Old 01-10-2013, 08:38 AM   #1
scooteraug02 OP
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,533
Fuel Stabilizer Storage.
Was reading Rider magazine. A guy wrote in he was having problems with his Concours after storage.
Andy said conventional Stabilizers and old fuel are hard on the spark plugs. It makes them charcoal black and foul.
The plugs will idle but have a hard time performing above idle.
He said his local BMW dealership introduced him to Star Tron. http://mystarbrite.com/startron/
"BMW fuel injection pumps were dying at an alarming rate if left to sit in old gas for more than 90 days, so the Beemer boys did their online homework and ordered a case of Star Tron....Now all the big automotive chain stores hav it on the shelf, including WalMart."
He says Star Tron has naturally occurring enzymes that can stabilize fuel for 2 years. It is a fuel and can't overdose your tank. Helps handle ethanol.
I just put some Stabil in my bikes. I don't know if this is a subliminal advertisement or if the stuff is any good.
Has anyone had luck with this stuff?
scooteraug02 is offline   Reply With Quote
Old 01-10-2013, 09:46 AM   #2
jd2577
The Boy Ruger
Oddometer: 108
Like you, I have always used Stabil in my motorcycles and ATV. So far so good but, up until this year, everything's been carburated. The new to me Beemer is the first fuel injected toy that I've owned. Stabil claims to work with both systems. Guess I'll find out for sure in the spring.
jd2577 is offline   Reply With Quote
Old 01-10-2013, 11:00 AM   #3
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 466
Stuff Works
Within the past year I added this to the fuel in a carbureted motorcycle I rarely ride now that I have my GS. I can let the bike sit for 6 months, and coupled with a solar trickle-charger, it starts and runs like it did when it was my regular commuter.
ElMartillo is offline   Reply With Quote
Old 01-10-2013, 12:14 PM   #4
onesaintsfan
BigJohnHart
onesaintsfan's Avatar
Location: McComb MS, where men are men and sheep are nervous
Oddometer: 1,325
Fuel Strip
I ride mine enought that I dont need to store it. But if your bike has the onboard computer and the associated fuel strip, I would be afraid to use ANY fuel additive. I use to run marvel oil in my fuel, but after 3 fuel strips I dont put anything but gas in my gas tank. Just sayin
John Hart McComb MS
2003 Ducati 999s "Christine"
2008 BMW R1200GSA Mary Jane
2005 Chaparral 210ssi " Native Sun II "
onesaintsfan is offline   Reply With Quote
Old 01-10-2013, 12:26 PM   #5
scooteraug02 OP
Dog Rancher
Oddometer: 4,533
My dealer recommended BMW Techron after my fuel strip was replaced.
Old 01-10-2013, 12:31 PM   #6
rboett
posser noob 205
rboett's Avatar
Oddometer: 1,777
I don't to turn this into a failed fuel strip thread, ,,or an ethanol / clogged fuel injector thread ,,, but I think a combination of ethanol and regular stabil was responsible for clogging my fuel injectors, then researching the crap out of the issue (on ADVrider and other sites) ,, I did switch to startron for storage ,, not long after my fuel strip went out,may be coincidence, BUT, after a two tank fulls of non treated gas, the fuel strip started to work again. MY personal belief is that there are a two problems happening with the fuel strips, the connections in them break for some reason,, the other is some kind of bad ethanol / fuel treatment or gas related combo . Dunno. Do some searches on ethanol and phase separation
I think the best bet is to fill up with a non ethanol fuel if you are just storing for a couple months , find some here http://pure-gas.org/
My $.02
edit: oh yeah,, use Chevron gas with Techron, or buy techron every couple tanks too, does not seem to harm the strip and does clean the injectors
nother edit: If you use Stabil, look for the Marine stabil, or the one that indicates that it is specially formulated for ethanol fuels
That'L do Pig,, That'L do
rboett is offline   Reply With Quote
Old 01-10-2013, 12:50 PM   #7
WindSailor
WindSailor's Avatar
Oddometer: 736
I'll go with that.
I talked to a local Marine repair shop and they liked and supported Star Tron. They said there was a world of difference between Star Tron and Stabil... on fighting / cleaning varnish etc. inside the carb. So far I've used Star Tron for about two years now and 'knock on wood' haven't had an issue.
