01-09-2013, 08:34 PM
#256 |
I See Faces...
Oddometer: 256
I was so impressed with ownst1100's cooking setup I made my own. Mine isn't as involved as his, I simply wanted a wind block for my stove and a convenient food-prep area for when picnic tables are not available. I thought the positioning of rear-bike-mount made a lot of sense. It's a great work height. Also, I wanted mine to be very small when folded, which it is.
Shown stowed on my top box, a Pelican 1550. Folded dimensions (appx) 12.5" x 10" x 1". Also shown is the ABS rear platform I made to create a bit bigger footprint for better stability: ![]() Takes less than a minute to set up. ![]() Other uses are on the tailgate of the Land Cruiser when 4 wheeling, and it's small and light enough to fit into a backpack for mountaineering. Thanks ownst1100 for the inspiration!
ElMartillo screwed with this post 01-10-2013 at 04:57 PM |
01-09-2013, 09:42 PM
#257 |
Oddometer: 2,422
Martillo,
Great idea. Reminds me of the 'wind screens' on the ole Coleman stoves. I also use a 1550 and have Varios. Going to look into designing something like yours/other one that utilizes the Vario as the support on the bottom. (You used an additional ABS plate). Martillo...do have any 'patterns' that you used? That is...mine would mount to the right side...with the back attached to the RotoPax. Might even utilize the 1-gallon RotoPax handle as part of the securing???
LaurelPerryOnLand screwed with this post 01-09-2013 at 09:54 PM |
01-09-2013, 09:52 PM
#258 | |
I See Faces...
Oddometer: 256
01-10-2013, 06:20 AM
#259 |
"Cool" Aid!
Oddometer: 41,483
Headlight protector:
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Out of order, but you get the idea. Jim
01-10-2013, 06:39 AM
#260 |
IBA, BMWMOA
Oddometer: 188
Front axle tool for my 1200. I spent about $8 at the hardware store and made two of them... one to show and one to go.
Christopher Ross 2011 R1200GSA - Helga 1974 R90S - Smokey |
01-10-2013, 07:10 AM
#261 | |
"Cool" Aid!
Oddometer: 41,483
![]() Mine. Cut the top off a cheap 13/16" socket. Small and free with junk tools everywhere. Jim
01-10-2013, 07:15 AM
#262 |
IBA, BMWMOA
Oddometer: 188
Nice.
Was the outside of that socket not round? I never get rid of old tools. I may upgrade tools, but I always keep the old ones. You never know when some Southern Engineering will be called for.
01-10-2013, 07:16 AM
#263 |
Hi
Oddometer: 53
R1100GS wind deflecter
I was tired of looking for the right angle that didn't exist to get rid of the buffeting. I cut the shape, heated it with a heat gun to get the curves right. Result, it's quiet, and NO buffeting! Visibility is only reduced a little because I gave it that satin finish.
[IMG] [/IMG][IMG] [/IMG]
Don't sweat the petty things, pet the sweaty things... |
01-10-2013, 08:36 AM
#264 | |
"Cool" Aid!
Oddometer: 41,483
Jim
01-10-2013, 08:41 AM
#265 |
Dog Rancher
Oddometer: 4,179
I just pull the foam out of the socket and put an extension in backwards or where the spark plug would go. No tools are harmed.
01-10-2013, 08:59 AM
#266 | |
Pepperfool
Oddometer: 2,572
And if you want to get fancy drill a 9/32" hole in one end so a screwdriver shaft can go thru it.
Old enough to know better.... Young enough to try it again |
01-10-2013, 09:15 AM
#267 | |
"Cool" Aid!
Oddometer: 41,483
![]() Took up way too much room in my tool kit. Jim
01-10-2013, 09:35 AM
#268 |
motorcycle addict
Oddometer: 885
JVB
Do you only flip that plexi gaurd up and cober the light when you are off road or do you leave it up normally? If up does it cause any refraction of the light and distort the focus at all? Most, obviously not all, but most cheap spark plug sockets have the hex on the end and are cut thru for the 3/8" backwards extension trick. Almost every cheap tool kit has one of those in it. On my boat tool kit I bought the 5/8" spark plug socket wa too thick to fit into the water manifolds to remove the sprkplugs on the 5.7 liter Chevy Mercruiser. I had to take a grinder and thin the bottom inch down and then be careful removing and torquing plugs in so as not to crack it. I do not have a lathe to turn a scket down. Cutting off the end of a cheapo plug socket is no big loss, it is not "harming a tool" it is merely "repurposing" a tool....recycle. Finding one that will fit backwards on an extension is a better idea though because then you have a spark plug socket as well. Some need to be turned down to fit the BMW head like my boat did. Remeber to give it a quick shot of paint to prevent rust if you turn one down.
it is easier to ask for forgiveness than permission kellymac530 screwed with this post 01-10-2013 at 09:42 AM Reason: add |
01-10-2013, 11:07 AM
#269 | |
I See Faces...
Oddometer: 256
Also, did it have a noticeable effect on the wind entering under the bottom edge of the windshield? More buffeting? Cheers! |
01-10-2013, 12:20 PM
#270 |
Oddometer: 108
Where do you get an M14 coupling nut at? I went to my local Ace hardware and they only had SAE style and not the larger version. Also, the large spark plug socket made by Husky does not allow for the reverse socket drive trick since it has a circular hole on the inside not the standard 3/8 inch square socket fitting..
'09 BMW R1200GSA Adventure! IBA #49426 |
