01-02-2013, 09:16 PM
#5161 |
Oddometer: 121
I have the H B side racks and rebuilding the rear fender once the tank is fit. I destroyed the wires, turn signals and license plate bracket when the rear fender broke off on a low side. Hoping that there will not be a clearance issue once I am done putting it back together.
Going to the steel yard tomorrow at lunch to pick out some material. Will post up some pics one it is put together. I will keep my eye out for the pictures of the fuel line connection. [QUOTE=tbarstow;20382606]Use steel for your first one. I just used the included clear fuel line and looped it up under the bodywork and into the main tank vent. I'll get some pics tonight. |
01-02-2013, 10:31 PM
#5162 | |
Two-wheelin' Fool
Oddometer: 2,566
01-03-2013, 09:43 AM
#5163 |
Oddometer: 121
01-11-2013, 11:43 AM
#5164 |
I am the Thai Tiger
Oddometer: 1,235
Is anyone using dirtbagz on their xc? I just picked up a xchallenge and I'd like to figure out the luggage. The price is right, but how do they hold up?
01-11-2013, 11:58 AM
#5165 | |
Oddometer: 73
'07 G650 XCh (and '04 recumbent bike) |
01-11-2013, 12:12 PM
#5166 |
Oddometer: 1,887
Dirt Bagz
I'm a fan. I've used them on several bikes now. They are rugged, simple and sturdy. You can see my setup in a ride report here. They are not waterproof so I use these for my clothes and roll-top waterproof bags for tools and other stuff. My shoes and jacket liner go in a waterproof bag on top. The design places the weight over the seat with some transfer to the frame via the Dirt Bagz rack. On the trip described in the linked ride report I encountered some heat issues from the muffler on the first day - a sharp tug on the rack moved the whole deal out enough to create some air space and there were no other problems on this trip.
Wisconsin Rustic Road Century |
01-11-2013, 12:36 PM
#5167 |
I am the Thai Tiger
Oddometer: 1,235
The magadan bags are nice, but I just can't stomach the price...hence my interest n the dirtbagz. Giant Loop also has some new some soft panniers, to the tune of $650. Yowsa! Just getting higher now. Glad to hear that the dirtbagz are still working for you ph. I emailed their company a week ago, but still haven't heard back.
"The worst fucking thing you can ever do is to try getting rid of a Thai hooker that wants to stay." - anonymous inmate gastone screwed with this post 01-12-2013 at 02:28 AM |
01-11-2013, 01:03 PM
#5168 | |
Oddometer: 857
So sold on and swapped to HB racks Never lookend back
So many roads...........So little time..!!! 2005 BMW R1150GS Adv - Black 2005 BMW R1150GS Adv - Silver 1998 Honda XR250R |
01-11-2013, 01:14 PM
#5169 |
Oddometer: 2,072
The Dirt Bags are a cheap way to put some Luggage on the XChallenge. Saying that I would not spend the money on them if you are going to travel with them.
Not Waterproof Racks are not up to the task Zippers clog with dirt and can be very frustrating. IMO get something waterproof with roll tops. I like the Madigans , Andy Straps, and the Wolfman Luggage.
ADV Relay Rider 08 (The Texas Connection) Ride Pooie Ride ![]() Don't stop riding until you get to the crash , you might save it! |
01-12-2013, 01:37 AM
#5170 |
n00b sums it up.
Oddometer: 225
Wolfman Luggage...
I use the Wolfman dry luggage and in western WA they are the best choice I could have made. After the rain I am so glad I have them I don't think I would ever get something that isn't waterproof or doesn't at least have its own inner water proof liner.
![]() Just my 2 cents... good luck. |
01-12-2013, 10:42 PM
#5171 |
Oddometer: 121
Baja 1.1 gallon tank added to XC with Hepco Becker Racks
Thanks to Butter and tbarstow posts of their Baja tank addition I have completed my tank set up. Purchased at http://justgastanks.com/product_info...roducts_id=572 This included brackets that mount to the top of tank and at the front tip. Included aluminum spacer not used. Replaced with rubber stopper drilled through the center.
With the physical help of grinding drilling and cutting 1/4 stock steel from Mouthfulloflake I present you picutres. ![]() We did cut into the cross bar bracket to provide for addition 1/2 inch of room to play. Did not seem to compromise the stability of the bar at all. ![]() Stock signals should mount just fine. Plenty of room. ![]() Instead of using the supplied aluminum spacer we used a rubber stopper. This set up will allow for the tank to run with out the side racks installed. ![]() About 1 inch clearance from the tank to the sidewall of tire. ![]() Test run beginning of next week Edit: The tank did great! No issues with clearance and it drained into the main tank just fine. Earlevet screwed with this post 02-04-2013 at 08:43 AM Reason: updated infomration |
01-13-2013, 07:21 AM
#5172 |
Oddometer: 2,069
I considered cutting out that same part of the rack. I agree with you and don't think that extra material has any effect on the strength of the rack. I'm still kicking myself for not doing this sooner as the tank had been sitting around my garage for at least a year and the extra range is nice if only to avoid frequent gas stops. Props to Oggi for posting about this tank back in the day, wherever he may be.
Marc 07 XChallenge 99 VFR |
01-13-2013, 12:27 PM
#5173 |
Slow Ride to Nowhere
Oddometer: 121
Your Seat height?
What is your seat height with a stock seat?
I want to lower the bike 2 inches to swing my stubby legs over. I'm going to need a shock too. I'm sending my new Shivers / forks from a Husky out for re-building and shorting. I like the seat height to peg spacing no knee issues, so I prefer to not cut out the seat foam. I am be looking for a stock seat to rebuild. I don't want to destroy this one. I will post my seat needs in the flea market. Sorry I can't flip the photos. The look great on my computer, but come out sideways when I post them. I have my forks lowered to the second mark from the top. [IMG] [/IMG]I have an aftermarket seat. ![]() The seat height is 37 1/4 in / 946mm at the level and 40.5 in / 1029 mm at the stick
"The Constitution? I'm pretty sure the patriot act killed it, to protect our freedoms" Bart Simpson 06 FJR1300 09 XR1200 H-D Yea I thought I never would either 75 Norton 850 E-Start Project 69 Z-50A Mini Trail with Lights & 2007 X-Challenge Heavy dirt bike sweet sweet motor |
01-14-2013, 04:04 AM
#5174 | |
Oddometer: 1,434
I did just add a GL Coyote bag. (They were on sale, and can be mounted over the Dirtbagz racks.) I'd buy the Dirtbagz again though. Best bang for the $$..
IBA#32778 2008 R1200GSA 2007 G650XChallenge No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..) |
01-15-2013, 03:28 PM
#5175 |
Stress Relief Rider
Oddometer: 479
+1 for Wolfman
Wolman gets my vote. I built the racks and the dry bags are super!
2001 F650GS 2007 G650X-Challenge 2011 Beta 400RR 2011 990 ADV R 2012 R1200GSA Triple Black |
