-07-2013, 12:49 PM   #16549
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 3,010
I've got a big ol set of Happy Trail cases for sale.
http://www.advrider.com/forums/showthread.php?t=852489
I mounted top loading pelican cases to my racks which I like too.
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 01-07-2013, 02:08 PM   #16550
ZappBranigan
Oddometer: 470
Wow, great price but those things look HUGE! I don't think I want cases that are quite that big.
Pelican cases are nice - that may be what I end up with.
Old 01-08-2013, 01:31 PM   #16551
ZappBranigan
Oddometer: 470
Re-thinking the ammo cans...
Alright I guess I should have known better but after seeing the prices people are asking for side boxes, the ammo cans are starting to look better and better.
I can get a decent set of Pelican cases (which would be about the size I need) for around $180 each.
Or a set of 20mm ammo cans (similar in size, although heavier) for ....
,,,$18 each?
quite a difference.
Old 01-08-2013, 02:40 PM   #16552
lockyv7
lockyv7's Avatar
Location: Sunshine Coast Australia, There is no winter here.
Oddometer: 1,053
,,,$18 each?
quite a difference.
And i think for about $5 you could get some old tin from a chicken coup.
lockyv7 is offline   Reply With Quote
Old 01-08-2013, 07:35 PM   #16553
goodcat8
goodcat8's Avatar
Oddometer: 3,010
,,,$18 each?
quite a difference.
Pricier, but ready to mount.
BA Moto Ammo cans
http://www.ba-moto.com/store/product...boxes-brackets
These were $50 bucks at an army surplus. Not counting rack costs.
I just sold these ebay cases off my bonnie.
These are my pelicans on my vstrom.
There's lots of cool options. Deciding is half the fun.
Old 01-09-2013, 09:45 AM   #16554
ZappBranigan
Oddometer: 470
BA Moto Ammo cans
Hey, I'm digging the Wyoming Cowboy logo (Go Pokes!) (UW Law class of '05)
True. I've already found what I think is a local source for the cans. It will actually be a fun project figuring out how to put them on the rack and lock them. up.
And then, of course, the stickers...
Old 01-09-2013, 11:27 AM   #16555
fotopat
Pat / Cleveland, OH
fotopat's Avatar
Oddometer: 111
Possibile luggage option for Scramblers
I've been looking around for luggage options for my 2013 Scrambler and am not entirely satisfied with the limited options available. The Metal Mules look great but cost a fortune and I'm not sure if I really want hard bags. If I did, I'd probably go with Solobox Panniers out of Bellingham, WA. It occurred to me I should have kept the Dirt Bagz from my KLR650! Anyway, I called the guys at:
Moto-Sport Panniers Inc
5405 W. 56th Ave., Suite A
Arvada, Colorado 80002 USA
(303) 456-4684
who make the Dirt Bagz and they said it's possible, they might come out with something come spring. Perhaps if more folks are interested, they might step up and make some for us. Check them out here: Dirt Bagz
and if they look like something you'd be interested in, give them a call.
"Ouch! That's gonna leave a mark!"
photos on shutterfly
photos on flickr
photos on panoramio
photos on SmugMug
fotopat on facebook
fotopat is offline   Reply With Quote
Old 01-09-2013, 11:38 AM   #16556
wildjester
wildjester's Avatar
Oddometer: 82
Hi... I am the actual owner of this Scrambler.
These 50 cal cans cost me $16 at my local Army Surplus store.
The mount was sourced from www.newbonneville.com
wildjester is offline   Reply With Quote
Old 01-09-2013, 12:11 PM   #16557
henryII
henryII's Avatar
Oddometer: 396
Still fancy the Balance a bag behind the back give.
[/URL]
Old 01-09-2013, 02:09 PM   #16558
scramblase
ATGATT -> Met/Isoleucine
scramblase's Avatar
Oddometer: 97
Ebay (and a bit of patience) can work wonders. Don't think I crested the $100 mark for all 3.
2011 Triumph Tiger 800 XC
2006 Triumph Scrambler "Adventure"
scramblase is offline   Reply With Quote
Old 01-09-2013, 02:48 PM   #16559
goodcat8
goodcat8's Avatar
Oddometer: 3,010
Ha! Small Internet!
Old 01-09-2013, 06:45 PM   #16560
xaman
Oddometer: 556
Love those pipes
xaman is offline   Reply With Quote
Times are GMT -7.   It's 12:28 PM.
