Old 05-13-2012, 08:06 PM   #31
Super Tracker
Oddometer: 9
I dug and dug, looking for info on XLR600/650 hybrid engines, found your thread on TT, followed over here, and no new news! Get on it man!
I think I stumbled on the original thread on TT, because I was searching for info on using a 650L head on an XL600R.... I know bassackwards. But I was just keeping my options open, since my frame/suspension is already modified, so carb placement isn't an issue. Going to follow your lead and start a thread over here, seeing more interest.
Good luck with your build, I'm following.
Later on,
TR
Super Tracker is offline   Reply With Quote
Old 05-14-2012, 07:15 AM   #32
brucifer OP
brucifer's Avatar
Oddometer: 1,624
Later on,
TR
Hey, welcome to the XL600R world!
It will work in reverse as well. I built a 2000 plated XR600 using an '84 XL600 bottom end, XR650L cylinder and the 2000 XR600 head. The original engine was blown up; the only things usable were the head, transmission and outer engine covers. The XR600 and XR650L heads are the same with one important difference (besides the air injector holes) the 650L has a larger combustion chamber than the 600.
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 05-18-2012, 12:22 AM   #33
Ivanych
Ivanych
Ivanych's Avatar
Oddometer: 213
Originally Posted by brucifer View Post
Couple inside shots of the frame.
Hi Mr. Brucifer!
What color (RAL number) has the paint for painting the frame of your bike?
It is OEM HONDA color?
I have to paint the frame in the near future and I can't choose a color: black or red.
Thank you.
Ivanych is offline   Reply With Quote
Old 05-18-2012, 05:58 AM   #34
brucifer OP
brucifer's Avatar
Oddometer: 1,624
The color that's on there now was matched up at the powder coater, I don't know what the number is. But if you're speaking of the factory paint code originally on the frame, I'll see if I can dig it up for you. I believe I took a pic of the code decal before the powder coating.
Old 05-18-2012, 06:32 AM   #35
brucifer OP
brucifer's Avatar
Oddometer: 1,624
Okay, found it. It's R-110.
Old 05-18-2012, 07:12 PM   #36
jontow
Oddometer: 51
What a monster this will be .... I love it.
jontow is offline   Reply With Quote
Old 05-21-2012, 05:07 AM   #37
kmequint
kmequint's Avatar
Oddometer: 51
I'm in!
kmequint is offline   Reply With Quote
Old 05-21-2012, 01:00 PM   #38
EmilianoXR650L
EmilianoXR650L's Avatar
Oddometer: 198
Hi !!!!!
... tambien me dijo un arriero, que no hay que llegar primero, pero hay que saber llegar ......
xr650L / DR 650 / TRX400FA / C90 ...
EmilianoXR650L is offline   Reply With Quote
Old 01-13-2013, 06:18 PM   #39
brucifer OP
brucifer's Avatar
Oddometer: 1,624
Hello folks! Been a while but have some forward movement.
Okay, finally pulled the forks apart and cleaned them out and reassembled with new seals.
Fit them into the triples and bolted on new fork guards with new bolts.
I scored a set of CR wheels from my neighbor with dual sport tires already installed. The fronts like new--the back, not so much.
Installed the wheel assembly but the axle came up short.
Here you can see it doesn't quite make it through.
So, I took the spacer from the other side.......
.......and had my machinest take 5/8" off.
Old 01-13-2013, 06:25 PM   #40
mcma111
mcma111's Avatar
Oddometer: 7,986
Bruce,
You do know that the CRF R and X axles are different don't you? The X is cut away for the Odo drive where as the R is not. Looks like you have a R axle.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-13-2013, 06:26 PM   #41
brucifer OP
brucifer's Avatar
Oddometer: 1,624
He also made me a spacer for the swingarm linkage. See the shiny piece to the left.
Here it is with the front end on for good. The swingarm is on temporarily while I figure out where I'm going to route the shocks remote reservoir and hose.
Old 01-13-2013, 06:29 PM   #42
brucifer OP
brucifer's Avatar
Oddometer: 1,624
Originally Posted by mcma111 View Post
Bruce,
It's all good, Steve. The axle's squared away now and I'm going to run an aftermarket speedo like a Vapor or something, so I'm not concerned about a speedo drive.
Old 01-13-2013, 06:56 PM   #43
davek181
Oddometer: 166
Great build report. I watch with great interest since my winter project dream list is USD forks and rear disc. I have already scrounged the pieces necessary, just lack the ambition and opportunity. I have a set of 94 CR125 forks I intend to use. Did you change spring rate?
Keep up the good work and documentation, maybe you will help motivate me
davek181 is online now   Reply With Quote
Old 01-13-2013, 07:23 PM   #44
brucifer OP
brucifer's Avatar
Oddometer: 1,624
Thanks Dave.
The springs that are in the forks now are Eibachs but I don't recall the number on them. I'm gonna go with what's there for now and change later if need be.
The shock I'm planning on having built specifically for this bike. I'm going to try out a local guy who says he'll give me the same deal as Race Tech only shipping charges won't be involved. Plus, being local will be nice if there's fine tuning to be done--which there probably will.
Old 01-13-2013, 09:09 PM   #45
Rot Box
Oddometer: 108
Really cool buildup. Looking forward to updates
2002 WR426F - 94 ATK605DSES - 1984 CR500R - 1981 XL500S
Rot Box is offline   Reply With Quote
Times are GMT -7.   It's 05:16 AM.
