Old 01-08-2013, 03:01 PM   #136
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,250
Originally Posted by calltrex View Post
I would use 48 front at least and 76 rear
I'm 210lbs
I had .46 in the front of my 520.....worked out well......it's all Greek to me......I take it to my local shop and rely on their expertise/recommendations......I've been going there for years and they know how I ride.... (http://www.allamericanktm.com/ ) .....they're the ones doing the work/magic with springs/oil types/oil levels.....I'm just the bank
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 01-08-2013, 10:20 PM   #137
BanhXeo
BanhXeo's Avatar
Oddometer: 337
I got a 76 in the back and I'm 205. Suspension for me was one of the best and most needed mods right off the bat. You will love the difference in feel of the bike. You know also now that I'm thinking about it, adding the radiator fan is something you guys should look into. I notice mine kick on when I'm out riding hard. It comes stock on the 500 but KTM didn't add it on the 350. Its 125 bucks I believe and doesn't take much to get it on. As much as mine runs I'm glad I added it. Have fun!
2013 KTM EXC-F SOLD
2013 BMW F8 GS FOR SALE
SmugMug: http://ktmrider.smugmug.com/
This is my WIFE, here are my BIKES, and these are my STORIES: http://www.advrider.com/forums/showthread.php?t=897188
BanhXeo is offline   Reply With Quote
Old 01-09-2013, 12:05 AM   #138
dvwalker
Working to ride
dvwalker's Avatar
Oddometer: 793
Crawdaddy, yea the 5W LED is definitely not a night light, but in a pinch should get you out of the woods...
I was mainly thinking function and the small 196w stator, and potential draw. We really didn't have to think about this on the WRR and the 350W stator.
I believe battery charge should stay positive using the 5W LED light with fan/GPS running. I installed the sicass light switch so one can always turn off the head light in a pinch. I'm still on the fence spending the bucks on a squadron as well...
Here's a little load work sheet, all numbers approx..
with factory 35w bulb - approx
with 5W LED
dvwalker is offline   Reply With Quote
Old 01-09-2013, 07:25 AM   #139
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,250
Picking up the bike on Friday...here's my off the bat game plan....
Suspension - The shop is installing the .46/76 Springs and they'll set me up with sag/best guesstimate on initial clicker settings
Armor - throwing on front and rear rotor guards along with a skid plate
Seat - Already made arrangements with my buddy Lendon at Seat Concepts....he's sending out a seat cover TODAY......I'm not interested in spending one minute on the stock 2 X 4 foam/seat cover.....
Tires - Pirelli MT43 rear tire/Bridgestone Ultra Heavy duty tube
I'll ride with the stock front tire for a while and see how I like it......may switch out to Pirelli XCMH.....having the shop balance the front wheel with lead weights that sit on the rim and wrap around the spokes (generally used for street bike applications....the rim strip lead weights always seem to flick off).....
Radiator Fan - I enjoy single track and I ride in some serious heat/at slow speeds in CA./AZ.....my 520/300 spew without fans....no reason to believe the 350 will be any different.....
Switching counter sprockets - I bought an XCW not the EXC so the stock gearing is 13/52.....too low for basic dualsport.....14/52 is still a bit too low......I'll chew up the stock aluminum sprocket and then replace it with a steel 48 or 50 tooth down the line
GPR - I have GPRs on all my bikes.....solid product/support......local San Diego Company
Highway Dirt Bikes guards/mirrors.....and I'm sure I'll throw on heated grips too.....
Fork Bleeders.....~$20 well spent
Pro moto foot pegs (if the ones on my WR will fit)
GPS hardwire
Brake switch (a rear brake light and mirror should be all I need to pick up a street plate when I head over to my place in AZ. next week)
HeadLight: picked up the 45W step up replacement from Sicass along with the 5W LED.....I'll mess around with both just for kicks....
Down the line:
Gas Tank.....undecided but leaning towards Acerbis 5.3.....a couple of my buddies with 350/500 have opted for the 5.3 Acerbis tank since that option is actually less expensive than a 3.1 gallon when you factor in the cost of quality radiator braces.....the bigger 5.3 tank protects the radiator from side impacts, the weight is carried low since you rarely fill it above the lower seat line (3 gallon mark), I'm told it's only ~1" wider than the stock tank with shrouds.....and you'll obviously have the freedom to go really remote if you ever actually fill that thing up with gas......I like to ride in Baja/other wide open spaces in the western U.S. so that "if you need it range" option is attractive to me....
Lighting.......we'll see.....the ~$400 Squadron is really not necessary for my primary mission......I rarely ride at night......just need a decent light for the "Oh shit....I broke down" (or by buddy broke down) scenarios....the option to switch the light off completely is atractive to me....good idea DVWalker......maybe I'll pick up that switch too......perhaps I'll put that switch into my HDB clamp....
Kickstand.....broke the kickstands off my 400/520/620......I have no reason to believe the same fate doesn't await my stock 350 kickstand.......kind of a sore point with me......KTM charges BIG $$ for these bikes then delivers them with shitty seats/flimsy kickstands......come'on guys....wtf?!?!
Crawdaddy screwed with this post 01-09-2013 at 01:37 PM
Old 01-09-2013, 08:02 AM   #140
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,867
With reasonable care I get many years out of OEM KTM kickstands,they're built to be light and minimal.
Cant lean on them or hold the whole bike off the ground with them or sit on the bike with them down,somehow mine last fine.
Ive seen people hold the bike up with em to oil the chain and then wonder why they broke.
But then Ive had KTM's since 1978.
