Old 01-11-2013, 07:17 AM   #1
JustRon OP
ex-broadwayron
JustRon's Avatar
Oddometer: 1,289
Chain jumps - is this ok?
This is an '08 Husaberg and the rear sprocket and chain are pretty new. I put a new front sprocket on (15t), but it wouldn't fit with the chain slider, so I modified the slider. There's not much room around the 15t, so I was a little paranoid. I've never tried this with my 'berg, but I ran it in first gear on the stand, just to make sure everything looked ok. But, the chain is jumping quite a bit. So, I put the old sprocket back on (14t- still in excellent condition, shows no wear). I get the same jumping.
When I give it a little throttle, it seems to jump a bit less, but still jumps a lot.
Here's a video:
https://picasaweb.google.com/1179750...02953261146322
Not sure if that video will work, because my work blocks it for me.
I posted this on Husaberg.org, and one guy said it's normal when the suspension is uncompressed. Tonight, I'll look for a kink in the chain, but I'd be very surprised to find one.
Any ideas?
2010 Beta 520RR
Baja crash Report
JustRon is offline   Reply With Quote
Old 01-11-2013, 07:46 AM   #2
sieg
sieg's Avatar
Oddometer: 2,936
Looks fine, just engine surges. Load the chain/engine (drag the rear brake) and it will smooth out.
BTW the video works, now get back to work.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 01-11-2013, 09:33 AM   #3
groundrules
groundrules's Avatar
Oddometer: 1,896
no chance you've got a sticky/frozen link on the chain, right?
groundrules is offline   Reply With Quote
Old 01-11-2013, 09:45 AM   #4
Switchblade315
Switchblade315's Avatar
Oddometer: 5,954
even seen what a chain does when you go over bumps. that looks like the rear tire is getting faster then the chain and pushing slack in it or a split second. and you might possibly have a stiff link but i say it looks normal. as suggested put just a little pressure on the brake and I bet it stops.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 01-11-2013, 10:52 AM   #5
JustRon OP
ex-broadwayron
JustRon's Avatar
Oddometer: 1,289
^ I'll check that tonight. I think I would have noticed already, but I haven't specifically looked for it yet.
And, I'll try applying the brake (I have this horrible feeling I'll put weight on the rear and the spinning wheel will catch the ground, heh.)
I guess I just don't know how this should look. I assumed the wheel would spin and the chain would look pretty smooth.
2010 Beta 520RR
Baja crash Report
Old 01-11-2013, 11:29 AM   #6
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,862
the video you posted looks very normal . . . . if your worried about weighting the scoot and dropping the tire to the ground (which, I agree, might be exciting), create drag on teh wheel (2X4 or some such) . . . . . . same affect.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 01-11-2013, 12:28 PM   #7
sieg
sieg's Avatar
Oddometer: 2,936
Originally Posted by broadwayron View Post
^ I'll try applying the brake (I have this horrible feeling I'll put weight on the rear and the spinning wheel will catch the ground, heh.)
Just push the pedal with your hand, or a long screw driver under the foot peg and over the pedal that will not weight the rear of the bike at all.
Old 01-12-2013, 07:48 AM   #8
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Big single torque pulses + typical drivetrain slack = jumpy chain. You oughta see my Tuono's chain on the dyno at 2500 RPM.
you don't see luggage racks on a hearse..........act accordingly
Old 01-12-2013, 06:54 PM   #9
JustRon OP
ex-broadwayron
JustRon's Avatar
Oddometer: 1,289
Took it for a test ride today with the bigger front sprocket, and all seems well.
Thanks for easing my mind!
(Third gear power wheelies take slightly more throttle with the bigger sprocket- I love this bike.)
2010 Beta 520RR
Baja crash Report
Times are GMT -7.   It's 05:37 PM.
