Old 01-11-2013, 08:40 AM   #76
Paulvt1
Paulvt1's Avatar
Oddometer: 3,540
Vid of it in the metal..
http://www.youtube.com/watch?feature...&v=3sALbsEVEp8
Paulvt1 is offline   Reply With Quote
Old 01-11-2013, 08:48 AM   #77
Worroll
Worroll's Avatar
Oddometer: 763
One of the pictures shows the same luggage as the Sprint GT. I dig the fully adjustable suspension. This would have definitely been in the running before I bought my GT.
Worroll is offline   Reply With Quote
Old 01-11-2013, 09:05 AM   #78
Worroll
Worroll's Avatar
Oddometer: 763
and an information scroll button on the handlebar switch....
Old 01-11-2013, 10:45 AM   #79
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,057
Originally Posted by jerdog53 View Post
Too bad its not more dirt orentated....
why? is there a lack of big-bore adventure bikes all of a sudden?
--Semantics are everything.
ph0rk is offline   Reply With Quote
Old 01-11-2013, 11:00 AM   #80
GB
Mod Squad
GB's Avatar
Oddometer: 55,976
Might as well move this one to Road Warriors.. and merge it with the RW Tiger Sport thread.
Old 01-11-2013, 11:00 AM   #81
KingOfFleece
SplitWeight(tm)
Oddometer: 784
It's a road bike.
KingOfFleece is offline   Reply With Quote
Old 01-11-2013, 11:03 AM   #82
GB
Mod Squad
GB's Avatar
Oddometer: 55,976
Originally Posted by daysgoneby View Post
Lemme guess, Ash loves it, like he loves all Triumph's!!
Old 01-11-2013, 11:41 AM   #83
DAKEZ
DAKEZ's Avatar
Oddometer: 19,702
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 01-11-2013, 12:35 PM   #84
Jltrd
Oddometer: 27
You mean like the Tiger Explorer?
Sent from my SCH-I535 using Tapatalk 2
Jltrd is offline   Reply With Quote
Old 01-11-2013, 12:53 PM   #85
burmbuster
burmbuster's Avatar
Oddometer: 1,429
Damn, that makes me miss my 1050 triple in my Sprint. That engine is absolutely awsome! Triumph steps it up once again. If they gave it good suspension then Ducati is in trouble.
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Old 01-11-2013, 01:16 PM   #86
MariusD
Oddometer: 576
T
This is a joke right? As if the explorer 1200 and 800xc arent enough dirt oriented?!
Thank god its not dirt oriented! =]
MariusD is offline   Reply With Quote
Old 01-11-2013, 02:21 PM   #87
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,057
Originally Posted by MariusD View Post
T
If it was more dirty, the next complaint would be that it was "too heavy" at 517 lbs wet
Old 01-11-2013, 03:39 PM   #88
Tigerland
new to ADV
Oddometer: 7
Tiger 1050 Sport
FEATURES
The new Tiger Sport takes the adventure style street bike category to another level.
The new exhaust and upgraded intake system have enabled our engineers to deliver an additional 10PS of power and 6Nm of torque from its 1050cc triple engine whilst boosting the output across the full range of revs. The engine’s growl sounds throatier and meaner too, but more importantly, it has improved acceleration with an output of 125PS (123 bhp, 92kW) and 104Nm (77lb.ft, 10.6kgm). Also new for the Tiger Sport is an updated gearbox that brings slicker, faster gear changes.
Major revisions to the styling create a more sporting look coupled with a new single sided swingarm which improves packaging and allows more space for the new exhaust and larger optional panniers. The fully adjustable suspension has been completely redeveloped with new springs and re-valved damping. The new stronger rear subframe provides greater payload capacity (220kg) and greater rigidity, whilst improved ergonomics make for a more comfortable ride.
