01-10-2013, 05:04 AM
#19711 | |
Super Lurker
Oddometer: 1,985
See here: http://www.stromtrooper.com/v-strom-...il-change.html
![]() Wee Stommin along. ![]() W/ABS |
01-10-2013, 05:28 AM
#19712 | |
Oddometer: 168
01-10-2013, 05:35 AM
#19713 |
Oddometer: 338
Yea that sounds good. Most likely I will be riding from around noon Saturday to dark since the wife has to go into work. There's also a trail starting where the Tuckahoe road exit ends off 288. It's going to be a development at some point I think. I leads to Broad street and there's people working at the entrance at Broad, but from the Tuckahoe side it's desolate. Type 37.625755,-77.656528 into google maps and check it out. You will see the trail pick up right where the road ends. It looks pretty straight forward, but with all the woods off to the side of the trail I'm banking that there are some trails off of it.
2012 WR250R 2007 SV650 (SOLD) 1984 XL350R (SOLD) 2002 CR80R (SOLD) |
01-10-2013, 05:39 AM
#19714 | |
Oddometer: 7,763
Pulling the tubes, invert, pump and drain is the only way to get it out. I wrote the following procedure for the post-95 Concours. The procedure is pretty much the same for your forks, but please note the oil quantities are for that bike. Yours will probably be different. FORK OIL CHANGE 1. Remove the plastic (not absolutely necessary, but makes it easier to get to the lower fork clamp bolts. 2. Loosen the four (two per side) fork tube pinch bolts on the top clamp + the two (one per side) Allen head handlebar clamp screws. Absolutely necessary to be able to loosen the caps since the pinching action constricts the tube around the fork caps. 3. Back out the preload adjusters to the last ring (or until you feel resistance) and break the top fork cap(s) loose. DO NOT loosen these any more than a couple of turns out, or try and remove the caps now. 3a. Elevate the bike and remove the front wheel. Do not allow the calipers to hang on the brake lines. 4. With the weight of the bike now off of the front suspension, remove the caps from the top of the tubes. CAUTION: There is some pre-load spring pressure on the cap so be prepared once the threads clear. Remove the springs slowly so they don't pull oil out with them and make a mess. 5. Remove the fender. 6. Loosen the two (2) bottom triple clamp bolts (per side) that secure the tubes. 7. Grasping the tube. Use a back and forth twisting motion while exerting a downward force and work the tube out of the clamps. Repeat for the other side. Pay attention which side is the left and right. 8. Invert the tube and dump the fork oil in a suitable container, pumping the tube/slider to get as much of the yucky oil out as possible. 9. Add a couple hundred cc of low flashpoint solvent (I like kerosene or diesel fuel) per tube, then pump the tube up and down several times to loosen up some the crud in the bottom. Invert the tube and dump the solvent into a suitable container, pumping the tube/slider to get as much out as possible. Repeat this process several times for each tube. 10. Add a couple hundred cc of low weight 'cheap' fork oil to each leg and work the tube up and down. This is to dilute any solvent that be be left in the tube. Invert the tube and dump the fork oil into a suitable container, pumping the tube/slider to get as much out as possible. 11. Reinstall the tubes in the bike tightening the the lower clamp pinch bolts only. 12. Add the fork oil. The rest is pretty much the reverse of removal. Follow the directions in the Manual for the proper torque values. Fork oil by volume: 379cc per leg (completely dry after full disassembly) Fork oil by volume: 330cc per leg (changing only) **Fork oil by level ('94-'up): 171mm from the top of the inner tube with the spring removed and the fork fully compressed ** Best method NOTE: You have not yet installed the spring(s). 13. Now the fun part..... getting the cap back on. Like all things, there's a procedure that helps. 14. In turn, take each cap and place on the top of the tube it will going in during final assembly. Slowly rotate the cap and determine the point where the threads just begin to grab. Using a magic marker, pencil - something - make a mark on the cap so you can reference it with a fixed spot on the top clamp (the slit in the clamp works). Repeat this for the other cap. 15. The whole reason for this procedure is to help get the cap started when the springs are in place. Trying to push down on the cap (against spring pressure) and turn it to get the threads started (without cross-threading) can be a real PITA. Another hint would be to use a speed wrench. These make it easy to apply a downward force and turn at the same time. 16. Finally, install the springs and their flat spacers. Position the cap in place so your alignment mark is just to the left of the fixed reference you've established. With a straight downward force, push the threaded portion of the cap into the bore of the tube. Insuring that it is straight, rotate the cap clockwise at least a 1/2 to 3/4 of a turn. The threads should have engaged easily to the point that you didn't even notice. Slowly relax downward pressure to make sure the threads are engaged, and if so, continue tightening the cap. Gorilla tight isn't necessary. Once you tighten the top clamp bolts, the tube will constrict and keep the cap in place. 17. Repeat for the other cap. 18. Replace the front wheel, calipers, and fender. Pump the front brake so the pistons will have moved back out to the disks BEFORE riding. 19. Double check all pinch bolts that secure the fork tubes to the triple clamps. 20. Replace any plastic that was removed. .
