Old 01-11-2013, 05:03 PM   #571
milzispete
Conquistador
milzispete's Avatar
Oddometer: 109
Originally Posted by One67 View Post
Just a question to you people with Freerides, do they start easily from cold ?
Mine takes too long to start IMO, it takes at least 3 long wind ups with the starter before it fires.
When I say cold, I mean starting for the first time in a day, not cold cold as where I live it's been 35 celcius every day for the past 2 weeks.
It was a bit hard to start when it was new ,but I figured it was just tight and would loosen up, it seems to be getting harder to start.
No problems with mine
i contacted the spirit world but they don't know what's wrong with my 690 either
milzispete is offline   Reply With Quote
Old 01-11-2013, 07:14 PM   #572
Bump Stop
2 Wheeled Drifter
Bump Stop's Avatar
Oddometer: 4,440
you don't have any popping or missing do you? sound's like a possible vacume leak that would cause a lean condition.
10 GASGAS EC300, 06 Husqvarna WR 250, 05 KTM 250EXC, 04 GASGAS EC 200, 00 KDX 220, 74 250 Mach 1
www.fuzionllc.com
Bump Stop is online now   Reply With Quote
Old 01-12-2013, 01:37 AM   #573
One67
One67's Avatar
Oddometer: 95
Yeah, good thinking. I'll spray some ether around the inlet manifold and see if I get a change in the idle.
One67 is offline   Reply With Quote
Old 01-12-2013, 03:50 AM   #574
blakken
dirt napper
Oddometer: 33
You have a cold start botton on the trottle body.
Pull it out and it will fire upp.
Then let it idle couple sec then push it in.
Its the same bottom that you adjust idle on.
Skickat från min GT-I9300 via Tapatalk 2
http://alvsbygrusspratters.blogspot.se/
2013 350 freeride
2011 990 adv r
2011 690 enduro r
2010 990 adv abs
blakken is online now   Reply With Quote
Old 01-16-2013, 12:18 AM   #575
One67
One67's Avatar
Oddometer: 95
Hmm, I've had no joy.
No inlet leaks and the cold start button made no difference, I maybe in for a trip to the stealer
Old 01-16-2013, 03:21 AM   #576
blakken
dirt napper
Oddometer: 33
If i have a gear in it is almost impossible to make it start. the clutch is draging until it gets warm.
If i in hurry and putt a gear in to fast after start it stalls.
2013 350 freeride
2011 990 adv r
2011 690 enduro r
2010 990 adv abs
Old 01-17-2013, 12:55 AM   #577
One67
One67's Avatar
Oddometer: 95
I allways start it in neutral.
Old 01-21-2013, 10:09 AM   #578
Hunebed
Hunebed's Avatar
Oddometer: 65
Fuel line cleaner
Before I got my FR the dealer cleaned the injectors, because the bike had been left standing for a few months. I allways use the highest octane fuel (less alcohol) to prevent clogging of the injectors. Maybe you could try fresh fuel with an additive to clean the injection system. I hope starting improves.
PPM
Hunebed is offline   Reply With Quote
Old 01-21-2013, 04:20 PM   #579
One67
One67's Avatar
Oddometer: 95
thanks for the advice, it's only had 5 tanks of fuel through it so far, it was full of an unknown fuel when I picked it up from the dealer. and I have only run it on Shell V-Power.
I spoke to the dealer mechanic and he said hard starting is a symptom of off-spec valve clearances.
So I checked them, 1 was in the middle of spec and the other 3 were on the tight limit of spec, so I subtracted .05mm from each of those valves.
all of which made no difference to the difficulty in starting, I am of the belief that it is ,as you say a fueling issue, it feels lean to me.
One67 screwed with this post 01-21-2013 at 04:22 PM Reason: typo
Old 01-21-2013, 11:51 PM   #580
blakken
dirt napper
Oddometer: 33
Do you remowed the pre filter?
Mine was hard to start when i remowed it.
2013 350 freeride
2011 990 adv r
2011 690 enduro r
2010 990 adv abs
Old 01-22-2013, 12:13 AM   #581
One67
One67's Avatar
Oddometer: 95
yes I did, did you put yours back on ?
Old 01-22-2013, 06:25 AM   #582
Hunebed
Hunebed's Avatar
Oddometer: 65
+1
Yes, I did fit a new prefilter.
PPM
Old 01-22-2013, 07:13 AM   #583
blakken
dirt napper
Oddometer: 33
Yes i did.
Then its start to behave better.
Freeride is runing very lean when you mess with air.
You can remove the filter if you remap
2013 350 freeride
2011 990 adv r
2011 690 enduro r
2010 990 adv abs
Old 03-21-2013, 12:53 PM   #584
2whl-hoop
2whl-hoop's Avatar
Location: Cottage Grove, the ragged edge of suburbia, MN
Oddometer: 659
http://blog.motorcycle.com/2013/03/2...ampaign=weekly
2whl-hoop is offline   Reply With Quote
Old 03-21-2013, 01:02 PM   #585
jerdog53
Crop Dusting Everywhere
jerdog53's Avatar
Oddometer: 1,923
Send a message via Yahoo to jerdog53
Originally Posted by 2whl-hoop View Post
Thats a Start!!
99 Cagiva Gran Canyon 09 696 Monster
"Shorter of breath and one day closer to death"
jerdog53 is offline   Reply With Quote
Times are GMT -7.   It's 01:58 PM.