AN IMPROVED ENGINE
The Tiger Sport's engine creates a more dynamic, punchy and responsive ride with more power, torque and improved fuel efficiency. The 1050cc three-cylinder engine that powers the Tiger Sport has been upgraded with improved gas flow, a new air box, better breathing and even more distinctive sound. This all results in improved acceleration and, combined with gearbox revisions, provides lighter, more responsive gear changes. Output increases by 10PS to 125PS (123 bhp, 92kW) and 104Nm (77lb.ft, 10.6kgm). With the added advantage of better fuel economy.
SUPERIOR HANDLING
Key to the Tiger Sport is a chassis that not only delivers comfort but also sporting fun. Fully adjustable suspension and new springs with re-valved damping enable high levels of adjustability and feel. The new stronger rear subframe provides greater payload and greater rigidity meaning the fun continues even when riding two up. This gives the bike its sharper feel with enough left in reserve to handle the additional load capacity offered by the fitment of the optional Triumph Dynamic Luggage System. TDLS features an inter-connecting cable between each pannier to isolate turbulence-induced movement from the chassis resulting in a more stable ride. The latest ABS system is standard and includes a new modulator for better extreme braking and improved feel to back up the Tiger’s radial brakes. It all goes to create a bike you’ll relish taking through the twistys.
MORE COMFORT
Not only has ride comfort improved, the seat is now narrower and more comfortable for both rider and passenger: it’s 5mm lower at the front and the handlebars are lower and closer to the rider, giving a more direct feel. The back seat is also lower, sitting the passenger fully behind the rider for better wind protection. Added versatility is also provided by the under seat storage compartment and the ability to store an optional U-Lock. Who said you can’t have comfort and a sporty ride in the same bike?
ALL-NEW STYLING
Attention to detail has shaped the Tiger Sport. A specially designed single-sided swing-arm, newly styled side panels, tail unit and screen all make the bike look sportier. New lightweight reflector type headlights improve lighting performance and create a new visual look. Sculptured footrests, coloured seat stitching, tougher material on the underside of the seat, aluminium pannier mounts and careful styling of the new fork yokes and engine side casings add to that impression.
In fact, the fit, finish and build quality of every single facet of the bike has been improved for 2013. New colours: Crystal White or Diablo Red.
ACCESSORIES
A wide range of accessories are available for Tiger Sport including the optional Triumph Dynamic Luggage System. Payload is doubled to 10kg per pannier. The left sided pannier is 31 litres and is capable of storing a full face helmet, the right sided pannier is 24 litres in order to shape around the silencer. The Dynamic Luggage System is designed to minimise the forces passed through to a bike's chassis induced by turbulence around the luggage. It does this by partially cross-linking the panniers, which are free to pivot on their top mountings by several degrees, so that the force on one pannier is passed through to the other without affecting the main chassis of the bike resulting in a bike which is more stable and yet more agile.
Tigerland is offline   Reply With Quote
Old 01-11-2013, 03:59 PM   #89
Motard_Menace
Motard_Menace's Avatar
Oddometer: 307
Looks to be an excellent touring ride. I am guessing this is exactly the market they are after, someone who wants to tour that also wants comfy ergos and performance for 99% road use. Most riders that tour rarely venture off the beaten path anyway. Its just a dreamers dream to have the bike that can supposedly do it all even though it will see about 15 miles of off pavement use in its lifetime. Kind of like owning a Hummer, it can go anywhere but never leaves the pavement. I think it looks like a killer Trumpy! Here is to hoping it comes stateside eventually so I can check it out. Please bring it to the US Triumph........
2007 Triumph Tiger 1050
"If you Can't Fix it with a Hammer, it must be an Electrical Problem......"
Motard_Menace is offline   Reply With Quote
Old 01-11-2013, 04:25 PM   #90
MariusD
Oddometer: 576
I am in the market for exactly this kind of bike and was disappointed with the only options from triumph being the explorer and xc. How could the "normal" tiger be gone!? So this bike is the best news yet, I just wonder when the bike makes it to the states so i can get my arse on it!
It's going to be an interesting year... New DL1000 and new Tiger!
Times are GMT -7.   It's 01:58 PM.
