Old 01-12-2013, 04:41 PM   #31
ttpete
Rectum Non Bustibus
Oddometer: 6,159
I've never used the beads, and I don't intend to try them. I own a Coats bubble balancer, and I can balance a wheel in about 10 minutes. Why mess with something that's worked for me for about 30 years?
2015 BMW R9T, 2010 Ducati 1098 Streetfighter S
2009 Kaw 650 Versys, 1967 Triumph 650 TT Special
Old 01-12-2013, 08:49 PM   #32
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,619
Fitted new tyres yesterday - took the tubes out, fitted them into new tyres, the Dynabeads stay in the tubes. That saved me 20 minutes of balancing by those times.
motu is offline   Reply With Quote
Old 01-12-2013, 09:11 PM   #33
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,661
Originally Posted by kurtaxline View Post
These guys are a total scam..!! The owner doesn't even know how to explain the physics of the product. Don't believe their nice little animation on their web... it's total BS..!! IMPORTANT NOTE: THIS PRODUCT DID NOT WORK FOR ME..!!! But, I found out the hard way. They're REAL easy to put in... but taking them out is a very expensive endeavor. You've got to break down your wheels if you don't like the product to get them out. I used them in my 2009 Harley Street Glide and got a real bad vibration around 60MPH and up. After the many phone calls to Innovative Balancing's "tech support" (which is a complete joke because they don't have any tech support) they couldn't explain it at all... all they could say was that it had to be something loose or wrong with the bike. So, I spent several hundreds of dollars between having my tires aligned with the rim (the dot and the valve stem), having my Fall Away checked-out, having my rims checked for defects, having every nut and bolt checked-out and ultimately having the wheels broken down to remove the POS DynaBead BS product. Went back to weights and immediately lost the vibration. Will NEVER use a scam product like this again and will NEVER deal with these Innovative Balancing yahoos again. DON'T DO IT..!! I only wish someone would have warned me beforehand. When I finally called to ask for my money back, all Carol (the owner) and her minions would say was "we'll gladly refund any unused product". When I asked how I could get my money back since I had obviously used it, they again just said (like a broken record) "we'll gladly refund any unused product". This meant of course that I was not getting any money back. I've never received any money back from them for my "used" product. In summary, their little white ceramic beads that go so easily in the valve stem, cost me roughly $500 to fix and ultimately remove. Don't be a sucker... they're counting on it..!!
Yea how come they work for most people then? I'd have to say that at least 75% of people around here like them, including me. Just because you didn't doesn't give you the right to call the company a scam.. Get a grip, pal.
AviatorTroy is offline   Reply With Quote
Old 01-13-2013, 09:49 AM   #34
fast4d
Oddometer: 2,481
I have been using dynabeads then airsoft BBs for the last 30+ tires
most of my prevous bike had nice oz, marchesini cast and forged wheels. they usually take a quarter oz to balance. so beads would work fine
my zrx has some HEAVY wheels which took 1.5 oz to balance without tires as I found out for the first time last week. I mounted a used angel (pirelli) but the paint spot faded so I did not clock and just put in my usually amount of BBs. got a vibe above 80mph so I balanced it the old fashion way.
fast4d is offline   Reply With Quote
Old 01-13-2013, 04:00 PM   #35
Megadeus
Motorcycles are therapy
Megadeus's Avatar
Oddometer: 221
In cars, which have a longer radius from the axle to the tires' edge, I find a static imbalance to emerge around 45-55 mph.
If I balance said tire and I have a vibration around 65~75 mph, I am suspect of a road force induced imbalance. A road force caused by rim run-out or imperfection in the tires' construction.
Sometimes the road force imperfection can be alleviated by reclocking the tire on the rim 180 degrees. Most of the time it's a runout issue with the rim. ie... bent lip, broken spokes, etc....
The other kick in the nuts is that if you ride a bike with an imbalance for a while, say 500+ miles, you end up wearing the tire circumference into an oblong shape. (Think egg shaped) The oblong shaped tire induces a vibration no matter how many times you put weights on it or put balancing media into it. Dynabeads only work with a good true rim and a new tire. Worn/questionable tires (track take offs) will not always balance out because you don't know if it's worn evenly.
This is why some people bitch that dynabeads didn't work for them. Their used tires are F'ed.
Megadeus is offline   Reply With Quote
Old 01-15-2013, 08:42 AM   #36
bwalsh
bwalsh's Avatar
Oddometer: 12,305
Good for you! But I'd say you're the only person on this thread with a tire balancer.
For people like me who change their own tires and don't own a balancer, and have no need to since using Dyna Beads, they are a lot cheaper than taking the tire/rim or the whole bike to a place that will charge, what I consider a healthy fee to change and or balance them. I also don't have to buy and fool with lead weights.
I run tube tires. After the two minutes it took to put the beads in the tubes on the first set of tires I changed out, I have never have to balance any of other five pairs of tires in 30,000 miles. I don't change tubes until they are toast.
Bottom line for me is...they work! For an initial up front cost of 10-20 bucks, I'll keep using them until they stop making them.
Another thing, I've only been riding four years and had never heard of the paint dot on a tire until about a month ago so of course all my tire changes didn't line this dot up where it is supposed to go....Still no vibration! Even more of an endorsement for Dyna Beads. Next tire change I may have to try this dot thing out.
Where is the dot supposed to be again? Across from the air valve?
