Old 01-09-2013, 04:18 AM   #346
Hikertrash
Oddometer: 2,766
Originally Posted by JimVonBaden View Post
More tomorrow!
Jim
Jim,
Where did you get this part? I want to install a USB port on my fender, but I haven't seen anything with a small enough diameter to fit between the metal hole underneath.
Hikertrash is offline   Reply With Quote
Old 01-09-2013, 06:37 AM   #347
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,541
Originally Posted by Hikertrash View Post
Jim,
E-bay. Warning on this one. You need to wire it to a fuzebox or relay. It has an internal light that will drain your battery over time if left hot all the time.
Jim
Old 01-09-2013, 11:23 AM   #348
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,377
Originally Posted by oalvarez View Post
Congrats, Mac!
Originally Posted by DucandGSrider View Post
I lurked that post, very well done.
Originally Posted by BigDave75 View Post
Great job!!!!
Thank you, thank you, and thank you... (-:
It was a great adventure...
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline   Reply With Quote
Old 01-09-2013, 12:41 PM   #349
Mikey10000
Oddometer: 29
I did it
Dropped it in the driveway!!! Had the bars turned too much and stalled it facing uphill. Down she goes.
Those big metal boxes and crash bars on the adventure definitely work.
Mikey10000 is offline   Reply With Quote
Old 01-09-2013, 12:45 PM   #350
rgb2cmyk
rgb2cmyk's Avatar
Oddometer: 256
Originally Posted by kimokk View Post
"I figured it would be identical and i would feel right at home.... but it felt more like hopping in bed with your girlfriends identical twin sister. Everything looked the same, and yet it felt weird, all new and different."
That's a great sig quote there if I ever saw one! Can I use it? Congrats!
Go for it. You have my blessing
_
14 R1200 GSA (Hopefully lasts longer than 2yrs)
12 R1200 GSA ("Sandy") (Hit by DUI)
09 R1200 GSA (Totaled by SS Sandy)
06 Husky TE450, 04 R1100s BCR, 03 F650CS
rgb2cmyk is offline   Reply With Quote
Old 01-09-2013, 01:12 PM   #351
ghostryder
made it
ghostryder's Avatar
Oddometer: 5,761
Took all the crash bars off, going to send them to get powder coated. Removed the light bar and lighs as well going to sell those and get a better setup.
ghostryder is offline   Reply With Quote
Old 01-09-2013, 03:26 PM   #352
JimVonBaden
"Cool" Aid!
Oddometer: 51,541
Added a relay for my aux lights and USB plug until I can get a Fuzeblock.
Took a 180 mile ride in the cold and rain.
Jim
Old 01-09-2013, 07:04 PM   #353
BTL
WINTER!! UGH!
BTL's Avatar
Oddometer: 408
Originally Posted by macadamia View Post
I completed an iron butt ride, coast to coast in under 50 hours from Jacksonville Beach, FL to San Diego, CA, on an 2012 GS Adventure...
Nicely done. I am complimenting Ironbutt when I retrieve my Triple Black beauty this spring.
BTL is offline   Reply With Quote
Old 01-09-2013, 08:20 PM   #354
JimVonBaden
"Cool" Aid!
Oddometer: 51,541
Made a headlight cover:
Jim
Old 01-09-2013, 10:44 PM   #355
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 353
Completed alternator belt replacement today, after going back to the dealership to get the correct part.
My Hepco-Becker engine guards made removal of the alternator cover quite an involved process, so while I had it off I cut it in half using a band saw. The gap between the two halves is minimal, and it's gonna save me a bunch of time and frustration in the future.
Cheers!
ElMartillo is offline   Reply With Quote
Old 01-10-2013, 03:37 AM   #356
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,636
Cheers!
Nice.
Mine has both the slice and an access hole.
The slice was intentional and done when I got the bike, the access hole was made when a belt failed and tried to extrude itself through the cover. Fortunately, it happened at the crank pulley bolt. I just cleaned up the hole a bit and made it large enough to insert a 17mm socket. Its normally covered up with a bit of black tape.
If you're all about the destination, take a fucking flight.
Twilight Error is offline   Reply With Quote
Old 01-10-2013, 06:19 AM   #357
TEWSTER2
TEWSTER2's Avatar
Oddometer: 412
I cleaned all the grooves in the tread on my tires with Qtips and a pair of tweezers.
Twice
www.youtube.com/user/tewster2/videos
2011 R1200GS, 2015 WR250R Whizzer
TEWSTER2 is online now   Reply With Quote
Old 01-10-2013, 06:58 AM   #358
mikegc
mikegc's Avatar
Oddometer: 1,593
What have you done to your GS or GS Adventure today?
Is your wife still pissed off or are you allowed back inside, now?
Mike
IBA 25881
Duty- Honoring a Friend
mikegc is offline   Reply With Quote
Old 01-10-2013, 07:04 AM   #359
FLARider1
FLARider1's Avatar
Oddometer: 1,264
I like the headlight cover.......I am thinking I will be copying that one!!
FLARider1 is offline   Reply With Quote
Old 01-10-2013, 07:10 AM   #360
JimVonBaden
"Cool" Aid!
Oddometer: 51,541
Took half an hour!
Jim
Times are GMT -7.   It's 12:12 PM.
