Old 01-11-2013, 08:45 PM   #17536
jraugie1
How hard can it be?
jraugie1's Avatar
Oddometer: 397
drz400s lighting upgrade
I am using my drz more and my sprint less and less on our norcal mountain roads. Anyone recommend a lighting upgrade? The stocker is barely usable on the twisty roads at night.
jraugie1 searching for truth and chocolate
Triumph Sprint ST, DR-Z400S
I go way too fast to worry about my cholesterol.
Stop Global Whining!
jraugie1 is offline   Reply With Quote
Old 01-11-2013, 08:58 PM   #17537
AtlasExp
Руссо Туристо
AtlasExp's Avatar
Oddometer: 266
Enjoy super power lighting!!!!!!
http://advrider.com/forums/showthread.php?t=766161
http://shop.globetrottin.com/categor...?categoryId=37
Motorcycle Racks Handmade in the US! Support a fellow Rider!
Dual Sport Luggage Racks for: DRZ-S, SM and E and KLR650 and DR650: http://www.moto-racks.com/
AtlasExp is offline   Reply With Quote
Old 01-12-2013, 02:10 AM   #17538
oldcodger
Oddometer: 57
Those lights are NHS on their own. They'd make a nice set of spots to go with the original headlight though.
Here is a link to the lights used in that fairing.
http://stores.intuitwebsites.com/hst...off/Detail.bok
oldcodger is offline   Reply With Quote
Old 01-12-2013, 03:11 AM   #17539
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 573
Originally Posted by ThumperDRZ View Post
Cam chain tensioner was upgraded in 2003
Buy a manual CCT or one from a 2003 and up.
Suspension was upgraded in 2002 as mentioned.
There are also torque value changes but other than that it's been the "Bold New Graphics"
Make sure you go on Thumpertalk to learn all of the tricks on a DRZ. Main thing is to check that front sprocket nut. These must be installed with red loctite or they come loose. Then the oil seal behind them will weep.
Thanks I appreciate the info!
Scott
06' Triumph Tiger (my lifer)
06' Husqvarna TE610
TIGERRIDER007 is offline   Reply With Quote
Old 01-12-2013, 05:17 AM   #17540
rjsurfer
Oddometer: 159
Do yourself a favor and get an HID headlight,cheapest and best solution.
You WILL have to adjust your headlight down a bit and split the rubber gasket to seal the bulb against the housing again to keep the water out but it's eazy peezy.
The high beam gives you a bright wide beam that is easily 3x brighter than stock and he low beam is deeper in throw and really picks up road irregularities without blinding oncoming drivers.
Ron W.
DRZ 400SM
DL-650 Gone but not forgotten
rjsurfer screwed with this post 01-12-2013 at 06:07 AM
rjsurfer is offline   Reply With Quote
Old 01-12-2013, 04:33 PM   #17541
coarsegoldkid
coarsegoldkid's Avatar
Oddometer: 102
Does anyone know if the Motion Pro Fork Tube Micro Bleeder for expelling air pressure will fit on the DRZS forks. It's not listed. Maybe you know one that does?
coarsegoldkid is offline   Reply With Quote
Old 01-12-2013, 04:35 PM   #17542
ADVGD
ADVGD's Avatar
Oddometer: 97
A route report video for Adventure Guide on a DRZ400
New Zealand Adventure Routes
ADVGD is online now   Reply With Quote
Old 01-12-2013, 04:50 PM   #17543
SuchesRider
Just Do It!
SuchesRider's Avatar
Oddometer: 1,602
Tank removal/installation issues
I have an 08 DRZ400S and I am having an issue with removing/installing the stock tank. The stock tank has a non vacuum petcock, there is a corbin seat, and I upgraded the carb to a FCR39MX. It is just about (if not) impossible to remove the tank and then reinstall it without removing the petcock first. The fit is just too tight. Have any of you guys had this experience? If so, what did you do? Thanks. SuchesRider
Four wheels move the body. Two wheels move the soul.
SuchesRider is offline   Reply With Quote
Old 01-12-2013, 05:11 PM   #17544
150ron
150ron's Avatar
Oddometer: 819
Well, its the weekend, so i hit the trails, love being out and about.
Just some dude...
150ron is offline   Reply With Quote
Old 01-12-2013, 05:18 PM   #17545
ThomasVolomitz
Not so Gnarly
ThomasVolomitz's Avatar
Oddometer: 3,977
60 degrees, everything melting. Great January riding day in Ohio.
Doo Done
ThomasVolomitz is offline   Reply With Quote
Old 01-12-2013, 05:21 PM   #17546
Creeker747
Creeker747's Avatar
Oddometer: 91
Burrrrr
We've got a high here in Az of maybe 47 degrees today. What was the temp? Also, do you want us to take up a collection for a bucket, sponge and soap to get your bike washed? JK
Thanks for the nice pic
Creeker747 is offline   Reply With Quote
Old 01-12-2013, 05:21 PM   #17547
oldcodger
Oddometer: 57
There are a couple of common thread pitches for bleeders. I think I know the size, but I am not absolutely certain. The easiest is to remove one of the screws and measure across several threads with a metric steel rule.
I didn't even do that when ordering. I've got Zeta bleeders ordered from Wheeling. I told them exactly which fork and they sent me the right part.
oldcodger screwed with this post 01-12-2013 at 05:54 PM
Old 01-12-2013, 05:26 PM   #17548
150ron
150ron's Avatar
Oddometer: 819
You know what!!! that is it!! F you guys, ive had enough
Im washing my bike now
It was cold out, temps were around the high 40's i think.
Just some dude...
Old 01-12-2013, 05:51 PM   #17549
oldcodger
Oddometer: 57
You too?
Old 01-12-2013, 06:52 PM   #17550
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,177
I am going for a ride tomorrow to Winckenburg Via BuckHorn wash rd da highest in Winken. will be 43 deg. ,bundle up & let's ride . This ride is mostly washes & deep sand crossing . Trakmaster II here i come ...
DR-Z400E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Times are GMT -7.   It's 12:20 AM.