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 01-15-2013, 09:04 AM   #37
ttpete
Rectum Non Bustibus
Oddometer: 6,159
That's the light spot. Valve goes to the dot if there is one. You'd be surprised how good tires can be now. I've mounted many that didn't really need any weights.
I lucked out on the balancer, picked it up at a swap meet years ago for fifty bucks. But there are balance arbors out there that are really inexpensive, and It's not difficult at all to balance with one of those. Try Harbor Freight.
Old 01-15-2013, 06:15 PM   #38
bwalsh
bwalsh's Avatar
Oddometer: 12,305
Thanks! I have four tires to mount soon so I'll be looking for the dot.
I've seen homemade balancers on here somewhere. I've had zero problems with the magic beads so I'll stick with them for the time being.
I've been wanting to try the air soft BB's in my truck tires but haven't gotten around to it.
2004 XR650L
Old 01-15-2013, 10:41 PM   #39
ROAD DAMAGE
Oddometer: 1,118
Hey Kurt,
Next time you get your bike up to 60 mph .......... pull in your clutch and let your motor go back to an idle while the bike coasts down the road. I'm guessing that most of your vibration will go away when you do this.
Next time you want to have your tires balanced, call me. I'll do it for $250!
Welcome to ADV Rider! Angry, spiteful and uninformed ............. you're gonna fit in here just fine!
Formerly known as: Routt County Rob
ROAD DAMAGE is offline   Reply With Quote
Old 01-16-2013, 08:24 AM   #40
bwalsh
bwalsh's Avatar
Oddometer: 12,305
I wish he would have told us how he really felt about them instead of beating around the bush...
2004 XR650L
Old 01-16-2013, 09:03 AM   #41
kantuckid
Oddometer: 3,177
Originally Posted by FatChance View Post
I find it interesting that anecdotally there are more people who say they don't bother balancing their tires and notice "no problems" than say the Dyna beads work as advertised. Maybe one could read something into that about how well Dyna beads actually work...
FYI, a tire doesn't "stay" in balance, even if it was a so called "perfect tire" when mounted to a good rim that was concentric and in balance itself. Tires wear unevenly-regardless of other factors and even if in balance with rim weights in the beginning of their life. You can not use beads & rebalance with rim weights or spin new tires for best balance spot but fact remains they can & do go out of balance from uneven wear.
I use the beads and have stuck with the 2oz rear/10z front as advised by the seller. They work for me & keep my tires spinning smoothly over the life of the tire. I don't sell them, have been a pro car & helo & industrial mech that also worked in a tire factory a good bit & life long bike guy. I also reuse them-they tirn a little black as the collect some stuff off the tire liner but still nice little round beads after many revs in there.
FWIW,The new Michelin Pilot Road 2's I just bought did not have balance spots on them. Years ago when I worked on the balance machines in a Goodyear tire plant the machine dropped a colored wax dot of various colors based on what spec it met, not based on the light spot, it was about if that car tire met an auto mfg's spec for being a OEM new car tire or it also indicated that the tire was unsuitable for any use. There were other checks such as human visual inspection prior to balance check & force variation check after the balance check.
I wish we could get a realsitic view from someone that works in MC tire place but they all seem to be foreign these days-all we get is superficial info from mags r.e., MC tires as they are paid advertisers in the mag so is "light info" & somewhat biased too.
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85
kantuckid screwed with this post 01-16-2013 at 09:12 AM
kantuckid is offline   Reply With Quote
Old 01-16-2013, 11:48 AM   #42
bwalsh
bwalsh's Avatar
Oddometer: 12,305
So now you have me wondering if the dot on MC tires means anything or is of any real concern.
As I said earlier, I have never lined up any "dot" (didn't even know they existed) on any of the 12-14 tires I've mounted. No problems what so ever. I even reversed one of them half way thru it's life, no matching up anything, and it was still a smooth ride for the next 4,000 miles.
2004 XR650L
Old 01-16-2013, 08:17 PM   #43
anotherguy
anotherguy's Avatar
Oddometer: 6,631
The dot is the light side of the tire. It is to be placed at the valve stem.
I have a Snap-On computerized balancer at my disposal. I have Dynabeads in the tires.
We had a customer buy a set of wheels that were way out of balance to the point they needed 3 1/2 ounces of lead weights. He couildn't bear that ugly stuff on his shiny new wheels. So we got him some Dynabeads and installed them. Worked very well on a very shitty set of wheels. I was sold. And I was quite skeptical prior to that experience but that's changed.
you don't see luggage racks on a hearse..........act accordingly
Old 01-17-2013, 05:25 AM   #44
MotorradMike
MIL-TFD-41
MotorradMike's Avatar
Oddometer: 1,019
Just to be clear, you didn't try the wheel/tire assembly (with DynaBeads) on the computerized balancer. Correct?
Mike
So far, everything that has surprised me has been completely unexpected.
BMW R1100RS
MotorradMike is offline   Reply With Quote
Old 01-17-2013, 09:46 AM   #45
blackx70
Oddometer: 772
When I got my bike, there were weights on the front wheel. I replaced the tire and removed the weights. I did a spin balance and could not find a heavy spot. I have been running with no weight on the front and everything seems fine.
BMWMOA 182072
blackx70 is online now   Reply With Quote
Times are GMT -7.   It's 07:56 PM.
