Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
View Results: Explorer or Explorer/XC
Explorer 0 0%
Explorer/xc 0 0%
Voters: 0. You may not vote on this poll
Old 01-07-2013, 01:05 PM   #3556
snakeroll
snakeroll's Avatar
Oddometer: 6
Iddy,
Your reply was very interesting to me. So you cannot mix the HOAT and OAT?
snakeroll is offline   Reply With Quote
Old 01-07-2013, 01:30 PM   #3557
SkiFastBadly
A beer? Yes, please
SkiFastBadly's Avatar
Oddometer: 1,540
Originally Posted by snakeroll View Post
Iddy,
NO, and also keep the little lambs away from the ivy.
The crows seemed to be calling his name, thought Caw.
2008 Buell Ulysses
2008 Triumph Scrambler
2004 HD Heritage Softail
SkiFastBadly is offline   Reply With Quote
Old 01-08-2013, 05:33 PM   #3558
gregdee
Motocampist
gregdee's Avatar
Oddometer: 495
Aux lights
With regard to aux lights what are they really there for? I try like hell to not ride at night so in my case I would assume that the aux lights were there to get you noticed. What do you all say?
Of those of you that have the Triumph aux lights/fog lights, do you like them and are they worth the price. I like the idea of just having them plug right in.
gregdee is offline   Reply With Quote
Old 01-08-2013, 06:03 PM   #3559
Pacific
Left Coast Adventurer
Pacific's Avatar
Oddometer: 81
I have aux lights on all my bikes. Too many deer in my area to ride at night. I have them solely to make me a little more conspicuous. They work, too, as does the bright TEx headlight. I don't rely on them, but they don't hurt.
I ordered PIAA's, then returned them and went with the (slightly more expensive) OEM lights because of the simplicity of installation.
Uva uvam vivendo varia fit. -- Agustus McRae, Lonesome Dove
Pacific is offline   Reply With Quote
Old 01-08-2013, 06:09 PM   #3560
Voluhzia
iExplorer
Voluhzia's Avatar
Oddometer: 1,615
I like my OEM too... They don't light as far as the headlights but wide and very visible from distance in day and night time
Facebook
Nova Scotia on Explorer
2012 Triumph Tiger Explorer
http://novascotiaexplorer.blogspot.com/
Voluhzia screwed with this post 01-08-2013 at 06:27 PM
Voluhzia is offline   Reply With Quote
Old 01-09-2013, 06:08 AM   #3561
gregdee
Motocampist
gregdee's Avatar
Oddometer: 495
auxillary power
How are you guys powering your auxiliaries like powerlet sockets or gps units? Have you added a fuse block and then wired from there? Is there a good way to tie into the existing electrical system or do you just run a lead directly from the battery to a fuse block or similar device?
Old 01-09-2013, 06:24 AM   #3562
ZZ4Blazer
Oddometer: 301
Other than the one factory installed? There's a spot for one under the rear seat. I believe there's a wiring plug for that already. And that's keyed hot.. Not constant like the one on the tank.
"homesick for a place Ive never been"
'13 Triumph Tiger Explorer 1200
08 Yamaha WR450F - woods/adventure monster in the making
ZZ4Blazer is offline   Reply With Quote
Old 01-09-2013, 06:34 AM   #3563
gregdee
Motocampist
gregdee's Avatar
Oddometer: 495
Sorry, I'm not all that familiar with it yet. Working on a deal with my "deal-er" right now. Just trying to figure out what I should ask for. Sounds like there are two pre-installed powerlets already? Cool. I suppose the tank will still need to come off to run power for a GPS unit though, eh?
Old 01-09-2013, 07:04 AM   #3564
Voluhzia
iExplorer
Voluhzia's Avatar
Oddometer: 1,615
OEMs are plug and play - all wired. Just install, thread the wires to the plug.
There are two plugs under rear rack, one is key hot for top box cigarette socket and the other one is engine run hot for aux socket. There is hole on the left side for it.
Facebook
Old 01-09-2013, 07:11 AM   #3565
Voluhzia
iExplorer
Voluhzia's Avatar
Oddometer: 1,615
There is only one Powerlet at front of tank which is always hot.
I ran GPS cable to the battery without dropping the tank, same thing for AUX OEM lights and heated grips.
Once you have a bike, you'll figure it out.
Facebook
Old 01-09-2013, 06:58 PM   #3566
M Bouthillette
Oddometer: 33
When you ran that cable, how did you transform the power supply from 12V to 5V ?
M Bouthillette is offline   Reply With Quote
Old 01-10-2013, 04:05 AM   #3567
Voluhzia
iExplorer
Voluhzia's Avatar
Oddometer: 1,615
Original cable (harness) supplied with the GPS has connections to wire into 12V circuit...
Facebook
Old 01-10-2013, 06:24 AM   #3568
gregdee
Motocampist
gregdee's Avatar
Oddometer: 495
Head light protection
Anyone running the Touratech headlight protector? The wire one or the clear plastic one? Is it worth it or is this just a coolness-I'm-a-badass-and-need-this-thingy farkle?
What about the Touratech side-stand switch protector? I can see where this could be important.
Old 01-10-2013, 08:59 AM   #3569
Voluhzia
iExplorer
Voluhzia's Avatar
Oddometer: 1,615
I have the OEM headlight protector. Don't know how it's different but here is why I like what I have:
- look cool
- protects from small rocks if following another idiot on gravel or snow icy road with sand all over
- quick disconnect, just pull off the grommets
Facebook
Old 01-10-2013, 08:26 PM   #3570
ridenm
ridenm's Avatar
Oddometer: 2,789
- look cool
Facebook
Checked out your blog report. What's your impression of the stock bags?
"Coming back to where you started is not the same as never leaving. ― Terry Pratchett (RIP )
ridenm is offline   Reply With Quote
Times are GMT -7.   It's 07:48 AM.
