Old 01-02-2013, 12:46 PM   #151
PacificPT
Oddometer: 984
Originally Posted by Adv Grifter View Post
Nice bike! Have you managed to do something with the stock muffler?
It's even worse than the one on my DR650! ... and the sound is truly pathetic. I hate LOUD pipes ... but is there a sensible option for the KLR that sounds a little better and lightens the load a bit? I'm not a fan of mufflers that need re-packing ... like FMF and loud pipes bring "unwanted" attention!
The HOT ticket for the DR650 is using on older GSXR Titanium muffler. Mine was $50 ... plus $200 for the mid pipe to make it ft. Light, nice sound, lasts forever, no re-packing. ALL GOOD!
I am now using a Jardine with the quiet insert and steel wool stuffed into the spark arrestor and held in place with a wire cage to soften up the exhaust note. Saves about 12 - 13 pounds compared to the stock unit. The weight savings from the pipe and the Li - Ion battery adds up to just over 20 pounds...
2000 KLR650
There's roads and there's roads and they call, can't you hear it? Roads of the earth and roads of the spirit. The best roads of all are the ones that aren't certain. One of those is where you'll find me till they drop the big curtain. Bruce Cockburn
PacificPT is offline   Reply With Quote
Old 01-02-2013, 03:06 PM   #152
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,389
Leo Vince are consistently doing very nice pipes for a variety of bikes. I first saw them back in around 2005 on DL1000 Stroms. Very Nice pipes. I used a Remus pipe on my Vstrom but the Leo Vince was nearly as good ... and less expensive by about $100.
They also make a very nice pipe for my "other" bike, my Triumph Tiger 1050.
Light, well made, not too loud. The Tiger one comes with a removable baffle.
And the Leo Vince pipe comes with a spark arrestor and a couple different baffle tubes, depending on what flow and noise level you want.
But, it does weigh 12 pounds, so those that want the lightest pipe may not like that.
Also, you don't repack it.
According to M-Tech, they say they dynoed it and it beat the FMF Q4.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY screwed with this post 12-08-2013 at 01:42 PM
GAS GUY is online now   Reply With Quote
Old 01-02-2013, 03:08 PM   #153
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,389
According to Happy Trails web site the stock Klr muffler only weighs 12 lbs.I don't know if that is accurate though.
2001 GAS GAS 321
IBA # 23,716
Old 01-02-2013, 05:18 PM   #154
PacificPT
Oddometer: 984
I will try to weigh the stock unit tonight when I get home. I did when I took it off last year, but want to check and make sure I am giving out the right numbers.
2000 KLR650
Old 01-02-2013, 05:45 PM   #155
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,389
Ok, that sounds interesting.I would like to know too.
2001 GAS GAS 321
IBA # 23,716
Old 01-03-2013, 11:01 AM   #156
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,389
Shock disassembly and service
I decided to disassemble the shock for routine service and fluid change.
The spring is a 550 in.lb. Eibach and is the firmest spring they currently sell for the KLR so I knew it was going to be tough to remove.
You have to compress it enough to get the collar out to allow the spring to come off.
I spent a few hours scrounging material and making a makeshift spring compressor.
It compressed the spring some but not enough to remove the collar.So I ended up having to run over to my friends house and use his shop press to remove the spring.
Then I could disassemble the shock after releasing the nitrogen pressure.
The fluid was toast and it only had about 10,000 miles on it.
I left some fluid in the picture so you could see how black and dirty it was.
This shock has been rebuilt before along with a 2 stage valve stack so the peening has already been removed from the top nut as you can see in the picture.So I can just remove it instead of having to grind first.
Here it is,with all the valving layed out.
The compression stack is in the bottom of the picture and the rebound stack is in the top of the picture.
You can see the 2 stage valving as the shims go from big to small and back to big in both sides.
I measured and wrote down all the dimensions on the valving for future reference.
I ordered up a new seal head and fluid,so am waiting for that.
I would like to get a stock 2008+ shock and see what the stock valving looks like.If I come across a good deal on one I will pick it up and see.
