Old 01-10-2013, 01:15 PM   #271
Desert Skies
One brick shy...
Desert Skies's Avatar
Oddometer: 2,056
I'm all about being "thrifty" when it comes to add ons. I took an aluminum block, drilled a 1" hole in it and cut it in two to make some saddles for my fog lights to bolt onto my engine guards.
“Sorry I'm late, feck'n off takes a lot of time.”
" The 'Wing is my wife's bike - I'm just the feck'n driver." - USMCG_Spyder
" This post is full of VonBadenisms." - Gordy
Tripn' with Tom Some pictures ZZ Rider - Tom Lowry Texas Blue - Tom Lowry
Desert Skies is offline   Reply With Quote
Old 01-10-2013, 01:29 PM   #272
LaurelPerryOnLand
Oddometer: 2,422
Noticed that you're saving on the "soap", as well!
LaurelPerryOnLand is offline   Reply With Quote
Old 01-10-2013, 01:49 PM   #273
Desert Skies
One brick shy...
Oddometer: 2,056
Dood, it's not a Harley.
Old 01-10-2013, 04:03 PM   #274
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,483
Originally Posted by ElMartillo View Post
Nice job, I like the DIY stuff that looks factory. I'd suggest a little rubber stick-on bumper or two at the potential contact point(s) at the top to prevent vibration noise should the wind push it backwards.
Also, did it have a noticeable effect on the wind entering under the bottom edge of the windshield? More buffeting?
Cheers!
The wind holds it firmly to the glass. It doesn't vibrate, but probably a good idea to add a bumper to pevent scratching protector.
I kept the edge opaque to minimize the reflection. It is not bad, but I might add a bit of paint along the edge to reduce it more.
Jim
Old 01-10-2013, 04:17 PM   #275
VietHorse
VietHorse's Avatar
Oddometer: 492
Start browsing this thread to do something for my newly bought GS...
You guys' mods are amazing! Thanks.
VietHorse is offline   Reply With Quote
Old 01-10-2013, 04:42 PM   #276
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 256
Martillo...do have any 'patterns' that you used?
Yes. First I made a cardboard mock-up. From that I made 3 plywood patterns of the 6 panels (3 patterns as it's symmetrical). Routered the aluminum to the pattern using a straight-cut router bit with an end bearing on my router table. De-burred, put the bends in the two bottom panels, cut the hinges, drilled for rivets (countersunk and pressed flat both sides)...et voila!
ElMartillo is offline   Reply With Quote
Old 01-10-2013, 08:49 PM   #277
UnclebudinTX
UnclebudinTX's Avatar
Oddometer: 185
Originally Posted by TheRoss View Post
Nice.
Was the outside of that socket not round?
I never get rid of old tools. I may upgrade tools, but I always keep the old ones. You never know when some Southern Engineering will be called for.
A broke wrench is just a wrench waiting to be repurposed.. I have a drawer full of broke wrenches, never knpw when you will need to bend one to fit .
Unclebudintx
http://unclebudsadventures.blogspot.com/
2004 BMW R1150GS 2004 BMW R1150RT
1979 Kawasaki KZ1000st (sold)
1991 Harley XLHsporty 883 (sold)
UnclebudinTX is offline   Reply With Quote
Old 01-12-2013, 11:06 PM   #278
VietHorse
VietHorse's Avatar
Oddometer: 492
R1200GS upper crashbar
Anyone did (or knowing someone else) make your own upper crashbar for your 1200GS?
I am looking for some ideas, dimensions and advices.
Thanks.
Old 01-13-2013, 01:58 PM   #279
JimVonBaden
"Cool" Aid!
Oddometer: 41,483
Made a light bar:
Unfortunately I ran out of bedliner paint, so I used plastidip. Not pretty underneith, but it looks good on the outside, and works well!
Jim
Old 01-13-2013, 02:22 PM   #280
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 2,572
Originally Posted by kimokk View Post
Where do you get an M14 coupling nut at? I went to my local Ace hardware and they only had SAE style and not the larger version. Also, the large spark plug socket made by Husky does not allow for the reverse socket drive trick since it has a circular hole on the inside not the standard 3/8 inch square socket fitting..
Any industrial fastener place that stocks metric carries them.
I just went to my local one.
It's interesting that McMaster Carr doesn't carry that size but went looking I found that the M12 coupling nut is 22mm across as well see link http://www.mcmaster.com/#metric-coupling-nuts/=l0t8h9
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 01-13-2013, 02:36 PM   #281
Dennisb40
Oddometer: 18
Hand Protection
Purchased some moose mitts and modified them with my sewing machine. Hands are nice and toasty to matter the temp.
I use Nylon cloth and lined it with a tough denim called duck cloth.
Not all BMW drivers are asshats :-).
Dennisb40 is offline   Reply With Quote
Old 01-15-2013, 11:45 PM   #282
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 256
Good Fix for Broken System Cases!
Not long after purchasing my Y2K 1150GS just about 3 years ago, I was enjoying one of my first dirt rides on the bike. After several attempts to "get air", some of which were moderately successful, I just happened to look in my right side mirror and noticed one of my poorly-loaded system cases rolling around in the dirt behind me.
Luckily I had a number of bungee cords with me, and after recovering the case I was able to reattach it well enough to gingerly ride home.
Upon inspection, I found the front "hanger" on the right side case was broken, nearly clean off. After finding out how much it would cost to replace the case ($$$), I decided a fix was in order. I had some stainless angle iron on hand, and my TIG machine with nothing better to do...
This is what a good "hangar" looks like:
This is the broken one, with my new stainless steel hangar:
As you can see, fits well. I trimmed the plastic so the hang height is darn close to correct:
Inside the case:
Stronger than the original, I'm sure. I also realized the rail on the same side was broken so I simply replaced that with a used unit, but I will soon post photos of my new stainless rails I'm currently working on.
I hope this idea helps some folks!
Cheers!
ElMartillo screwed with this post 01-15-2013 at 11:50 PM
Old 01-16-2013, 11:23 AM   #283
STUFF2C
We Ain't Left Yet!!
STUFF2C's Avatar
Oddometer: 1,163
the $2 big foot... NHL
Thanks to the Interstate Highway System, it is now possible to travel from coast to coast without seeing anything.
-- Charles Kuralt
I never plan a ride, just the destination and that's always subject to change.
STUFF2C is offline   Reply With Quote
Old 01-17-2013, 07:42 AM   #284
LaurelPerryOnLand
Oddometer: 2,422
Cheers!
There's a SERIOUS market for something like these for VARIO cases!
The replacement case bottom cost $114 and $142 (left and right) IIRC.
See "Case Bottom Replacement" Step 1 in my pictorial for an example of the same kind of broken TAB on the VARIOs.
It seems like it's always this tab...shown in the picture.
http://advrider.com/forums/showthread.php?t=848307
OK...you sit around...make up a few "TAB REPAIR KITS" and pocket a few thousand dollars which can then be used to farkle!
Just sayin'.
Old 01-17-2013, 09:10 AM   #285
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 256
Just sayin'.
Well, I like making money as much as the next guy, I enjoy fabrication and problem-solving. I could price it reasonably I'm sure.
You have a broken one you could send me? Ideally I'd need the piece(s) that broke off, ultimately ideally the bike for fitment, but we could get around that if necessary.
Cheers!
Times are GMT -7.   It's 04:17 AM.
