01-11-2013, 09:59 AM
#24796 | |
Justa Venturer
Oddometer: 1,245
Good luck!
___________________________________________ So much riding-so little time |
01-12-2013, 05:49 AM
#24797 | |
Enjoying my last V8
Oddometer: 5,296
Regards Fritzcoinc 96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT, 86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM, |
01-12-2013, 08:12 AM
#24798 |
Oddometer: 5
Axle block/sliders
According to my 2006 manual the axle blocks for the TE and the SM are the same, so these should work on the TE. I see yours is a 2000 model though so you should check with a dealer or check your swingarm dimensions
Here's the dimensions for my 2006: height-40mm, chain side axle dia- 25mm, nut side axle dia- 20mm Don't hesitate to contact me through my website (www.six-ninedesign.com) with any other questions. |
01-12-2013, 10:21 AM
#24799 |
Justa Venturer
Oddometer: 1,245
The axle diameter is smaller on the 2000 model.
01-12-2013, 08:45 PM
#24800 |
Oddometer: 524
Picking this beauty up on Monday
![]() ![]() Just 900 miles and set up about perfect.
www.davidschelske.com nw scout screwed with this post 01-12-2013 at 10:48 PM |
01-12-2013, 08:56 PM
#24801 | |
Infraction Collector
You'll love it!
Hungry? Out of work? Nowhere to ride? Do us all a favor and eat a Sierra Club member. "They" said we couldn't run the OBDR on supermotos... |
01-13-2013, 07:46 AM
#24802 | |
Oddometer: 76
Gas cap reassembly question
Thanks for the write-up. nsx screwed with this post 01-13-2013 at 07:48 AM Reason: correct spelling error |
01-13-2013, 10:40 AM
#24803 |
Oh! Pretty sure I know that bike. It's a beauty indeed.
01-13-2013, 10:43 AM
#24804 |
I found that it was easiest to set the key slot just short of the full open position. There, you'd put the lugs in the open position and turn it back until the hole in the tumbler shaft lines up.
01-13-2013, 11:59 AM
#24805 | |
Baby steps...
Oddometer: 1,751
![]() It doesn't matter when the chain was done...if/when it needs it, do it
"turn it on man, turn it on-whatever, whoever you are-TURN THE FAWKER ON!" -Herbert Foster Gunnison 01 Girlie 09 TE450 |
01-13-2013, 01:25 PM
#24806 |
Oddometer: 803
01-13-2013, 02:43 PM
#24807 |
Oddometer: 49
I checked the free sag on my 06 TE610 and it is close to 2 inches. I have the race sag set at 4-1/4 inches. I think that the stock spring (6.4) is too stiff for my weight (185lbs). How do I determine what rate spring that I need? At this point I use the bike for day trips without any luggage.
Do I need to look for a Sachs spring only or are there other springs that might work? Singletrak |
01-13-2013, 07:02 PM
#24808 |
Oddometer: 1,120
Stock forks are 0.52 kg and rear is 6.4 kg
You most likely need .0.48s and 5.8 springs Call Les Tinius: Les Tinius LT Racing Mail: les@lt-racing.com Web: www.lt-racing.com Phone: 360-871-2259 He can get you the right rear spring and if you send him the shock he can revalve for your riding style and normal riding conditions. He is an old suspension guru and specializes in Huskies.
Current Stable: 2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS 2007 Husqvarna TE610 , 2003 KTM 525 MXC Indy Unlimited screwed with this post 01-13-2013 at 07:10 PM |
01-14-2013, 06:06 AM
#24809 | |
Oddometer: 1,702
Dan |
01-14-2013, 01:44 PM
#24810 | |
Oddometer: 7,755
Yeah +1 more. I could not be happier with the work Les did to my 610.
Albert Einstein Baja trip to the tip 6:10 to Yuma trials and tribulations in the Mojave Baja Blitz Yard sale View Current Location via Spot Tracker |
