Old 01-05-2013, 04:11 PM   #436
jc9995
Commuting BEAST :)
jc9995's Avatar
Oddometer: 213
Originally Posted by Wisconsinkris View Post
Thanks JC9995!
Hey, how did you mount yours to your 650gs?
I made some brackets that hang from the bottom of my crash bars. I didn't care for it though and just drilled a hole in the side of the plastic shrouds. Getto...but I wanted them tucked in as far as possible.
"We cant solve our problems with the same thinking that created them"...Einstein
jc9995 is offline   Reply With Quote
Old 01-05-2013, 04:19 PM   #437
bash3r
I ain't no DingWeed
bash3r's Avatar
Oddometer: 1,727
These M10s are on my list!! Save me a kit :)
08' Yamaha WR250R
09' Yamaha WR250F
14' BMW F800GSA
Adventure Tshirts | 3 Step Hideaway |Campground POIs
bash3r is offline   Reply With Quote
Old 01-05-2013, 08:22 PM   #438
Charrito
Charrito's Avatar
Oddometer: 92
Holy shit that was fast! Got them today! THANKS!!!
Charrito is offline   Reply With Quote
Old 01-07-2013, 12:09 PM   #439
Charrito
Charrito's Avatar
Oddometer: 92
Where are you guys mounting the switch? I want to make sure it stays clear of rainwater, etc...
Old 01-07-2013, 01:46 PM   #440
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 2,989
Depends on the bike I suppose. Mines front top of the fuel tank where my wee has a plastic plate thing.
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 01-08-2013, 05:11 AM   #441
BrittC
BrittC's Avatar
Oddometer: 277
Mounted the lights and tested them. So far so good.
Please ignore the frozen bottle of washer fluid in the background. Damn you winter!!
2002 Aprilia ETV1000 Caponord
2008 Yamaha WR250R
1992 Yamaha XT225 Serow
http://britt-motorcycling.blogspot.com
BrittC is offline   Reply With Quote
Old 01-08-2013, 07:11 AM   #442
Charrito
Charrito's Avatar
Oddometer: 92
It's a Tiger 800...I'm thinking of the same thing, the plastic piece on the front of the tank. I think it is less exposed there than mounted on the bars somewhere. Unless I could seal it or waterproof it without damaging the button.
Old 01-08-2013, 08:01 AM   #443
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,146
The switch will hold up to rain. Its not waterproof and I wouldnt submerge it, but like the controls on your handlebars, a little rain now and then shouldnt be an issue.
The lights run on very low DC current and ive used this type of switch (in rain) for years without issue.
If you are really concerned or anticipate lots of rain or moisture, there are silicone sprays that dry and disperse water (be sure its safe for plastic). They can be messy so if you opt to use a spray, I wouldnt do it with the switch on the bike (overspray).
thanks,
-Brian
MondoMotos - LED Auxiliary Light Kits - Tusk Panniers
RoadRUNNER Magazine - Blog
Ride Reports - Four Corners - Amish Country - Costa Rica - Expedition Michigan (or not) - Tellico Plains
The Toad screwed with this post 01-08-2013 at 11:40 AM
The Toad is offline   Reply With Quote
Old 01-08-2013, 12:33 PM   #444
mattmus4357
Oddometer: 667
Hey Brian, any word on when the MM12's will be in? Thanks
mattmus4357 is offline   Reply With Quote
Old 01-08-2013, 01:14 PM   #445
Charrito
Charrito's Avatar
Oddometer: 92
thanks,
-Brian
Thanks Brian...I don't want to mess with spray as I've already wired the bike. I'll mount the switch near the front of the tank, it should be OK.
I'll post pics of the whole setup once the brackets arrive in a couple of days.
Old 01-08-2013, 02:48 PM   #446
Wisconsinkris
Wisconsinkris's Avatar
Oddometer: 101
Question on the provided switch,
I assume it is 12v. But what is the amp rating?
Wisconsinkris is online now   Reply With Quote
Old 01-08-2013, 09:07 PM   #447
Wisconsinkris
Oddometer: 101
I finally finished cleaning up the wiring.
I installed mine on the brackets that hold up my winglets by extending the forward bracket.
I didn't use the whole harness and ended up connecting the lights a fuzeblock I already had and added my own switch inline with the power to the lights. I mounted the switch to a bolt on the left handguard.
The result.....
Out the back yard....before and after
On the fence...before and after
View from oncoming....poor suckers gunna see me coming from a mile away....before and after
These lights are awsome. Can't go wrong with the quality as well as the price.
Old 01-10-2013, 07:30 AM   #448
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,146
The result.....
Many thanks for the pics and review.
(The switch is rated @ 5amps)
-Brian
Old 01-11-2013, 09:58 AM   #449
GB
Mod Squad
GB's Avatar
Oddometer: 55,973
I like your above MM10 kit, with the small LED lights, wiring harness and switch!
You might want to add pics of it in your first post too!
Old 01-11-2013, 11:54 AM   #450
SFC E
SFC E's Avatar
Oddometer: 37
Originally Posted by Drex_Army_RET View Post
Thanks for the prompt response! Hopefully you guys ship to Military APO addresses.
Drex
Received the MM10's in the mail today. Excellent quality! Now to find some time to install them.
SFC E is offline   Reply With Quote
Times are GMT -7.   It's 09:23 PM.