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-08-2013 at 01:52 PM
Old 01-03-2013, 03:31 PM   #157
fleshpiston
fleshpiston's Avatar
Oddometer: 599
If it helps ......
I just weighed stock and the LV X3 on a crappy bathroom scale.
Stock ..... 10.5 lbs (missing small heat shield)
LV X3 ..... 6 lbs (with mid-pipe, seems only fair)
SRX600
SRX250
SR500
KLR650
fleshpiston is offline   Reply With Quote
Old 01-03-2013, 03:43 PM   #158
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,389
Originally Posted by fleshpiston View Post
If it helps ......
Thats odd, HT website says the stock pipe is 12 lbs.and the LV pipe is 12.1 lbs.It must be a typo.
Anyway thanks for posting that, it helps.
How do you like the LV muffler ?
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-08-2013 at 01:55 PM
Old 01-03-2013, 04:01 PM   #159
fleshpiston
Oddometer: 599
I haven't even used it yet, I got it because it's supposedly one of the quietest and for the mechanical baffle.
Oh, and saving 3.5 pounds apparently!
SRX600
SRX250
SR500
KLR650
Old 01-03-2013, 06:51 PM   #160
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,389
I like a quiet muffler on the Klr , I plan on running a LV this year also.
2001 GAS GAS 321
IBA # 23,716
Old 01-03-2013, 08:59 PM   #161
DirtDad
Green Chile Guru
DirtDad's Avatar
Oddometer: 1,608
I got 12lbs for my stock exhaust, on my crude scale. I used a DG slip on, which is no where near as nice as the Leo. It is a little loud, but only 6 lbs. With the JD jet kit, air box mod, and slip on, it really woke up the bike.
After removing the license plate holder, and hardwar, foot pegs, and lighter handle bars, I lost about 14 lbs total including the slip on. I heard you can save up to 7 lbs using a lighter battery. That would be around 21 lbs total.
I noticed the difference with just the 14 lbs.
Current rides:
2014 YZ250F 05 KTM300EXC 07KTM450EXC
04 GasGas 280, finally, my perfect stable.
DirtDad is offline   Reply With Quote
Old 01-10-2013, 06:31 PM   #162
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,389
Petcock Mod
I made up a aluminum plate and a gasket to eliminate the vacuum diaphragm assembly.
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-08-2013 at 01:57 PM
Old 01-10-2013, 06:56 PM   #163
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Light weight KLR?
This one looked pretty good. The owner/builder used to post here ... probably got run off by KTM/BMW attack dogs who Love To Hate KLR's.
I think a lot can be shaved off by ditching the stock headlight and all the ancillary parts that support it. This guy did a nice job with better forks and shock too. The build is (I think) somewhere on ADV ... no idea where. Anyway ... just another creative direction to go with the trusty KLR! The bike above was NOT the final version ... it was still in progress.
Old 01-11-2013, 08:23 AM   #164
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,389
ADV GRIFTER,
I remember seeing that bike.I think it belonged to Sam M.
I think he ended up putting a versys engine in it,and then eventually moved on to something different completely,IIRC.
2001 GAS GAS 321
IBA # 23,716
Old 01-12-2013, 02:43 PM   #165
Byork
Novice
Byork's Avatar
Oddometer: 237
Doo
Gas Guy or anyone else listening,
I tried to search to find answers, but seeing as I am in the middle of doing the doo I'll just ask. Sorry if its redundant. (I'm asking on this thread because I find it better than any of the "KLR mod" threads. Good job Gas Guy!!)
I am upgrading to a torsion spring. I removed the stock extension spring without removing the inner case. Since the torsion spring goes outside the inner case, do I still need to remove it for anything?
Also, the "lever" that the stock extension spring was connected to is just floating on the shaft. Is this correct, I have basically just obsoleted that part and it remains on the shaft?
So basically, am I ok not removing the inner case if I've removed the spring? Thanks in advance. Maybe I can wrap this up tonight and move on to putting on my new chain.
BTW my stock spring had plenty of tension and travel, I almost closed it back up without changing it.
'06 Vulcan 900
Byork is offline   Reply With Quote
Times are GMT -7.   It's 01:58 PM.