Ive been running the Dirt Tricks radiator fan with good results,draws way way less then the stock fan. Oddly my 2011 530 will go on a hot day trail ride usually with minimal or no boiling while my buddy's 2012 500 will puke water more or less constantly on climbs. Mine must have a little richer fuel mixture.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 01-09-2013, 09:16 AM   #141
BanhXeo
BanhXeo's Avatar
Oddometer: 337
Thanks for the work sheet Dale, gives me a better idea of what I have drawing off my battery right now.
2013 KTM EXC-F SOLD
Old 01-09-2013, 06:35 PM   #142
dvwalker
Working to ride
dvwalker's Avatar
Oddometer: 793
really good list of mods crawdaddy, looks like you're going to have a blast...a couple other items to think about not on your list.
- heat shield over header pipe, if you like you're riding pants
- check your muffler for a little worthless screen baffle, not sure the xcw has this, but remove it if you have one, will blow out on the trail eventually anyway
- replace 100c rated thermo switch with 95C to turn rad fan on at lower temp, should help keep things a bit cooler (swiped pics from etickets build)
- fuel filter: remove the tiny clog prone 10/20 micron filter between the quick-disconnect/injector, and replace with a real fuel filter (ie Golan) using FI clamps
- kickstand: I installed the pro moto billet, but for the money not much better than stock IMHO, save your money...just remove the spacer and replace with shorter bolt from your ktm owners bag
- light switch: the plug play sicass is a lot narrower than the stocker, more room on the bar, as a bonus you can turn off light
+1 on the Acerbis 5.3, nice fit with good rad protection
dvwalker screwed with this post 01-09-2013 at 06:41 PM
Old 01-10-2013, 06:56 AM   #143
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,250
- replace 100c rated thermo switch with 95C to turn rad fan on at lower temp, should help keep things a bit cooler (swiped pics from etickets build)-
Is there a recommended/preferred heat shield?
P3 has a slick looking unit (http://www.ktm-parts.com/P3HSKT35KS.html ) but I'm wondering if it reaches back far enough/stands off far enough to protect the pant legs?......it's billed as a "Pipe Guard" as opposed to the Acropovic "Heat Shield": http://www.bigbadpowersports.com/pro...S10450535.html
I'll have to look and see if the XCW even has the exhaust screen?
Good idea on thermo switch......possibly ~$20 well spent.....there's a Napa right down the street from me.....my only concern is the increased battery drain if it causes the fan to run more than it really needs too?.....KTM spent thousands to determine when it needed to kick on....you'd think they'd error on the conservative side to begin with....
LIkewise, I'm told the service bulletin/change to 20 micron filter has virtually eliminated the clogging issue that earlier bikes encountered with the 10 micron filter.......I'll run it "as is" before making any changes on the fuel filter.....as the old adage goes, "if it ain't broke don't fix it"....I put more faith/credibility in mfg service bulletins than internet chatter.....
Old 01-11-2013, 07:42 AM   #144
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,250
My new http://seatconcepts.com/ covered 350XCF-W seat pan arrived last night......slapping it on the bike today when I pick it up so my ass will never have to endure the lame/stock 2 X 4 seat pad/cover.
Stylish/stock height, all carbon wrap, with orange accent thread........nice! ....Thanks Lendon!
Crawdaddy screwed with this post 01-11-2013 at 08:19 AM
Old 01-11-2013, 08:07 AM   #145
ADVTuga
Paulo Lança
ADVTuga's Avatar
Oddometer: 298
All carbon wrap with orange accent thread.......nice! ....Thanks Lendon!
Hi Crawdaddy , can you post a photo with the seat on the bike ? Thank you .
http://www.trailaventura.pt/
ADVTuga is offline   Reply With Quote
Old 01-11-2013, 02:39 PM   #146
vladg
Oddometer: 32
I use this Gizmovest. Its durable, doesn't slip out of your hand while your holding it and it attaches to my RAM mount great to keep it right where I want to position it. http://www.gizzmovest.com/CRStage.cf...2&MainNav=True
This is what my hardwire looks like..http://www.mountguys.com/ProductDeta...31-00&click=21
Yes I have same Gizmovest as well. But its not designed to use that miniUSB connection from our link. Did you drill hole in Gizmovest or so? I have seen miniUSB connection with 90* bent on connection itself. I was thinking to use that one.
http://offroad-kherson.at.ua/
vladg is offline   Reply With Quote
Old 01-11-2013, 03:44 PM   #147
calltrex
calltrex's Avatar
Oddometer: 25
top view of the seat would be nice too. does it stick out on the wide part?
2012 KTM 350 EXC-F
calltrex is offline   Reply With Quote
Old 01-11-2013, 04:58 PM   #148
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,250
I'm kicking back with a beer watching yesterday's Dakar highlights.......bike will be ready in an hour or so.......I'll post some pics of the seat on the bike tomorrow morning from various angles......
I have Seat Concepts seats on all my bikes.....it's a no brainer......quality product, stylish, comfortable, reasonable.....
Old 01-11-2013, 10:39 PM   #149
NSFW
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,688
congrats chris on the new bike.
i picked up a 2013 last october, haven't really rode it.
good choice on the seat concept. lendon did an awesome seat for ours.that was my first improvement.
already have a bunch of parts waiting to be installed. just don't have the time.
this one is the most bang for the buck...........trailjammers
NSFW is offline   Reply With Quote
Old 01-12-2013, 06:03 PM   #150
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,250
Side by side
Crawdaddy screwed with this post 01-12-2013 at 06:18 PM
Times are GMT -7.   It's 08:40 AM.