GB Young Services, LLC Garage Project: http://gbyoung2.smugmug.com/Family/G...11686385_YA8pi |
01-10-2013, 05:50 AM
#19715 |
Oddometer: 338
To add to my last post I just coincidentally saw an article saying Eagle Construction just purchased the land here (google maps, type 37.658828,-77.647569 in). That is off of the area I was just talking about. It looks like a dirt bike track of some sort. At first I was worried it may be someone's farm or yard, but now a developer owns it so I wouldn't be too worried with exploring it.
You can see the land they bought here as well http://www.richmondbizsense.com/imag...s-Farm.pdf.jpg. It won't show you the trails cut in on that map though so you're better looking on google.
01-10-2013, 06:00 AM
#19716 | |
Oddometer: 168
01-10-2013, 06:24 AM
#19717 |
Oddometer: 338
Where do you live?
01-10-2013, 07:29 AM
#19718 | |
will golf for food
Oddometer: 27,468
and who would trade a RT for a HD?
IBA#10787 “We, the people, are the rightful masters of both congress and the courts - not to overthrow the constitution, but to overthrow men who pervert the constitution.” – Abraham Lincoln "Fathom the odd hypocrisy that Obama wants every citizen to prove they are insured, but people don't have to prove they are citizens". -Anonymous WV VA Good Eats Map |
01-10-2013, 07:30 AM
#19719 | |||
VA is for Riders
Oddometer: 330
http://www.fs.usda.gov/Internet/FSE_...rdb5392127.pdf I found the road numbers I was interested in and just got off the phone with the Glenwood/Pedlar Ranger District's office. The road you wanted to go up was 1167 from Map 28. When you plan a trip out there again, after winter, you should check out 1881 on Map 30. You can spot the rd # centered left to right about 1/4 way down from the top. If you like jumping waterbars it's a blast. It is the one with the tunnel under the Parkway if you have been through there or have heard mention of it. Ride em' while you can. They have very little money to maintain roads so when they become heavily damaged they close them. They are also closing them because folks do not stay on the roads.
A little dirt don't hurt. |
01-10-2013, 08:23 AM
#19720 | |
squirrel
Oddometer: 1,148
I have been led down that FS road with the tunnel before but didn't know where I was or how to get back. Probably your video.
01-10-2013, 08:28 AM
#19721 |
Addicited to ALL bikes!
Location: Chester,VA. Growing on me or getting used to it?
Oddometer: 1,730
I am riding on Sunday but on Saturday, I am looking for someone to help me do yardwork (blow/pick up leaves, cut/spread a bunch of monkey grass, spread mulch, etc) from around 0800-1630. Is $10/hr plus drive time and free lunch fair? PM me if interested, all work confidential.
Me: BMW F800GS/DRZ-400S, Gabriel: KTM 50 Senior Adventure! |
01-10-2013, 08:48 AM
#19722 | |
VA is for Riders
Oddometer: 330
01-10-2013, 08:54 AM
#19723 | |
Super Lurker
Oddometer: 1,985
01-10-2013, 09:31 AM
#19724 | |
Oddometer: 660
Oh yeah. I'm that bad with directions. Actually, I'm way worst than I lead on. But hey, I love to ride, and I've got great friends that helps me out in that area.
01-10-2013, 09:32 AM
#19725 | |
BTBlueSkies
Oddometer: 107
Thanks so much for checking out the status of the gate. It is a nice ride back to that gate so no worries if it is closed. It is also pretty much on the way to the general area. Who may be in for saturday? I plan to leave about 8 AM ish from Midlothian. We could meet at Cafe Caturra on the Midlo Turnpike at 7:55AM and grab a coffee and bite then head out.. .. it's at: 13830 Village Place Drive Midlothian, VA 23114 Many times I like to leave with first light, and that is oKay with me also... I have a green light to go on saturday so I am making a day of it :)
Smiles, Karl |