WindSailor is offline   Reply With Quote
Old 01-11-2013, 04:42 AM   #8
cueball
should'a walked it first
cueball's Avatar
Location: lake serene, ms. at least it was 'til i moved in!!
Oddometer: 740
i've been using startron for a couple of years with great success. i have several chainsaws, a generator, a large 2 stroke boat engine, 4 stroke boat engine, a seldom used trials bike etc etc & since switching have had no further issues with carbs gumming up or poor running after sitting for extended periods. good stuff
frank
lake serene
ktm 950, r1150gsa, r1100gs
cueball is offline   Reply With Quote
Old 01-11-2013, 05:12 AM   #9
RAL88
Marineboy
RAL88's Avatar
Oddometer: 77
I've been using Startron for about 8 years now. 6 of those years was in an unheated garage and it would regularly get down into the twenties in the winter. Before that I used Marine Stabil.
I have had no issues with Startron and the bikes run great and start right up after sitting for a while. I use it on a regular basis as it is suppose keep things from gumming up.
They now make a small 1 ounce bottle which I keep on the bikes so when I am out I can add it.
Rich
____________
'96' K1100LT-SE
'97' R850GS-R
"If it ain't broke take it apart and make it work better"
RAL88 is offline   Reply With Quote
Old 01-11-2013, 06:08 AM   #10
vtbob
wanderer
Oddometer: 596
I've been riding motorcycles a long time. approaching 50 years. I've never used any type of fuel stabilizer.
all my bike sit at least december thru march...some longer some year maybe a bit shorter.
I just fill up the tank to limit condensation, and in the last 15 years or so put the bike on a battery tender. the bikes always start...some times need a bit or ether in the spring t make firing up easier.
It get cold here in Vermont
vtbob is offline   Reply With Quote
Old 01-11-2013, 06:28 AM   #11
STUFF2C
We Ain't Left Yet!!
STUFF2C's Avatar
Oddometer: 3,049
I've never used anything in any of my gas powered anything. I do drain the carbs on everything when I put it away though. I turn the gas off on my airhead at the end of my street and then dump the bowls every time I ride it. Same with my mower, I installed an in-line valve and run it dry too. if I use a two stroke tool, like my chain saw, I dump the leftover fuel out and run it dry. So far, So good.
I know i just jinxed myself... going out now to find some wood to knock on.
Thanks to the Interstate Highway System, it is now possible to travel from coast to coast without seeing anything.
-- Charles Kuralt
I never plan a ride, just the destination and that's always subject to change.
STUFF2C is offline   Reply With Quote
Old 01-11-2013, 03:02 PM   #12
cueball
cueball's Avatar
Oddometer: 740
i started riding in the mid-sixties and like you never had a problem until ethanol reared it's ugly head!! startron seems to keep it's effects to nil for me.
frank
lake serene
Old 01-11-2013, 03:49 PM   #13
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
That tech guy who writes for Rider is a blithering boob. EVERY MONTH he gives shitfull advice based on less motorcycle knowledge than the average lawnmower mechanic. Sta-Bil works fine and does not foul plugs. I've stored stuff two years, starts right up like I shut it down last week. Startron is fine, but not the magic eliexer that the hucksters claim. It's fuel stabilizer.
Old 01-11-2013, 03:54 PM   #14
showkey
Oddometer: 1,963
VT fuel must be some good stuff...........No protection.........You are one lucky guy................fuel related problems are the largest reason for repairs in the small engine, outboard and motorcycle industry. It was that way 30 years ago........but now it is much larger problem and a cash cow for the shop
Think your ether fix is a cure for the small amount of fuel in the carb is no longer volatile. Best practice is drain the float bowl even with Stabil or other products in the tank.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 01-11-2013, 04:27 PM   #15
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,342
+1, the rep from Startron must be sucking this guy's dick. I'm sure it works fine as a stabilizer, but guess what? So do Stabil and Sea Foam and they won't foul your plugs. You know what fouls plugs? Trying to start a Concours with dirty ass nasty gummed up carbs because the owner didn't DRAIN them before storage. Fuel stabilizer doesn't keep the fuel in the bowls from evoporating and leaving fuel residue behind!
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is online now   Reply With Quote
Times are GMT -7.   It's 09:49 AM.
